Eeprom dump thread!
This is a sticky topic.
  • lotas
    • Jan 2016
    • 4881
    • Russia
    #1141
    Re: Eeprom dump thread!
    Originally posted by luzmina
    Hi, I need the bin file for Magnavox 55ME314V/F7 A4GR1MMA, panel U4DR0XH. I have the DUMP file but is corrupted, I am using the BIN file for the DS3 but I got inverted picture. Thanks
    Post your non-working dump here, I'll try to fix it.
    • luzmina
      • May 2015
      • 17
      • US
      #1142
      Here it is. Thanks
      • lotas
        • Jan 2016
        • 4881
        • Russia
        #1143
        Here it is. Thanks
        Try this Dump.
        • luzmina
          • May 2015
          • 17
          • US
          #1144
          The fixed file works!!! but the picture is still inverted, same as when using the 55ME314V/F7 DS3 file, Thanks
          • lotas
            • Jan 2016
            • 4881
            • Russia
            #1145
            Here you need to try to enter the service mode through the remote control (you need to know exactly what code to dial on the remote control) and change the "mirror" item to ON or OFF.
            • mnjoao
              • Feb 2022
              • 14
              • portugal
              #1146
              good afternoon, along with the dump that works
              thanks
              • mnjoao
                • Feb 2022
                • 14
                • portugal
                #1147
                thanks
                • Storyteller12
                  • Jun 2020
                  • 625
                  Originally posted by Cantv
                  Hello , some one can share with me the EEPROM DUMP FOR Samsung tv UN60H7150 . Thank you in Advance .
                  I tried to read the eeprom for you but was unable to. Tv does work and has no problems at all.
                  For some reason this eeprom wont read. I tried a few others and they all read no problem.
                  Is there a trick to reading this one?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #1149
                    Firmware needed please for a polaroid p43d300fp
                    lcd panel VES430UNDA-2D NI2
                    MAINBOARD 17MB110P 23397404
                    • yokoono
                      • Apr 2010
                      • 515
                      #1150
                      For me in the archive is mb110 not 110p. If you want you can try.
                      https://files.fm/u/ve6hh359y
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #1151
                        Thankyou i will give it a try is it best too remove the ic and programe it that way using a ch341a
                        Edit just downlaoded the file i tried to extract it says no archive is either unknown format or damaged i have tried downlaoding it twice
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #1152
                          Changed to a diffrent pc downloaded files ok if using a ch341a which files do add? i have never really used a ch341a before thanks
                          • yokoono
                            • Apr 2010
                            • 515
                            #1153
                            I checked. The archive is good. Use another unzipped or newer version. Installation is done from the stick not with CH341.
                            Do you know the installation procedure for Vestel electronics?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #1154
                              I picked two sets up yesterday for free both seem too have firmware issues, i have just ordered remotes for both sets so cant try the firmware until remote comes.
                              please can you explaine the update procedure step by step and i will give it ago i have 1gb and 2gb usb memory sticks so hope that will be ok. Thankyou for your help.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #1155
                                • yokoono
                                  • Apr 2010
                                  • 515
                                  #1156
                                  You need the remote control for installation. The installation is done with the OK key.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #1157
                                    Hopefully remote will come either today or tomorrow, what format do i need too wipe usb stick with and could you please tell me the procedure i will print if off for future refrence thanks.
                                    • yokoono
                                      • Apr 2010
                                      • 515
                                      #1158
                                      1. Format a stick with FAT32
                                      2. Unzip and put the 4 files directly on the stick
                                      3. Insert the stick into the TV
                                      4. Press and hold the OK key on the remote control
                                      5. Plug in the TV
                                      6. The TV's stby LED flashes slowly and then quickly. Now release the OK key
                                      7. Wait for it to finish. It may take 5-10 minutes.
                                      If after this operation the remote control is no longer useful, use a programmable one or a Vestel one.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #1159
                                        5. Plug in the TV
                                        Thank you i will try it once the remote arrives.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #1160
                                          Hi remote came and mainboard will not take the update at all i just get a brief flash of backlight at power on ( i do have a diffrent mainboard that uses the same panel the tv powers on and works ok) i cant keep this board in the set as is missing some ports like scart rca plugs extra hdmi port but board swap proves psu and backilights work fine so must be a fault on main bga ic i guess.
