Eeprom dump thread!
This is a sticky topic.
Re: Eeprom dump thread!
Here it is. ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
Try this Dump.Attached Filesif you find these attachements useful please consider making a small donation to the site
Here you need to try to enter the service mode through the remote control (you need to know exactly what code to dial on the remote control) and change the "mirror" item to ON or OFF.Comment
good afternoon, along with the dump that works
thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
I tried to read the eeprom for you but was unable to. Tv does work and has no problems at all.
For some reason this eeprom wont read. I tried a few others and they all read no problem.
Is there a trick to reading this one?Comment
Firmware needed please for a polaroid p43d300fp
lcd panel VES430UNDA-2D NI2
MAINBOARD 17MB110P 23397404Comment
For me in the archive is mb110 not 110p. If you want you can try.
https://files.fm/u/ve6hh359yComment
Thankyou i will give it a try is it best too remove the ic and programe it that way using a ch341aFor me in the archive is mb110 not 110p. If you want you can try.
Edit just downlaoded the file i tried to extract it says no archive is either unknown format or damaged i have tried downlaoding it twiceLast edited by vinceroger69; 03-09-2022, 09:37 AM.Comment
Changed to a diffrent pc downloaded files ok if using a ch341a which files do add? i have never really used a ch341a before thanksFor me in the archive is mb110 not 110p. If you want you can try.
I checked. The archive is good. Use another unzipped or newer version. Installation is done from the stick not with CH341.
Do you know the installation procedure for Vestel electronics?Comment
I picked two sets up yesterday for free both seem too have firmware issues, i have just ordered remotes for both sets so cant try the firmware until remote comes.
please can you explaine the update procedure step by step and i will give it ago i have 1gb and 2gb usb memory sticks so hope that will be ok. Thankyou for your help.Comment
You need the remote control for installation. The installation is done with the OK key.I picked two sets up yesterday for free both seem too have firmware issues, i have just ordered remotes for both sets so cant try the firmware until remote comes.
Hopefully remote will come either today or tomorrow, what format do i need too wipe usb stick with and could you please tell me the procedure i will print if off for future refrence thanks.Comment
1. Format a stick with FAT32
2. Unzip and put the 4 files directly on the stick
3. Insert the stick into the TV
4. Press and hold the OK key on the remote control
5. Plug in the TV
6. The TV's stby LED flashes slowly and then quickly. Now release the OK key
7. Wait for it to finish. It may take 5-10 minutes.
If after this operation the remote control is no longer useful, use a programmable one or a Vestel one.Comment
Thank you i will try it once the remote arrives.1. Format a stick with FAT32
5. Plug in the TV
Hi remote came and mainboard will not take the update at all i just get a brief flash of backlight at power on ( i do have a diffrent mainboard that uses the same panel the tv powers on and works ok) i cant keep this board in the set as is missing some ports like scart rca plugs extra hdmi port but board swap proves psu and backilights work fine so must be a fault on main bga ic i guess.Comment
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks10-17-2025, 03:51 AM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
- Loading...
