Vizio D50u-D1 Dead: PSU or Main Board?
  • fharris1977
    • May 2017
    • 132
    Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
  • EazyBone
    • Jun 2023
    • 1361
    • United states
    Did you check the fuse on PSU? Unplug PSU to main board plug and check voltages. But fuse first obviously
    • fharris1977
      • May 2017
      • 132
      Yeah fuse is good. No voltage on any pins on PSU connector unplugged from mainboard.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        Check the voltage "across" one of the main filter caps in the primary (C9803,04 or 05) If you have +160vdc
        • EazyBone
          • Jun 2023
          • 1361
          • United states
          I mean, it appears you have a PSU malfunction. You definitely should have voltages. So now you know. Are you trying to diagnose the PSU to fix it? Or just order one.
          definitely test the main filter caps, check the octocoupler voltage also
          • lotas
            • Jan 2016
            • 4805
            • Russia
            And also check the diode at the standby voltage output for a short circuit.
            • Asraf Atb
              Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
              by Asraf Atb
              Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
              Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
              I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
              01-27-2025, 05:02 PM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • JDC
              by JDC
              ONN 100012588
              Long answer:
              07-15-2022, 07:39 AM
