Emerson LC401EM2F no standby light or power
  • bman4
    • Jul 2015
    • 210
    • canada
    #61
    Re: Emerson LC401EM2F no standby light or power
    Backnlught circut only.gets 12v instead of 24v
    Main votages are good and stable. No shorts on blacklight.
    • bman4
      • Jul 2015
      • 210
      • canada
      #62
      Replace the optos with random ones without looking at data sheets . the 817c opto is from a 12v power supply and maybe this is why it only gets 12v now .
      The 817c failed in place of the tlp781. Im just gonna have to order some proper ones.
      • bman4
        • Jul 2015
        • 210
        • canada
        #63
        I got the new optos in today. The 3 others are getting a beep on cold side now . the top one of the two top left ones is not getting a beep.When i first replaced them with random ones the tv stby came one solid red. since the new optos its flashing as soon as i turn on the tv still .i let it sit in srby and now the protect relay is staying on. the back light is getting 14 v out of 24. On the two 12n60 the one that did not fail is shorted on 2 back pins on the board Witch leads to the ic .possibly the ic is bad. The output to the one that failed is not shorted but is to the second. Gonna order some ic's now. I isolated everything back to the ic so its the culprit now. I dont know if i.did something to cause this or it was already like this .
        • CapLeaker
          Leaking Member
          • 8351
          If there is a short to the gate of a Mosfet, then you have to check that gate drive circuit too. And don't change things with "random" parts from the junk bin. At least pull the datasheet and see if it is similar to the old stuff you took out.
          Fix what you know isn't right with the correct parts. Then make yourself a "series light bulb trick" seen here: https://www.badcaps.net/forum/showthread.php?t=32748, plug the PSU into that and then fire it up. Other wise you may need a lot of more parts. Good Luck!
          • bman4
            • Jul 2015
            • 210
            • canada
            #65
            the new12n60c mosfet 2 is not shorted but the ic on the back of board. It's odd that this pin failed on the ic when the one that is for the orginal shorted mosfet 1 didnt. Maybee the opto corelates with the mosfet 2 and that is why im getting half volts . the high voltage cap was getting proper vloltage.Here of some pics of the power supply with the parts circled. thought i checked all directions on the mosfets for shorts,I guess ill chalk it up to a rookie move.
            • CapLeaker
              Leaking Member
              • 8351
              so how much voltage did you get on the main filter capacitor?
              These Emerson PSU's aren't that easy to fix. They blow not one component, but more like a dozen. There could be still blown zeners, open or gone high in value resistors too.
              • bman4
                • Jul 2015
                • 210
                • canada
                #67
                168v and its a 400v cap so im guessing only half of it was working like i thought.I was only getting 168v while pressing power. Someone mentioned 168v is good so i dont know . i tested all diodes to be good . tested the through hole resistors that have mutiples to compare for the circut of the ic . The smd resistors that correlate with the ic where not open or shorted. the smd resistors are hard for my eyes to read them but realized i could get a clear picture. 223 = 22.16. 69c =50.2, 000=0.2, 124=120.1, 562= 5.55, 473=46.2, 222= 2.15, 510=32.45, 438=2.744, some seem like they match numbers within 10% but learned that the number don't allways match. R1605 and lifted one match and read 5.0. R1436=17.22 r1424=100.3. Im shure if i repalce this ic it will work. I think This psu looks minimal in parts to compared to plasmas. My first voltage post was wrong, had my meter on wrong. Thank you for your feed back have a great day!
                  • 12328
                  • U.S.
                  #68
                  168 is good in standby, should go up to around 400 when hit power on, be careful 400 volts is a shit-ton of volts.
                  • CapLeaker
                    Leaking Member
                    • 8351
                    so the pfc isn't working. No PFC = No 24V.
                    • bman4
                      • Jul 2015
                      • 210
                      • canada
                      #70
                      Got the ics in and it and q1602 failed no short on ic or 1601. Tried it a second time with new ic and new q1601, q1602 .Q1602 shorted and the ic didnt again. I tested the pins on pcb before i installed them and there was no shorts both matched ohm reading. There was stby light.
                      • CapLeaker
                        Leaking Member
                        • 8351
                        read my post #64 again.
                        • bman4
                          • Jul 2015
                          • 210
                          • canada
                          #72
                          do i put the lamp in series on the mains input on hot or neutral. i forgot to resolder a throght hole resistor r1606. I resoldered this resistor replace q1602 & ic and now it dose not blow the fuse or arc . Wow to think one through hole.ristor could.cause.that much chaos! stby light is blinking with the back light and i get a pic now. it cuts out after stby blink and repeats when power button is pressed. Tested all optos and they are all getting signal.zener diode d1605 is shorted but i think i lifted it before andnit tested good.
                          • bman4
                            • Jul 2015
                            • 210
                            • canada
                            #73
                            That zener diode is shorted but what value do i replace it with. I see some zeners read like a schottky diode. I see a 2 horizontal then a vertical 2/ symbol in pic? it almost impossible to read.
                            • bman4
                              • Jul 2015
                              • 210
                              • canada
                              #74
                              12n60 gate voltage is 2.7v. The Size of zener is small. Im guesiing 2.7v 1/2 w zener diode.
                              • bman4
                                • Jul 2015
                                • 210
                                • canada
                                #75
                                The zener on the other transistor reads 0.620
                                • bman4
                                  • Jul 2015
                                  • 210
                                  • canada
                                  #76
                                  I threw in a zener diode that read 0.600 from a 12v power supply lwith what i just discoverd has a 2n60c.
                                  Its up and running. Gonna to test for 24h
                                  • CapLeaker
                                    Leaking Member
                                    • 8351
                                    sweet
                                    • AleMonti
                                      LG 55EG910V - no power and no standby light
                                      by AleMonti
                                      I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                      I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                      The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                      After checking the basics I did the following:
                                      • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                      11-04-2024, 05:02 PM
                                    • SkishyIshy
                                      Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                      by SkishyIshy
                                      Hey All,
                                      I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                      I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                      I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                      03-17-2021, 11:44 AM
                                    • noinimod
                                      Sony 55X900E no standby light, no power. Replaced mainboard already
                                      by noinimod
                                      No standby red light, nothing
                                      This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                      Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                      At a few pins I can see the power supply providing 19.5V to the main board
                                      Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                      LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                      12-22-2021, 12:58 AM
                                    • lapfix
                                      HP OMEN NO power no light
                                      by lapfix
                                      HP OMEN : DAG35DMBAD0
                                      NO power ,no short ,no corrusion
                                      Consumption : when charger plg in = 0.004 amp
                                      Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                                      when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                                      No light at power button led
                                      All coils resistances :
                                      Pl 2001 =3v measured with kohm.
                                      pl 2004 = 5v measured with kohm
                                      pl 6001 = 49.7ohm
                                      pl 4012 = vccsa = 24.4 ohm
                                      pl 3001 =...
                                      11-03-2025, 07:48 AM
                                    • x_orange90_x
                                      Vizio E550i-A0 no power, no standby light
                                      by x_orange90_x
                                      I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                      11-20-2023, 09:49 AM
