Toshiba 42rv530u wont power on
Re: Toshiba 42rv530u wont power on
I see from sj pictures the cap does not use a plastic cap so if it's bulged it needs replacing
This digikey link should get you close, then measure it and the lead spacing
https://www.digikey.com/products/en/...=1&pageSize=25Last edited by R_J; 05-28-2018, 09:39 PM.Comment
If you go to harbor freight, it's the cen-tech 11 function $21.99, usually some coupons at their site and in mailers they send out.Comment
Taking that 450VDC cap is the LAST thing you will want to do.
1) We have not seen the pictures of YOUR board yet. Your Power supply board P/N????
2) What Voltages do you have on the connectors on the cold side of the power supply.
3) Is the TV plugged into the GFCI out let at this point?
4) Which meter are you using right now? Did you figure out yet how to set the meter properly to read Ohm, DC Voltage, AC Voltage?
5) I am really CONCERNED about you getting electrocuted!Last edited by budm; 05-28-2018, 08:29 PM.Never stop learning
Just be careful to only touch the legs with the meter leads, keep your hands away.Comment
Wouldn't be my first suggestion either, he thought it was bulging, so what do you do with a bulging cap, you replace it VERY CAREFULLY.Comment
Is this your board? if so it's going to be a little harder checking voltage on the big cap, because the cap is upright and not lying on it's side.
http://www.shopjimmy.com/toshiba-750...upply-unit.htmLast edited by nomoresonys; 05-28-2018, 08:51 PM.Comment
If this is the board it is very easy to measure the voltage on that cap. See location C821....
Regarding C820, The cap on this board does not have the plastic cap, so if it IS bulged then it should be replaced.
This what I was referring to regarding the bulged plastic top: http://audiokarma.org/forums/index.p...citors.421456/
This happens a lot, and the cap. is fineLast edited by R_J; 05-28-2018, 09:10 PM.Comment
I was actually reading the meter right, I incorrectly assumed that the reading would be close to the uf on the capacitor. I guess I misunderstood. It actually just kept going up infinitly like a good capacitor should.
Currently trying to upload pictures. My board is the PE0546A version.
I feel bad about worrying you never my intention, I am so grateful for everyone too. I will try to get back to this board later in the week. I bet it's that switch. NEVER plugging anything in while I have the top off unless I know I'm safe.Comment
Yes... I want to learn, but not waste people's time. I am not very good at board troubleshooting. My Grandma was, she used to work on stuff like this back in the day. Old IBM stuff that was real big. I just want to try and find a board that is compatible and won't go haywire on me too.Comment
http://www.shopjimmy.com/toshiba-750...upply-unit.htmLast edited by Heavyarms92; 05-28-2018, 09:28 PM.Comment
This happens a lot, and the cap. is fineComment
The only thing poped on those in the link is the plastic, the caps are fine. But some caps don't use that plastic, Then if you see the bare aluminum bulged they are bad
Now post pictures of your board so we can HELP YOULast edited by R_J; 05-28-2018, 09:45 PM.Comment
Maybe I should have started out with pictures. I gurssI have been assuming too much lately. This TV used about 3-4 boards in its lifetime. I'm not gonna lie I am seriously thinking about replacing mine but I wanna try a and figure that relay out SR81 I believe. I feel like I've caused a few headaches believe me that was not what I set out to do here. I blame Tampatec he makes it look too easy.Comment
I done did, they are on 90. It won't let me upload from my gallery , and I already buttoned her up for the night sorry.
Maybe I should have started out with pictures. I gurssI have been assuming too much lately. This TV used about 3-4 boards in its lifetime. I'm not gonna lie I am seriously thinking about replacing mine but I wanna try a and figure that relay out SR81 I believe. I feel like I've caused a few headaches believe me that was not what I set out to do here. I blame Tampatec he makes it look too easy.Last edited by nomoresonys; 05-29-2018, 04:30 AM.Comment
We should have started with the basics, that's checking voltages at the powersupply connector/s, p860, p810A and P811A, check the second video below, has a demo.Last edited by nomoresonys; 05-29-2018, 03:57 AM.Comment
When you're comfortable with your meter, measure the voltages on those connectors, will be with meter set to 20 vdc, in this case negative lead is to groung/tv chassis is ok and red lead to pin, will test with tv plugged in, will take reading with tv in standby which is just plugged in, then hit power on and see if anything changes on the meter and report both conditions, need description of pin and expected voltage, here's an example of how to report it:
CNxxxx
1/2 - UD: 14V=14v standby, 14v tv on
3/4 - PWM_BLU: 14V=14v stby, 14v tv on
5/6 - PS_ON: 14V=0v stby, 14v tv on.
7/8 - GND: 15V
9/10 - GND: 0V something to that effect.Last edited by nomoresonys; 05-29-2018, 04:55 AM.Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by beetle1303I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...3 Photos-
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
