Eeprom dump thread!
This is a sticky topic.
  • mallard729
    • Dec 2021
    • 11
    • usa
    #1101
    Re: Eeprom dump thread!
    i was able to pull this file off of the chip i thought was bad. if this file is intact/valid does that rule out my matronix ic 25L3206E, as the issue? the original issue is the vizio logo reboot loop after a frozen auto firmware update
    Seems like reflashing what i have downloaded for the ic would not accomplish anything, but i am very new to this, any help is welcomed
    • lotas
      • Jan 2016
      • 4881
      • Russia
      #1102
      I'm not familiar with Vizio TVs, but most likely you have a problem in another flash, this is emmc, where the software is located, you need to try to force the update via USB, but you need to know how to go through this procedure, if the flash EMMc starts to crumble (wear), then rather only replacement of the mainboard.
      https://support.vizio.com/s/article/...language=en_US
      It is necessary to ensure that when the TV is turned on to the socket, it must immediately pick up the update on USB (the files with the updates must strictly comply with the instructions, as written on their website).
      • mallard729
        • Dec 2021
        • 11
        • usa
        #1103
        thanks for the input, i tried the firmware via usb, but none of the buttons function on back of the tv, they did before this issue started.....
        so it is likely maybe i selected the wrong ic chip ?
        • lotas
          • Jan 2016
          • 4881
          • Russia
          #1104
          But you need to try to force it to pick up the firmware, maybe you need to hold down "OK" or "Power" or the same buttons on the TV with an inserted USB stick, and then apply power, try to change other USB sticks of the old model no more than 2Gb.
          • mallard729
            • Dec 2021
            • 11
            • usa
            #1105
            i have tried for like 3 hours, about 4 different memory sticks, insert usb, plug in to outlet while holding down the buttons, makes no difference, i can leave the tv powered on in a boot loop and holding down power button does nothing , does not shutdown the tv, just stays in a boot loop.
            can this device boot off a usb to try and flash firmware? i think it needs to be at the no signal screen ....
            • mallard729
              • Dec 2021
              • 11
              • usa
              #1106
              i got another 2gb flash drive and tried again, nothing works, i don't think these can boot off usb. pretty sure u gotta have the tv OS loaded ... thanks anyways
              • Yanleb
                • May 2017
                • 102
                Toshiba Seine Board PE0362 EEPROM Dump for 42LX177, 46LX177, 52LX177, 57LX177. Includes IC115 (39VF800A) and IC117 (K9F1208U0C).
                Check this web page that explains how to look at the booting sequence using a serial port and a terminal:
                http://www.benjammin.net/www/pages/t...a-42HL167.html
                • HenryJ
                  • Oct 2006
                  • 54
                  #1108
                  Alpine iLX-F309 needed. At a loss on this one powers on never boots, service info not available to us mortals.
                  • Helikvar
                    • Jul 2018
                    • 68
                    Looking for eeprom dump for Rca rlded4633a-d TP.MS3393.PC821 .I have original eeprom dump but tv stays in standby.Tried a few other eeproms but picture is inverted when powered on.Tried flipping in service menu but image won't flip.
                    • lotas
                      • Jan 2016
                      • 4881
                      • Russia
                      #1110
                      Post your own, non-working dump, I'll try to fix it.
                      • dodysallam
                        • Jan 2022
                        • 7
                        • egypt
                        #1111
                        Pleas I want dump for seiki model se32hy27 main tp.ms3393.p85 think for help
                        • lotas
                          • Jan 2016
                          • 4881
                          • Russia
                          #1112
                          • dodysallam
                            • Jan 2022
                            • 7
                            • egypt
                            #1113
                            Think you I want flash for tp.ms3393.p85 model SEIKI Se32hy27
                            • lotas
                              • Jan 2016
                              • 4881
                              • Russia
                              #1114
                              If the problem is in the firmware, then read the data (DUMP) from the spi flash and put it here and I will restore the firmware for you.
                              • lotas
                                • Jan 2016
                                • 4881
                                • Russia
                                #1115
                                What's the problem with TV?
                                • dodysallam
                                  • Jan 2022
                                  • 7
                                  • egypt
                                  #1116
                                  Just only red led not working
                                  • lotas
                                    • Jan 2016
                                    • 4881
                                    • Russia
                                    #1117
                                    Do you have a programmer?
                                    • dodysallam
                                      • Jan 2022
                                      • 7
                                      • egypt
                                      #1118
                                      Ok
                                      • dodysallam
                                        • Jan 2022
                                        • 7
                                        • egypt
                                        #1119
                                        Ok think you
                                        • dodysallam
                                          • Jan 2022
                                          • 7
                                          • egypt
                                          #1120
                                          Think you again
