Sharp 70 - Delta DPS-222BP - 2 Long 3 Short
  • gette
    • Jun 2021
    • 5
    Hi...
    Very handy and tech newbie here trying to learn to fix my TV that died after a lighting strike
    SHARP LC-70LE732U
    Delta DPS-222BP
    Icon Flash 2 Long 3 Short
    Power PWB Failure
    Power supply error 2 (*2) D+3.3V error
    D_POW
    Digital 3.3V failure Flashes fast 3 times
    DET_D3V3 (33pin) failure (L). Digital 3.3V is not applied.
    If error is detected during start-up or operation, the power is turned on again by polling.
    Above is what manual states not what I confirmed, but would lie to but not sure how/where.
    I've been reading on here and watching YT videos off and on for months trying to learn what I can.
    Anyway I replaced the commonly recommend D7915 2x times now.
    Error Reset TV and still getting error.
    I am not sure where to go next to try to determine what seems to be causing it. I'd like to test the power and related components at certain points as the error specifically states what it is but I am not 100% where/how for this specifically.
    Caps "appear ok" no bulge or leaking, etc. I'd test what I can be seems may have to remove them to do so. So I am trying to narrow down as much as possible.
    Was hoping someone might have some suggestions on what to do/test next for this error:
    Power PWB Failure
    Short of that anyone is NJ/Philly/DE area that can diagnose and repair this.
    Thank you all in advance!
    Geo
    Happy Labor Day!
  • gette
    • Jun 2021
    • 5
    Re: Sharp 70 - Delta DPS-222BP - 2 Long 3 Short
    I ordered an DER DE-5000 ESR LCR meter so I can test the caps in circuit.
    But beyond that I am not sure how to go about to test the power voltages and at what point to narrow down the issue.
    Problem is I read and saw on YT that have to create a power switch and/or create a jumper and do all these songs and dances to get it fully powered up in order to test certain places.
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • SONY_E-WASTER
      Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
      by SONY_E-WASTER
      Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
      The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
      then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
      does...
      12-26-2021, 05:46 PM
    • cm0002
      Sharp LC-55N7000U 1 long 5 short blinking, no display
      by cm0002
      I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
      Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
      I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
      06-19-2023, 06:21 PM
    • Charrlie
      Sharp Lc-70le734u blinking 2 long 5 short
      by Charrlie
      Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
      So I busted into it and have done the following:
      -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
      07-07-2022, 02:02 PM
      MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
      This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
      09-07-2024, 03:40 AM
