Eeprom dump thread!
This is a sticky topic.
Re: Eeprom dump thread!
Try (Toshiba). Main 17MB211S panel VES315WNDB-2D-N21Attached FilesComment
Try this too. It is for 17MB211S panel VES315WNDS-2D-N21. If the image is returned I have the profile saved for fixing.Attached FilesComment
Yes, there are 3.3v on the chip (EEPROM). 12v and 5v are on the board as well.
The red light is on and blinking 2 short times in intervals.
Backlight is working OK.Comment
TV not turning ON. When you turn TV ON, RED light up and stay solid. When you push ON button, RED light blinks 2 times and stay solid. Then blinks 2 times again and stay solid. And does this all the time.
PS.: Backlight I checked with the mainboard from Panasonic TV. Backlight working, just can't turn ON the TV.Comment
Blaupunkt w40/58j-gb-fhcup-eu memory dump
Hello, i need memory dump for this tv. the mather board t.msd309.8b 10304 and panel lta400hm07. thanks.Comment
try this oneComment
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
by Ancient1Hi
I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
Right distribution board, 2 Flexs, near them:
The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
I... -
by jimhaHi ,
I'm looking for a dump to repair my screen
Thanks-
12-09-2024, 03:52 PM -
- Loading...
