Vizio VO420E - INV_ON signal stays low
  • ngth82
    • Jul 2015
    • 541
    Good afternoon all -
    I have another TV in hand. This time it's a Vizio VO420E. I picked it up for free the other day. The TV is manufactured in the 2008/2009 time frame.
    Pictures of the boards and an overall view are attached. I checked the voltages on the power board.
    Initial assessment
    - There is some sign of life on the main board, but without schematics, i see that a few caps have 0V on either side, and a couple of LDO's and switching supplies have output voltages. I just don't know if the values are correct.
    - The backlight does not turn on
    - no sign of life with flash light test shining at screen
    - The optical audio out does not illuminate red.
    - The main board fuses near the power connector are okay -
    -- F1 - 5.128V on both sides
    -- F2 - 12.28V on both sides
    Main caps
    +165V across the main caps when off
    +392V across the main caps when the power button is pushed.
    The voltage across the main caps stay steady.
    Power Supply - Connector CN201
    Pin name, actual voltage read
    ON/OFF, 0V (when off), 3.166V (when on)
    +12, 12.27V
    +12, 12.27V
    +12, 12.27V
    GND, 0V
    GND, 0V
    GND, 0V
    GND, 0V
    GND, 0V
    ST/+5V, 5.194V
    ST/+5V, 5.194V
    ST/+5V, 5.194V
    Power Supply - Connector CN202
    DIM, 0V
    INV_ON, 0V
    VBR_A, 0V
    No Connect
    Status, 0V
    No connect
    Tests
    - I was able to force the backlight on by removing the cable from connector CN202, and hooking up an external power supply to the INV_ON signal when the TV is ON.
    - The backlights glow - at least the back lights work.
    - I disconnected the ribbon cables between the main board and the integrated T-CON, no change in behavior.
    - It appears that the main board is not running yet.
    Request
    - Does anyone have the schematics for the main board or the service manual for this TV? I was not able to find it online. I was only able to find the following brief service manual in online form only:
    https://www.manualslib.com/manual/10...page=19#manual
    -Thomas
    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Vizio VO420E - INV_ON signal stays low
    you main board is only half working. ps/on is present, but bl/on is missing.
    a schematic is normally impossible to find foe main boards unfortunately.
    you can try and trace the bl/on pin backwards from the connector and hopefully find the bad component, but mains are hard to find faults on.
    have you checked all of your ldo regulators?
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
      http://www.shopjimmy.com/catalogsearch/result/?q=VO420E
      Look at EEPROM and Repair kit to see if it will fix your symptom.
      • ngth82
        • Jul 2015
        • 541
        Hey guys -
        Thanks for the reply. I've been busy at work and didn't realize there were replies to the thread!
        @budm - I'm going to cave in and give it a try. Looks like eBay has a kit that includes the EEPROM + 5 LDOs. for $15 including shipping.
        @attainteddragon - Yes, here are the LDO voltages that I have found along with the markings on the package:
        Pin orientations are looked at from "left-to-right" with the tab "up"/"north". I can't find a datasheet for the part marked L243 / G1117.
        U11 - 7805CT
        Pin 1 - 12V
        Pin 2 - 0V
        Pin 3 - 5V
        Tab - 0V
        U4 - L243 G1117
        Pin 1 - 5.162V
        Pin 2 - 3.29V
        Pin 3 - 2.046V
        Tab - 3.3V
        U7 - 1084
        Pin 1 - 2.065
        Pin 2 - N/C, short pin
        Pin 3 - 5.147
        Tab - 3.3V
        U9 - L243 G1117
        Pin 1 - 1.259V
        Pin 2 - 2.506V
        Pin 3 - 5.142V
        Tab - 2.506V
        U8 - L243 G1117 - I think this one looks suspect.
        Pin 1 - 0V
        Pin 2 - 1.250V
        Pin 3 - 3.3V
        Tab - 1.250V
        U2 - L243 G1117
        Pin 1 - 2.045V
        Pin 2 - 3.288V
        Pin 3 - 5.137V
        Tab - 3.288V
        U4 - L243 G1117
        Pin 1 - 1.372V
        Pin 2 - 2.619V
        Pin 3 - 5.140V
        Tab - 2.619V
        TU31 - I think it says EH13A / 925N05 - no voltage
        Pin 1 - 0V
        Pin 2 - 0V
        Pin 3 - 0V
        Tab - 0V
        U21 - 4953 is what i can make out.
        Looks like a dual channel P-FET like a Vishay Si4953
        Pins 1 and 3 are the source
        Pins 2 and 4 are the gate
        Pins 5-8 are the drain.
        Pin 1 - 12.25V
        Pin 2 - 11.97V
        Pin 3 - 12.25V
        Pin 4 - 11.97V
        Pin 5 - 0V
        Pin 6 - 0V
        Pin 7 - 0V
        Pin 8 - 0V
        U1 - 4953 is what i can make out.
        Pin 1 - 5.163V
        Pin 2 - 0V
        Pin 3 - 5.163V
        Pin 4 - 0V
        Pin 5 - 5.147V
        Pin 6 - 5.147V
        Pin 7 - 5.147V
        Pin 8 - 5.147V
        -Thomas
        • ngth82
          • Jul 2015
          • 541
          I found a separate thread that was talking about several components on the input:
          - Ferrite bead L16 - 1 ohm across it. 1.18V both sides
          - fuse TF1 (the "N" fuse) - that fuse is okay , it reads 0.6 Ohm, 0V both sides
          - Ferrite bead L57 - 1 ohm across it - 0V both sides
          Note that the drain of U21 is connected to L57, then to TF1. In the current state, it makes sense why it's 0V.
          No dead short to ground on either side of the L16, TF1 or the L57 components.
          -Thomas
            U21 is probably not being turned on by the micro controller, it is probably use for supplying the switched 12V to run the T-CON board.
            • ngth82
              • Jul 2015
              • 541
              True. I'll continue to look around the board when i get a chance.
              I attached an up close photo of the power input area with the two FETs.
              I'm a little rusty on my P-FET logic. The pin out of U21 () has the Source on Pins 1 & 3, the Gate on pins 2 & 4, and the drain on pins 5-8.
              The Gate should be controlled by the microcontroller. I haven't followed the traces for the Gate back to where they originate, but i would imagine that the source and gate should be both 12V.
              If anything, if the Gate is "high" i should see a voltage expressed on the drain side and it should be close to the Source side, correct?
              -Thomas
                This is P-CH so the GATE Voltage will have to be at least 3~4VDC < than the Source pin Voltage for this P-CH MOSFET to be on.
                I would not worrying about this MOSFET right since you have multiple command signal problems.
                As you can see why the MOSFETs are OFF right now:
                S: Pin 1 - 12.25V
                G: Pin 2 - 11.97V
                S: Pin 3 - 12.25V
                G: Pin 4 - 11.97V
                D: Pin 5 - 0V
                D; Pin 6 - 0V
                D: Pin 7 - 0V
                D: Pin 8 - 0V
                • vinceroger69
                  • Mar 2012
                  • 6714
                  i would probably try the eeprom repair too if this was my set as they do seem to fail a lot on vizio
                  • R_J
                    • 9559
                    Sometimes if you freeze the eprom/flash the tv might work, freeze the ic before pluging in the tv as it usually gets read when first pluged in. then see if it will turn on.
                    • ngth82
                      • Jul 2015
                      • 541
                      Hi R_J -
                      I tried freezing the EEPROM on the back of the board several times then plugged the unit in. Each time i waited until the main caps were fully discharged. No dice. The INV_ON signal isn't being asserted high.
                      I'll purchase the EEPROM kit and report back.
                      -Thomas
                      • ngth82
                        • Jul 2015
                        • 541
                        EEPROM order placed. It'll arrive Nov 6th. I'll check back after Nov 13th as i'm on vacation.
                        I also see that there is an EEPROM dump thread. I'll place the new EEPROM on my programmer and add it to the thread
                        -Thomas
                        • TVDIYguy
                          • Oct 2017
                          • 17
                          • usa
                          Vizio TV suck in boot up screen when turned on.
                          Need a little help here... i've been looking for a similar thread but can't find anything.....
                          I have a Vizio , model number E3DB420VX, and the mother board number is 3642-1462-0150(7b).
                          After looking and researching on the internet for the last two days it seems that all arrows point to the EEPROM CHIP.. however i can't find the location of the chip and nowhere on the internet is it listed.... question is, IS it on this motherboard or is it integrated like the emachine computers of old.... yes i'm that old. If someone can point out what the location number might be that would be awesome. The only station numbers i have seen that remotely look like eeproms are U2,6,8,10. All others look like something else. I've contacted shopjimmy and anybody else listed and they told me to come here. So here i am. I appreciate all suggestions...
                          • ngth82
                            • Jul 2015
                            • 541
                            On mine, the eeprom is on the back of the main board.
                            What are the markings on the parts you identified? Pictures or a line by line breakdown would be helpful. Look at eBay for other potential sources.
                            -Thomas
                            • attainteddragon
                              • Apr 2013
                              • 764
                              • australia
                              part eeprom marking will have 24........ or 25......... on it.
                              • TVDIYguy
                                • Oct 2017
                                • 17
                                • usa
                                All EPROMs I have seen are 8 pin and there are like 5 of them in various sizes .... I'll try to post this pic I took with my phone ... I'll take better ones tonight an see if that helps
                                  Shopjimmy does not sell the programmed EEPROM for this TV model so that may be hard to find.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    probably a smart tv with nand chips etc
                                    • TVDIYguy
                                      • Oct 2017
                                      • 17
                                      • usa
                                      It is a smart tv.... A and all the locations for EPROMs they "look" fine no burns or swelling ... Is it a programming issue ? And if I can't find the correct programmed EEPROM then buy a new board ?
                                      • TVDIYguy
                                        • Oct 2017
                                        • 17
                                        • usa
                                        The only one I see that has a 20's number is this one ...... N28
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • gavric
                                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                                          by gavric
                                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                          When i click video to start playing picture goes black(like when you change...
                                          09-02-2021, 08:55 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead: PSU or Main Board?
                                          by fharris1977
                                          Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
                                          03-12-2024, 12:22 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
