Sharp Lc-70le734u blinking 2 long 5 short
  • Charrlie
    • Jul 2022
    Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
    So I busted into it and have done the following:
    -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such
    -Disconnected each plug/ribbon on the Tcon one by one, no change.
    Few tv specialists pointed me towards the main board being the issue. Any thoughts?
    (Also Have not multi metered anything, assuming that is the next logical step)
    Any help is appreciated, I'm somewhat mechanically inclined but also in no man's land here 😆
  • nomoresonys
    • 12306
    • U.S.
    Re: Sharp Lc-70le734u blinking 2 long 5 short
    check the solder joints, then test the connector, demo there: https://www.youtube.com/watch?v=XH9GfkGQX1I
    • thommyX
      • Apr 2016
      • 95
      Check
      Q7902 HIT667
      D7918 SB5200
      Q7120 KIA378R12PI
      IC7905 STR-A6069H
      D7908 P6KE150
      R7918 0,22 Ohm
      Thomas
      • nomoresonys
        • 12306
        • U.S.
        yep, probably Q7120 KIA378R12PI.
        • Diah
          • Feb 2013
          • 6462
          you need to search here we were dealing with sharp. first and the most important testing power boards als stand alone.. and there was listed too.. when you are sure PSU ok and BL ok no way to check parts.. its time to replace boards.
          • cm0002
            Sharp LC-55N7000U 1 long 5 short blinking, no display
            by cm0002
            I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
            Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
            I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
            06-19-2023, 06:21 PM
          • Superbee_dad
            Sharp 80” long short flash backlight error - Help
            by Superbee_dad
            Hello Sharp TV experts
            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
            01-24-2025, 11:51 PM
          • SONY_E-WASTER
            Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
            by SONY_E-WASTER
            Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
            The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
            then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
            does...
            12-26-2021, 05:46 PM
          • 08caine15
            HP 14s-cf0057TU caps lock blinking 3 long and 2 short
            by 08caine15
            Hi everyone , I need your help with this board and it's giving me a hard time . 3 long and 2 shorts base on HP site it's a MEMORY ERROR , tried replacing RAM it's still the same. RAM VOLTAGE has 1.2V i think it has a complete voltage a 3.3v and there's also ah 2v , tried checking pins if there any damage or unsoldered and everythings good , now I don't what should I do next. Also tried reflashing and programming the bios and still the same, hopefully there's someone who can help me with this since im having like 4 laptop with the same error.
            10-03-2024, 02:23 AM
          • gette
            Sharp 70 - Delta DPS-222BP - 2 Long 3 Short
            by gette
            Hi...
            Very handy and tech newbie here trying to learn to fix my TV that died after a lighting strike
            SHARP LC-70LE732U
            Delta DPS-222BP
            Icon Flash 2 Long 3 Short
            Power PWB Failure
            Power supply error 2 (*2) D+3.3V error
            D_POW
            Digital 3.3V failure Flashes fast 3 times
            DET_D3V3 (33pin) failure (L). Digital 3.3V is not applied.
            If error is detected during start-up or operation, the power is turned on again by polling.
            Above is what manual states not what I confirmed, but would lie to but not...
            09-06-2021, 11:33 AM
