Toshiba 42rv530u wont power on
  • Heavyarms92
    • May 2018
    • 62
    Re: Toshiba 42rv530u wont power on
    Looks like your tv was made in 2008, you very well may need some new caps.
    Yes, that's very likely I'm just not sure how to take the 450 uf out with the extra petals in place.
    • R_J
      • 9625
      I see from sj pictures the cap does not use a plastic cap so if it's bulged it needs replacing
      This digikey link should get you close, then measure it and the lead spacing
      https://www.digikey.com/products/en/...=1&pageSize=25
        • 12331
        • U.S.
        #83
        If you go to harbor freight, it's the cen-tech 11 function $21.99, usually some coupons at their site and in mailers they send out.
          Taking that 450VDC cap is the LAST thing you will want to do.
          1) We have not seen the pictures of YOUR board yet. Your Power supply board P/N????
          2) What Voltages do you have on the connectors on the cold side of the power supply.
          3) Is the TV plugged into the GFCI out let at this point?
          4) Which meter are you using right now? Did you figure out yet how to set the meter properly to read Ohm, DC Voltage, AC Voltage?
          5) I am really CONCERNED about you getting electrocuted!
            • 12331
            • U.S.
            #85
            Just be careful to only touch the legs with the meter leads, keep your hands away.
              • 12331
              • U.S.
              #86
              Wouldn't be my first suggestion either, he thought it was bulging, so what do you do with a bulging cap, you replace it VERY CAREFULLY.
                • 12331
                • U.S.
                #87
                Is this your board? if so it's going to be a little harder checking voltage on the big cap, because the cap is upright and not lying on it's side.
                http://www.shopjimmy.com/toshiba-750...upply-unit.htm
                  • 12331
                  • U.S.
                  #88
                  Might be faster and easier to just buy that board.
                  • R_J
                    • 9625
                    If this is the board it is very easy to measure the voltage on that cap. See location C821....
                    Regarding C820, The cap on this board does not have the plastic cap, so if it IS bulged then it should be replaced.
                    This what I was referring to regarding the bulged plastic top: http://audiokarma.org/forums/index.p...citors.421456/
                    This happens a lot, and the cap. is fine
                    • Heavyarms92
                      • May 2018
                      • 62
                      Whoa, I didn't plug anything in, no one told me to. Sorry for making you worry not my intention. I've been reading and double checking that manual and feeling like an idiot. I'm going to hang it up for now though, it's gonna be a long week at work.
                      I was actually reading the meter right, I incorrectly assumed that the reading would be close to the uf on the capacitor. I guess I misunderstood. It actually just kept going up infinitly like a good capacitor should.
                      Currently trying to upload pictures. My board is the PE0546A version.
                      I feel bad about worrying you never my intention, I am so grateful for everyone too. I will try to get back to this board later in the week. I bet it's that switch. NEVER plugging anything in while I have the top off unless I know I'm safe.
                      • Heavyarms92
                        • May 2018
                        • 62
                        Yes... I want to learn, but not waste people's time. I am not very good at board troubleshooting. My Grandma was, she used to work on stuff like this back in the day. Old IBM stuff that was real big. I just want to try and find a board that is compatible and won't go haywire on me too.
                        • Heavyarms92
                          • May 2018
                          • 62
                          That's the one, I just uploaded pictures. See post 90 plz.
                          • Heavyarms92
                            • May 2018
                            • 62
                            Dang those are popped! Mine does not look like that.
                            • R_J
                              • 9625
                              The only thing poped on those in the link is the plastic, the caps are fine. But some caps don't use that plastic, Then if you see the bare aluminum bulged they are bad
                              Now post pictures of your board so we can HELP YOU
                              • Heavyarms92
                                • May 2018
                                • 62
                                I done did, they are on 90. It won't let me upload from my gallery , and I already buttoned her up for the night sorry.
                                Maybe I should have started out with pictures. I gurssI have been assuming too much lately. This TV used about 3-4 boards in its lifetime. I'm not gonna lie I am seriously thinking about replacing mine but I wanna try a and figure that relay out SR81 I believe. I feel like I've caused a few headaches believe me that was not what I set out to do here. I blame Tampatec he makes it look too easy.
                                  • 12331
                                  • U.S.
                                  #96
                                  Was referring to C820 NOT 821.
                                    • 12331
                                    • U.S.
                                    #97
                                    Not a problem, a lot of us are here to help if we can and learn.
                                      • 12331
                                      • U.S.
                                      #98
                                      We should have started with the basics, that's checking voltages at the powersupply connector/s, p860, p810A and P811A, check the second video below, has a demo.
                                        • 12331
                                        • U.S.
                                        #99
                                        When you're comfortable with your meter, measure the voltages on those connectors, will be with meter set to 20 vdc, in this case negative lead is to groung/tv chassis is ok and red lead to pin, will test with tv plugged in, will take reading with tv in standby which is just plugged in, then hit power on and see if anything changes on the meter and report both conditions, need description of pin and expected voltage, here's an example of how to report it:
                                        CNxxxx
                                        1/2 - UD: 14V=14v standby, 14v tv on
                                        3/4 - PWM_BLU: 14V=14v stby, 14v tv on
                                        5/6 - PS_ON: 14V=0v stby, 14v tv on.
                                        7/8 - GND: 15V
                                        9/10 - GND: 0V something to that effect.
                                        • R_J
                                          • 9625
                                          NO, I ment C821 The board location is not populated but the rivits and contact to the trace is there, and that cap is in parrallel to C820, So the voltage can be tested from above.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
