Sharp LC-55N7000U 1 long 5 short blinking, no display
  • cm0002
    • Jan 2017
    • 16
    I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
    Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
    I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected, any ideas?
  • tech9pc
    • Sep 2021
    • 49
    Re: Sharp LC-55N7000U 1 long 5 short blinking, no display
    99 percent it's backlights. Do the flashlight test in the dark to see if you can see the Sharp Logo and the images on screen when booting up ... and have sound. That way you know it's bad leds and not something else like mainboard.
    Here's the LED replacement info.
    https://www.aliexpress.com/i/1005001638120251.html
    This is common with all Sharp / Hisense models. If backlights are left at 100 percent from factory sale. Only last 1 or 2 years. Replace and turn them down to 60 percent and last way longer and these tv's still have great picture.
    And there are ton's of good youtube videos on replacing backlights ... just search your model LC-55N7000U
    • Charrlie
      Sharp Lc-70le734u blinking 2 long 5 short
      by Charrlie
      Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
      So I busted into it and have done the following:
      -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
      07-07-2022, 02:02 PM
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • SONY_E-WASTER
      Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
      by SONY_E-WASTER
      Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
      The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
      then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
      does...
      12-26-2021, 05:46 PM
    • 08caine15
      HP 14s-cf0057TU caps lock blinking 3 long and 2 short
      by 08caine15
      Hi everyone , I need your help with this board and it's giving me a hard time . 3 long and 2 shorts base on HP site it's a MEMORY ERROR , tried replacing RAM it's still the same. RAM VOLTAGE has 1.2V i think it has a complete voltage a 3.3v and there's also ah 2v , tried checking pins if there any damage or unsoldered and everythings good , now I don't what should I do next. Also tried reflashing and programming the bios and still the same, hopefully there's someone who can help me with this since im having like 4 laptop with the same error.
      10-03-2024, 02:23 AM
    • gette
      Sharp 70 - Delta DPS-222BP - 2 Long 3 Short
      by gette
      Hi...
      Very handy and tech newbie here trying to learn to fix my TV that died after a lighting strike
      SHARP LC-70LE732U
      Delta DPS-222BP
      Icon Flash 2 Long 3 Short
      Power PWB Failure
      Power supply error 2 (*2) D+3.3V error
      D_POW
      Digital 3.3V failure Flashes fast 3 times
      DET_D3V3 (33pin) failure (L). Digital 3.3V is not applied.
      If error is detected during start-up or operation, the power is turned on again by polling.
      Above is what manual states not what I confirmed, but would lie to but not...
      09-06-2021, 11:33 AM
