Sharp Aquos LC-60LE830U One Long One Short
  • mmartell
    • Oct 2013
    • 3189
    I have the service manual, in fact more than one but I can't bypass the Lamp Error. The manual is cryptic as fuck and causing me to lose patience.
    I'm trying to do a little bit of troubleshooting before breaking in to test the leds. Even if I need to replace leds I think I'll still need to learn the reset so now is as good as ever. Suggestions ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Sharp Aquos LC-60LE830U One Long One Short
    This has the capacitive buttons, too. Makes it more difficult to know if you're actually "pressing" the button or not.
    • vinceroger69
      • Mar 2012
      • 6714
      This thread has the reset procedure in but as you say its hard too tell with capacitive buttons
      http://www.justanswer.com/tv-repair/...arp-aquos.html
      • mmartell
        • Oct 2013
        • 3189
        Thanks, can't get that to work either but will keep trying.
        • mmartell
          • Oct 2013
          • 3189
          Does anyone know what the led arrangement and quantity are in this unit ? It has four pairs of wires but i'd like to get an idea of the voltage I can throw at them. Nothing printed on the power supply.
            This is where LED tester comes in handy.
            May be the LCD panel spec sheet will tell you, what is the model number of the panel? It has four set of strings base on four drivers circuit I can see on the board.
            Panel is LK600D3GW30Z??? I cannot locate spec sheet for the panel.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              I think the led strips are 4 off E329419 with about 50 leds per strip
              http://alfa-electronique.com/product...0546&id_lang=1
              http://www.tvparcalari.com/index.php...2&tag=&page=89
              • mmartell
                • Oct 2013
                • 3189
                Hey thanks for those links. Will have a look shortly bjdm.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  What power supply does this tv have? DPS- ....
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    Also found this which may prove useful
                    http://www.fixya.com/support/t176177...cator_flashing
                    • mmartell
                      • Oct 2013
                      • 3189
                      Here's the panel and power supply model numbers
                      • R_J
                        • 9514
                        All I can add is this LCD Module manual
                          That is great info on the LCD panels.
                          • mmartell
                            • Oct 2013
                            • 3189
                            I bought one of those led backlight testers so this one's on hold until it arrives.
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              I got the 46LE830U with only 5V. Tried new mainboard , same situation. I already looked at the leds , visibly they look ok. They are as Dick Barton said , 4 strips.
                              Do you have any voltages at all on the PS? I only got 5V on the secondary side on the connector going to the mainboard and 340V / 13V on the primary side. I have no voltages on the driver circuit at all , can be a defective ic on the mainboard?
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                Hope this schematic can help
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  I get no voltages either but that's to be expected i think as the unit is stuck in the one short, one long mode.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Bought this... and verified all four strips light up.
                                    Going to force-on the supply to see if the driver circuit is functioning.
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      Saves time and effort in having to open up the panel to check the leds.
                                        $39 now? the price is slowly coming down.
