Emerson LC401EM2F no standby light or power
  • Beef_Ramen
    • May 2016
    • 22
    • US
    So i found this tv on the side of the road, and have repaired everything i have identified to be nonfunctional. I'm looking for suggestions on what to try next, i have attached a video below which explains everything in more detail. If you have any suggestions or help whatsoever please post it, I have checked this forum and various other sites but still need some assistance.
    https://www.youtube.com/watch?v=PyiBtmWuzQk
    Re: Emerson LC401EM2F no standby light or power
    Please upload good clear straight shot pictures of the that power supply board top and bottom side, and the pictures of the whole backside of the TV so we can see all the boards, that will be a start.
    BTW, are these the exact match of your boards? It also has repair kit for the power supply board.
    http://www.shopjimmy.com/catalogsear...rson+LC401EM2F
    • Beef_Ramen
      • May 2016
      • 22
      • US
      Thanks for the reply. Yes, the link you provided is the same as my board. Also here are some pictures, if you need a closer shot of anything in particular let me know.
      http://imgur.com/a/itSgD
      • Beef_Ramen
        • May 2016
        • 22
        • US
        We're those shots clear enough?
          I did not have a chance to download the pictures and study them yet.
          • CapLeaker
            Leaking Member
            • 8179
            Unplug everything from the power supply. Plug it into the outlet and measure the voltage on the main filter capacitor in the primary. Use both of your leads on that capacitor while measuring. Then there are 2 sets of ribbon cables going from the power supply to the main board. With the power supply plugged in measure all the DC voltages on those pins and post them with the pin out name.
            • Beef_Ramen
              • May 2016
              • 22
              • US
              No problem and no rush, if the pictures aren't clear enough when you view them just let me know, thanks again
              Thanks for the reply. Bare with me, I'm rather new to most of this with the exception of recapping a few boards.
              How exactly do I perform the tasks? I just want to make sure I do this right and understand it before proceeding.
              • CapLeaker
                Leaking Member
                • 8179
                Easy. Each switching PSU has 2 sections (see that line going through the PSU?). A primary and a secondary. The primary has the potential on mains power. So be warned. Each DC V measurement on the primary is with the GND probe of your DMM to the big high voltage main filter capacitor, while probing around with the positive probe. Be careful, if the PFC booster is turned on, you get roughly 400V DC on that main filter cap.
                The secondary is isolated from the primary. Your GND reference for your negative probe is either chassis GND or the GND pins on the 2 connectors, or any GND point at the secondary.
                Reason for post 6: if you have 170V DC at the main filter cap, that is good. If not, well there is something else shot in the primary. If you have 170V at that main filter cap, proceed probing the pins on both connectors on the PSU. I am looking for the standby voltage.
                Here is how it goes. STBY voltage is always there on the PSU. That is going to the main board. When you press the on button on the TV, the main board returns PSon and BLon. In other words, it tells the PSU to turn on all the voltage rails and the back lights. TV turns on.
                Right now we don't know if:
                A: the primary has power on the filter main filter cap, in order to power the STBY circuit
                B: there is something wrong with the standby voltage circuit
                C: you got a bad main board.
                • Beef_Ramen
                  • May 2016
                  • 22
                  • US
                  Ok I'm understanding it more now.
                  I thought I would mention this before I continue, when checking the dc voltage on the main filter capacitor, it's only reading out 1.90~V with both probes on each lead. That's already a problem right?
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Can you read the voltage using your meter probes connected to each pin. Red to "+ " and Black to "-" across capacitor C1612.
                    You also need to check all the diodes using your meter set to diode mode.
                    Also check the white ceramic fuse, number I cannot read.
                    If there is an ON/OFF switch on the set then check that too.
                    • Beef_Ramen
                      • May 2016
                      • 22
                      • US
                      Originally posted by dick_barton
                      1. Can you read the voltage using your meter probes connected to each pin. Red to "+ " and Black to "-" across capacitor C1612.
                      2. You also need to check all the diode using your meter set to diode mode.
                      3. Also check the white ceramic fuse, number I cannot read.
                      4. If there is an ON/OFF switch on the set then check that too.
                      1. It's reading 1.90~ volts
                      2. I've checked all the diodes and they seem to be ok, I replaced 2 of them mentioned in the video I posted, which seems to make my fuse stop blowing.
                      3. Fuse has been replaced as mentioned in the video, it's showing 0.015 voltage in ac mode.
                      4. There is a power button on the TV, but I doubt that's what you're talking about
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        basically a power button can fail with bad contacts can you test the switch?
                        Theres a possibility i guess that this tv took a lightening strike so maybe why the psu had blown so bad on the underside, also if the tv had any inputs ie cable etc going to the main board that maybe damaged too but lets test the psu first and go from there. on the psu where the connectors are going too the ribbon cables/connectors can you upload pictures af them as sometimes it also gives voltages printed on the board and pin layout etc.
                        • Beef_Ramen
                          • May 2016
                          • 22
                          • US
                          How would I go about testing the switch?
                          Here are the pictures
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Can you check the continuity of the two transformers highlighted within the red boxes using your ohm meter and then measure what ac voltage you have across the points indicated by the arrows.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Just place your ohmmeter across the ON/OFF switch and it should be 0 ohms when the switch is in the ON position and OL when in the OFF position.
                              • Beef_Ramen
                                • May 2016
                                • 22
                                • US
                                All points circled have continuity, the 2 points tested for voltage read 119.0~ volts
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Well that's something positive. Sothe PSU does has mains input voltage. So now to find the capacitor holding the rectified ac. Will look at your photo's to find it.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    In the yellow box shown, can you lift one end of the diode and test it and then measure the coil resistance of the relay.
                                    • Beef_Ramen
                                      • May 2016
                                      • 22
                                      • US
                                      Lift as in De solder one lead from the diode? If so does it matter which lead?
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        Ignore that test for now.
                                        You said you had 119V ac from the earlier measurement. There are 4 diodes that rectify the AC and apply it as DC to the capacitor C1612.
                                        Measure once again across C1612, one probe on either pin with meter set to => 600V DC.
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
                                        • noinimod
                                          Sony 55X900E no standby light, no power. Replaced mainboard already
                                          by noinimod
                                          No standby red light, nothing
                                          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                          Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                          At a few pins I can see the power supply providing 19.5V to the main board
                                          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                          12-22-2021, 12:58 AM
                                        • x_orange90_x
                                          Vizio E550i-A0 no power, no standby light
                                          by x_orange90_x
                                          I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                          11-20-2023, 09:49 AM
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
