Emerson LC401EM2F no standby light or power
  • Beef_Ramen
    • May 2016
    • 22
    • US
    #41
    Re: Emerson LC401EM2F no standby light or power
    Check what voltage you get on pin 4 (VCC) of that IC.
    I know this sounds bad but where do I put the negative probe when checking pin 4?
    Originally posted by budm
    So just to be sure, you do not have the DCV at ALL+4.3V jumper for sure?
    Correct I do not have voltage when testing the ALL +4.3V black ribbon connector piece.
      "I know this sounds bad but where do I put the negative probe when checking pin 4?"
      The black probe goes to the negative leg of the main filter cap. When you working in the dc primary side of the circuit, the negative leg of the main filter cap is the GND REF. for the meter, in the cold side of the circuit, the chassis is the GND REF. for the meter.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8351
        What bud m said above or my post #8.
        • Beef_Ramen
          • May 2016
          • 22
          • US
          #44
          Thanks for that, still learning even basic things like this.
          Anyway with the negative black probe on the negative lead of the main capacitor, and positive probe on pin 4 of that IC, it's reading out -55DCV
            Are you sure you have the meter set correctly and using the right cap, the cap that you measured 160VDC (the filter cap for the standby power supply)?
            • Beef_Ramen
              • May 2016
              • 22
              • US
              #46
              You were right, sorry about that, ok so black probe on C1201 negative lead and red probe on pin 4, I'm getting 63DCV~
              • Beef_Ramen
                • May 2016
                • 22
                • US
                #47
                Anything else I should try?
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8351
                  post DC V measurements from all the pins from that IC. You may have to replace C1204. What is written on C1204? Check D1206 and D1207 and replace that IC. Kinda high voltage having 63V on a IC that should have max 45V.
                  • bman4
                    • Jul 2015
                    • 210
                    • canada
                    #49
                    I have this psu from a emmerson im working on. It has a blown main fuse and seeing some dead shorts on sot-220s an diodes. Removed the doubble diode sot220 near the inverter d1721 tested good. Im getting 0.0 ohm then starts charging a cap on d1721. I have yet to power on the psu and test.volts because fuse . the mip ic1201 is not shorted.testing sot220 q1062 & q1601 right now but lcr enter self.test mode. Just tested q1602 to be bad but q1601 good!
                    Q1601 is a fairchild k8a50d 500v 8a n channel feild effect transistor.
                    Back to testing ,
                    Bman4
                    • bman4
                      • Jul 2015
                      • 210
                      • canada
                      #50
                      Im measuring Schottky Barrier Rectifier diode 662 by cold section yelllow trans former With vf of 0.200 and others under . d656 reads 0.387. I think Schottky Barrier Rectifier diode are not supposed to be below 0.3v
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8351
                        a schottky diode should have a low voltage drop. So 0.2V drop is normal on these. If you in doubt, lift a leg, measure the voltage drop and compare it to the spec sheet. You do not want to see a total short on a diode, that's bad. Since there is a FET blown, I am pretty sure that there is more wrong with this PSU. Usually there are some shorted diodes, bad resistors that are either open or gone high in value, blown zener diodes etc.
                        You can have a look here in what you might be in of: https://www.badcaps.net/forum/showth...hlight=emerson
                        • bman4
                          • Jul 2015
                          • 210
                          • canada
                          #52
                          they all tested 0.2+ but one small d670 reads 170.i was told there was a.voltage spike and the mains voltages are 125 .im hopeing it just took the one out and not the ic . i have one rjk6026 that is 600v but feel like its wrong to use 2 difrent parts . would it be a good idea to use orginals or the. Rjk6026 . i have 2pg011 but reads one less diode on my lcr. I fixed a 50u50 with just one part on ss and hope its that easy again.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8351
                            no, you don't need to put in the original part. You can sub it, if you want, as long as the specs are close. THe 2pg011 is a IGBT, so forget about that. The RJK6026 has a better voltage rating, but the current rating is only half of the original and RDSon is way too high. Look for something like a 10N50 or a 12N60 TO-220-3 full pack and jam that in there. Tons of manufacturers make that FET. I think the origninal was a TK10A50D.
                            • bman4
                              • Jul 2015
                              • 210
                              • canada
                              #54
                              you saved me alot of time looking for a better sub. I will report back when i test the improvisions with the fairchild 12n60. Finally just getting to know diffrent packages.i quickly thought 2pg011 because its 600v.just starting to think more clearly after being sick.
                              Thank you,
                              Bman4
                              • bman4
                                • Jul 2015
                                • 210
                                • canada
                                #55
                                I installed the parts and i get a stand by light that flashed till relay shut down gotta test voltage but its getting stby tested 168.at tye filter caps . l tested ony 5v at pin 4 on bottom if thats the direction it counts. on ic1201 top 3rd pin reads 133.9 second pin reads - 315. First reads -125. When i was testing for groud chassis to filter cap gound i was getting a pulsating 0v. Fuseable resistors test fine. Maybee that ic. I get voltages allover to bcklight inverter. Hard to test main volages because they are covered by by the cable and no easily acessable test points. Gonna a get back to it tommrow.
                                  When you make Voltage measurement in the hot side circuit, you need to use the negative leg of the hot side main filter cap as the GND ref. for your meter, not chassis GND. that is why your readings are invalid right now.
                                  • bman4
                                    • Jul 2015
                                    • 210
                                    • canada
                                    #57
                                    Apologize about the bad grammar in the last post. It was long night and posted that b4 i went to sleep!
                                    I did , wanted to see if Main filter cap was to chassis ground because it was hard to keep position.
                                    I gor a flickering 0000 from main cap ground to chassis when i forgot to switch to continuity.
                                    Ill have to look up data sheet and find out if pic ic 1201 pins are counted to the right on the bottom 4 pins
                                    Filter cap: 168v
                                    Ic1201
                                    Top pin 1 : minus 125
                                    Top pin 2 : minus 315
                                    Top pin 3 : 133.9v
                                    Bottom pin 4 : 5v
                                    Baclight inverter shoots up to 125 going up and down.
                                    Top 1:Tuner 35 volt top pin rises.
                                    Pin 2 : The 12v for main is stable .
                                    Pin 6:P on is 3.3 when it list 3.5.
                                    Pin 8: 6.5 for tv is at 7.20 rising .
                                    Pin10:p-on 3.5 for reg is stable at 3.7
                                    Pin 12: P-on 5.0v is stable at 5.2
                                    Pin14:24v amp rises
                                    I know optocouplers stabilize voltage and must be damaged.there is 5 on this board. To test hot side they need to be powered on .
                                    I think infound 2 bad optos .
                                    Top one in righ conner facing rear of tv by backlight. the one in the bottom left below mini yellow transformer engaged protection relay when testing.
                                    • bman4
                                      • Jul 2015
                                      • 210
                                      • canada
                                      #58
                                      Ic1201 i belive is functions but there is 2 bad optos . i got some stashed somewhere and gotta got find them.
                                      Bottom pin 1:minus 45.1
                                      Bp 2:56.3v
                                      Bp 3:minus 56.4
                                      Bottom pin 4 : 5v
                                      • bman4
                                        • Jul 2015
                                        • 210
                                        • canada
                                        #59
                                        Replaced the optocouplers and get reading . the bottom right one under mini transformer engages protectipn shut down relay on hot side. This bottom right corelates with ic 1201.
                                        • bman4
                                          • Jul 2015
                                          • 210
                                          • canada
                                          #60
                                          Might of been hard to under stand what i was explaining becausel i left out detail.
                                          The optos i replaced where not getting a beep on continunity like the others when power was engaged.
                                          The bottom right opto coupler engages protection relay when testing continuity on hot side unlike the others .. i belive it.corelates with ic 1201.i got 5.02 mega ohom reading on hot side of bottom right opto
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
                                          • SkishyIshy
                                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                            by SkishyIshy
                                            Hey All,
                                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                            03-17-2021, 11:44 AM
                                          • noinimod
                                            Sony 55X900E no standby light, no power. Replaced mainboard already
                                            by noinimod
                                            No standby red light, nothing
                                            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                            Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                            At a few pins I can see the power supply providing 19.5V to the main board
                                            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                            12-22-2021, 12:58 AM
                                          • lapfix
                                            HP OMEN NO power no light
                                            by lapfix
                                            HP OMEN : DAG35DMBAD0
                                            NO power ,no short ,no corrusion
                                            Consumption : when charger plg in = 0.004 amp
                                            Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                                            when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                                            No light at power button led
                                            All coils resistances :
                                            Pl 2001 =3v measured with kohm.
                                            pl 2004 = 5v measured with kohm
                                            pl 6001 = 49.7ohm
                                            pl 4012 = vccsa = 24.4 ohm
                                            pl 3001 =...
                                            11-03-2025, 07:48 AM
                                          • x_orange90_x
                                            Vizio E550i-A0 no power, no standby light
                                            by x_orange90_x
                                            I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                            11-20-2023, 09:49 AM
