Sharp Aquos LC-60LE830U One Long One Short
  • mmartell
    • Oct 2013
    • 3189
    I have the service manual, in fact more than one but I can't bypass the Lamp Error. The manual is cryptic as fuck and causing me to lose patience.
    I'm trying to do a little bit of troubleshooting before breaking in to test the leds. Even if I need to replace leds I think I'll still need to learn the reset so now is as good as ever. Suggestions ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Sharp Aquos LC-60LE830U One Long One Short
    This has the capacitive buttons, too. Makes it more difficult to know if you're actually "pressing" the button or not.
    • vinceroger69
      • Mar 2012
      • 6714
      This thread has the reset procedure in but as you say its hard too tell with capacitive buttons
      http://www.justanswer.com/tv-repair/...arp-aquos.html
      • mmartell
        • Oct 2013
        • 3189
        Thanks, can't get that to work either but will keep trying.
        • mmartell
          • Oct 2013
          • 3189
          Does anyone know what the led arrangement and quantity are in this unit ? It has four pairs of wires but i'd like to get an idea of the voltage I can throw at them. Nothing printed on the power supply.
            This is where LED tester comes in handy.
            May be the LCD panel spec sheet will tell you, what is the model number of the panel? It has four set of strings base on four drivers circuit I can see on the board.
            Panel is LK600D3GW30Z??? I cannot locate spec sheet for the panel.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              I think the led strips are 4 off E329419 with about 50 leds per strip
              http://alfa-electronique.com/product...0546&id_lang=1
              http://www.tvparcalari.com/index.php...2&tag=&page=89
              • mmartell
                • Oct 2013
                • 3189
                Hey thanks for those links. Will have a look shortly bjdm.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  What power supply does this tv have? DPS- ....
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Also found this which may prove useful
                    http://www.fixya.com/support/t176177...cator_flashing
                    • mmartell
                      • Oct 2013
                      • 3189
                      Here's the panel and power supply model numbers
                      • R_J
                        • 9624
                        All I can add is this LCD Module manual
                          That is great info on the LCD panels.
                          • mmartell
                            • Oct 2013
                            • 3189
                            I bought one of those led backlight testers so this one's on hold until it arrives.
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              I got the 46LE830U with only 5V. Tried new mainboard , same situation. I already looked at the leds , visibly they look ok. They are as Dick Barton said , 4 strips.
                              Do you have any voltages at all on the PS? I only got 5V on the secondary side on the connector going to the mainboard and 340V / 13V on the primary side. I have no voltages on the driver circuit at all , can be a defective ic on the mainboard?
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Hope this schematic can help
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  I get no voltages either but that's to be expected i think as the unit is stuck in the one short, one long mode.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Bought this... and verified all four strips light up.
                                    Going to force-on the supply to see if the driver circuit is functioning.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      Saves time and effort in having to open up the panel to check the leds.
                                        $39 now? the price is slowly coming down.
                                        • FlorianP
                                          Sharp Aquos LC-40LE810E - 2 long, 1 short
                                          by FlorianP
                                          First of all I am not native English speaking, so sorry for potential mistakes or misunderstanding.
                                          I have a basic multimeter and a soldering iron. No electronic pieces for replacement for the moment, but I can buy some.
                                          I have a Sharp Aquos LC-40LE810E with issue.
                                          When I turn on my TV with the remote control, I have 2 long flashing on the boomerang symbol, and no image/no sound.
                                          I saw in the service manual that I need to click on « menu » button of the remote control to have more information.
                                          --> Error core...
                                          09-05-2020, 10:02 AM
                                        • SONY_E-WASTER
                                          Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                          by SONY_E-WASTER
                                          Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                          The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                          then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                          does...
                                          12-26-2021, 05:46 PM
                                        • cm0002
                                          Sharp LC-55N7000U 1 long 5 short blinking, no display
                                          by cm0002
                                          I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
                                          Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
                                          I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
                                          06-19-2023, 06:21 PM
                                        • Charrlie
                                          Sharp Lc-70le734u blinking 2 long 5 short
                                          by Charrlie
                                          Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
                                          So I busted into it and have done the following:
                                          -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
                                          07-07-2022, 02:02 PM
                                        • gette
                                          Sharp 70 - Delta DPS-222BP - 2 Long 3 Short
                                          by gette
                                          Hi...
                                          Very handy and tech newbie here trying to learn to fix my TV that died after a lighting strike
                                          SHARP LC-70LE732U
                                          Delta DPS-222BP
                                          Icon Flash 2 Long 3 Short
                                          Power PWB Failure
                                          Power supply error 2 (*2) D+3.3V error
                                          D_POW
                                          Digital 3.3V failure Flashes fast 3 times
                                          DET_D3V3 (33pin) failure (L). Digital 3.3V is not applied.
                                          If error is detected during start-up or operation, the power is turned on again by polling.
                                          Above is what manual states not what I confirmed, but would lie to but not...
                                          09-06-2021, 11:33 AM
