Sharp Aquos LC-60LE830U One Long One Short
  • mmartell
    • Oct 2013
    • 3189
    Re: Sharp Aquos LC-60LE830U One Long One Short
    Originally posted by budm
    $39 now? the price is slowly coming down.
    Yessir. And not from China either, California. Was wondering about something though...
    Many edge lit led strips are actually two equal strips in parallel. If a single led opened in a strip (or in my case all four strips) would that cause a properly functioning power supply to shut down the backlight ? Because that creates the scenario where the backlight tester says "ok" but in reality they're not. This unit reported 108v for each of my strips. Shouldn't it be testing for current draw as well so the user can compare with the readings from other strips inside the panel since they can't really be seen ?
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      That's an interesting senario. The unit provides a variable voltage at what I believe is at a constant current. So I reckon testing a led string with one or more short circuited leds would display a lower voltage on the tester display.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Out of curiosity I have just checked mine. I put my multimeter in series with the positive terminal output probe and have the following results when testing.
        Shorting the probes together, current = 29mA
        Testing 1 Led, current = 29mA
        Testing sting of 6 leds, current = 29mA
        So it look as though the current is a constant and it's the voltage that changes.
        • mmartell
          • Oct 2013
          • 3189
          So it would be wise to compare the voltage readings if you have more than one strip. At least that will tell you if you have any shorted leds which may not be apparent with the screen intact.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            You could use that method but the only problem is that I noticed that some led strips have more leds than in the next/previous strip in the row.
            Looking at a Youtube video of a led repair yesterday which had 8 leds in one row 9 in the next, then 8, then 9. Was odd.
            Edit
            As a quick and cheerful way of testing the leds I think it does what it says even if it can't handle all posibile errors you may encounter. You'll gain that with experience in using it.
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              #26
              Just curious. Does the V led turn on for a while and then goes to the 2 blinks? Mine does that. It turns on and the white "V" led lights up...takes like 10 seconds and it then shuts off with the same blinks. Backlight does not turn on.
                Once you get that LED tester, one good thing is that Built-in Voltmeter to show the Vf (Forward Voltage) of the LED.
                I.E.
                You have two strips of LED, each strip has 4 LED.
                When you connect the tester to one of the two strip you get the reading of 12V, but when testing the other strip you get 9V, it means that the one with 9V reading has one shorted out LED.
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  #28
                  My thoughts were as an example if you were testing one led strip with 7 leds and a second strip with 8 leds but you are unaware of the number of leds per strip because you have not opened up the panel, then the voltage reading could mislead you.
                    That is true if the the strips are not the same.
                    So the bad thing is that if you have one big string with 2~3 shorted out LEDS, the string will still light up using the tester but the LED driver circuit may go into over current shutdown due to shorted LEDs which is the condition I run into before. There is no way to be 100% sure unless you can actually get to the LED strips.
                    • mmartell
                      • Oct 2013
                      • 3189
                      No, mine starts with the error blink right away.
                      • mmartell
                        • Oct 2013
                        • 3189
                        Exactly this. In my case it seems these leds are wired such that half of a horizontal strip is in series with half of the adjacent vertical strip such that a corner at a time will light per pair of wires coming off the driver.
                        So that's 50/2 + 30/2 or 37 leds. My tester reads a voltage of 108v per string or 36 leds at 3v each. I could have one shorted led per string but impossible to know without Vf for these particular leds and it would probably be a coincidence to have one led shorted per string anyway.
                        Would 12v missing out of 444v be enough to trip the protection anyway ?
                        On a more practical note what pins need jumpered to force on this supply ? I know standby with pson but I'm not familiar with some of the other Sharp designations.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          #32
                          It took me 3 mainboards to turn this tv on! Other 2 mainboard the V led starts blinking right from the start and i only had 5V on the powerboard.
                          With this 3rd mainboard the tv turns "on" but i got bad led strips i think. Check my thread , it has pictures.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Well I can put this one to bed.
                            After reading another Sharp thread here yesterday the poster implied to power on the set by plugging it in THEN push and hold the power/input/vol- buttons - so I did. After a few seconds the "V" stopped flashing and went solid, followed by a soft power supply "click" and the screen lit up with a "k" on the left hand side. Then a ch-/vol+ (or was it ch-/vol- ?) and the service menu was on the screen. I grabbed the remote and reset the Lamp Error by turning it to "On" then powered the set off with the remote and unplugged it. Been coming on normally ever since even after cycling the mains several times.
                            I will add that the capacitive button board nearly fell out of its slot so who knows if it was even pushed up tight against the bezel during my previous attempts. Will fix that before I button it up.
                            • FlorianP
                              Sharp Aquos LC-40LE810E - 2 long, 1 short
                              by FlorianP
                              First of all I am not native English speaking, so sorry for potential mistakes or misunderstanding.
                              I have a basic multimeter and a soldering iron. No electronic pieces for replacement for the moment, but I can buy some.
                              I have a Sharp Aquos LC-40LE810E with issue.
                              When I turn on my TV with the remote control, I have 2 long flashing on the boomerang symbol, and no image/no sound.
                              I saw in the service manual that I need to click on ยซ menu ยป button of the remote control to have more information.
                              --> Error core...
                              09-05-2020, 10:02 AM
                            • SONY_E-WASTER
                              Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                              by SONY_E-WASTER
                              Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                              The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                              then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                              does...
                              12-26-2021, 05:46 PM
                            • cm0002
                              Sharp LC-55N7000U 1 long 5 short blinking, no display
                              by cm0002
                              I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
                              Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
                              I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
                              06-19-2023, 06:21 PM
                            • gette
                              Sharp 70 - Delta DPS-222BP - 2 Long 3 Short
                              by gette
                              Hi...
                              Very handy and tech newbie here trying to learn to fix my TV that died after a lighting strike
                              SHARP LC-70LE732U
                              Delta DPS-222BP
                              Icon Flash 2 Long 3 Short
                              Power PWB Failure
                              Power supply error 2 (*2) D+3.3V error
                              D_POW
                              Digital 3.3V failure Flashes fast 3 times
                              DET_D3V3 (33pin) failure (L). Digital 3.3V is not applied.
                              If error is detected during start-up or operation, the power is turned on again by polling.
                              Above is what manual states not what I confirmed, but would lie to but not...
                              09-06-2021, 11:33 AM
                            • Charrlie
                              Sharp Lc-70le734u blinking 2 long 5 short
                              by Charrlie
                              Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
                              So I busted into it and have done the following:
                              -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
                              07-07-2022, 02:02 PM
