Eeprom dump thread!
This is a sticky topic.
  • Farasa
    • Jul 2016
    • 47
    • South-Africa
    #1021
    Re: Eeprom dump thread!
    Hi..
    I'm looking for firmware for a JVC 50 inch led tv...I don't have a number but a board number
    Chassis:Jug7.820.1222
    Cpu. :MSD6328 BXA-Z1
    Panel. :T546hb01
    54T07-c02
    Any help will be appreciated
    • Farasa
      • Jul 2016
      • 47
      • South-Africa
      #1022
      Anyone have this file
      • cheeky2
        • Dec 2012
        • 339
        • uk
        #1023
        Unlikely to get a response where the model number of the TV is omitted.
        • Retrocomputer
          • Aug 2012
          • 47
          • Italy
          #1024
          Originally posted by Retrocomputer
          First of all, thank you so much!!
          There's just one thing bothering me... The dumps you sent me are from a 19" TV, whereas mine has a 22" panel. Is it ok anyway?
          Thank you
          Davide
          No ideas about this? Or the best thing is just to try?
          Thanks!
          • lotas
            • Jan 2016
            • 4881
            • Russia
            #1025
            Thanks!
            Try, only save your dumps. First try spi flash (EN25F80) to check
            Here is another 22
            • Rajnhl
              • Oct 2018
              • 94
              • India
              #1026
              Thank you
              Davide
              if resolution is same than it will work.some settings like mapping may be needed in service menu
              • bader
                • Sep 2021
                • United Arab Emirates
                #1027
                Thanks a lot
                • Amazig
                  • Jul 2021
                  • 10
                  • Portugal
                  #1028
                  Re: nevir :nvr-7409-43hd-n
                  good night
                  does anyone have the dump of this tv,
                  main board: tp.s506.pb801
                  display: HV430FHB-N40
                  the TV only changes the color of the LED monitor, from red off to green on, and the only thing that does
                  thanks to anyone who can help even with an idea
                  thanks.
                  Last edited by SMDFlea; 09-20-2021, 07:12 AM. Reason: https://translate.google.com
                  • andrewc
                    • Apr 2015
                    • 18
                    • australia
                    #1029
                    Anyone has Sony 65W850C dump file?
                    • Rajnhl
                      • Oct 2018
                      • 94
                      • India
                      #1030
                      Originally posted by Amazig
                      boa noite
                      alguém tem o dump de este tv,
                      placa principal : tp.s506.pb801
                      display : HV430FHB-N40
                      o televisor só muda da cor de led monitor ,de vermelho desligado ao verde ligado, e a única coisa que faz
                      obrigado a quem pode ajudar mesmo com uma ideia
                      obrigado.
                      check back light
                      verifique a luz de fundo (google translation)
                      • Amazig
                        • Jul 2021
                        • 10
                        • Portugal
                        #1031
                        Hello
                        thank you rajnhl; I've already checked the bottom leds; everything working; now an information; I received the bin file to update via usb, will it be possible to record on the chip, because the tv does not turn on!
                        thanks
                        • tech9pc
                          • Sep 2021
                          • 50
                          Hi does anyone have firmware for RTU6549-MAIN-V2 RCA Main Board, CV3458H-A, 7.T3458HA1000.0008
                          I got a Version 1 CV3458H-A, 7.T3458HA1000.0003 off ebay for 30.00 and popped it in and board works but about every 20 or 30 minutes tv loses input signal and have to flip HDMI source than back to get picture up again. Probably from not being the same board as original which has lost its HDMI port signals won't work.
                          They are practically identical. Anyone know if I flash the 7.T3458HA1000.0003 board with the 7.T3458HA1000.0008 firmware should work? Thanks for any help.
                          Board BD_CV3458H_A_10
                          Panel LC650RU1A
                          • andrewc
                            • Apr 2015
                            • 18
                            • australia
                            #1033
                            I need dump file for Sony 65W850C please.
                            • Rajnhl
                              • Oct 2018
                              • 94
                              • India
                              #1034
                              Hello
                              thanks
                              plug usb drive and connect to power .
                              • Farasa
                                • Jul 2016
                                • 47
                                • South-Africa
                                #1035
                                Hi..
                                I'm looking for firmware for a CHANGHONG LED55A4000 55 inch led tv...
                                CHANGHONG LED55A4000,
                                Panel. :T546hb01
                                54T07-c02
                                • ducky29
                                  • Dec 2015
                                  • 369
                                  • Europe
                                  #1036
                                  Hi..
                                  Panel. :T546hb01
                                  54T07-c02
                                  Post a picture from the back of your tv.
                                  • Farasa
                                    • Jul 2016
                                    • 47
                                    • South-Africa
                                    #1037
                                    Ok Ducky29
                                    • Jbeni
                                      • May 2014
                                      • FRANCE
                                      #1038
                                      Re: Polaroid TV switch off after logo display
                                      I am looking for the Dump Firmware of this model.
                                      Mark: Polaroid
                                      Model: TQL39R4PR001
                                      Main board chassis: CV9203H-A42
                                      LCD Screen / Panel: T390xvn01
                                      More information: W25Q32
                                      thank you for your reply
                                      • tachiouine
                                        • Nov 2018
                                        • 32
                                        • maroc
                                        #1039
                                        plase dump sony kdl19s5700
                                        • tech9pc
                                          • Sep 2021
                                          • 50
                                          Help! BD_CV3458H_A_10, 7.T3458HA1000.0008
                                          C/N: SU-CU-20180601
                                          Panel LC650RU1A or LK650RA1A01 ?
