e701i-a3 no picture but backlights
  • viewerau
    • May 2020
    • 305
    Re: e701i-a3 no picture but backlights
    Originally posted by diif
    He pulled them off and once off they don't go back on.
    That's what I figured, but isn't the picture now showing the set working?
    Or am I confused?
    Sorry
    Signature:Seemingly hopeless tv fixer
    • Awsmessymail
      • Nov 2023
      • 12
      • United states
      #1062
      Here you all go! This is a repair on a Sony KDL-70r 550a model that someone brought to me for repair. This is using the failure -prone Sharp 70 inch LCD panel. The only difference between this panel and the Vizio model which also uses the Sharp 70 inch panel is this model is 3D. It doesn't play any difference on the design of the panel though. This was the second of this model TV that somebody had brought to me in a week. The first one that I tried to repair had vertical tab failure so it was inevitable useless. This one however had the same symptoms as that one shutting down with with a 5 blink code but as soon as I started unplugging one or the other side of the panel from the t-con board I knew exactly what I was in for and this is the result. After this video I have fixed another Sony of the same model for another customer and another Vizio. The other Sony was the left side driver boards instead of the right and the Visio I just repaired was the right side driver boards not the left so with this information either side can go bad so don't jump to conclusions right away before you do testing. The lucky thing about the Sonys and Sharp models is that they're OCP shut down doesn't destroy the t-con board like the Vizio does so it helps in the determining factors of trying to pinpoint your diagnosis without having an array of t-con boards on hand to get to your diagnosis like the Vizio. Unless you're handy with soldering to have an array of transistors ready to replace the original coxa that goes bad, you would have to be quick with the power cord if you don't get a picture right away on the Vizio and sometimes when you're lucky you will not blow up the tcon board by unplugging it before it does imminent failure to the COXA transistor on the board.
      https://youtu.be/A9UaWnsF2Mg
      Freak, any chance you'd change this video to being a non-private video? I'm working on a set and would like to watch it. I've tried everything and still have a blank screen with backlights. all components test fine but I see that someone in earlier posts was talking about a "red cap" and seeing 15.3V there. I don't see that but the transistors, other caps, and other spots have the correct voltage. You never really mentioned this "red cap" (mines orange like your photos show). Any idea of what could cause 0v on this orange capacitor?
      • otaku_nut
        • Aug 2025
        • 6
        I know this is an old thread but still very relevant. I'm hoping someone knowledgeable is still watching it and might be able to offer some advice. I've replaced the t-con on my e701i-a3 and removed the right and left driver ribbons. I turned it on with only the vertical boards and got colors. Previously I only had the typical black screen with backlight and sound. I plugged in the right side front facing and I got clear picture on the right side and blurred picture on the left. I turned it off again and briefly plugged in the left and back to black screen. I unplugged it right away. I unplugged the left again and it is back to blur on the left and clear on the right. I'm ready to rip off the panel ribbons to the driver boards on the left but there is one concern. I have a giant vertical red stripe in the center of the screen. Anyone have any idea if removing the ribbons from the left will solve this vertical stripe? I also would love confirmation that it is the left I need to remove before I do it? If the Left driver is not responsible for the vertical red, where do I look for that answer? Thanks in advance and also thanks to the pioneers of this thread, you guys are awesome and very patient.
        • otaku_nut
          • Aug 2025
          • 6
          Well, I went for broke and removed the driver board and I got full picture back, but the vertical line still won't go away. I've tried cleaning the connections, pressing on the connections to try to get a response and nothing. I'm happy to report that the display board fix worked at least, so if anyone is still reading this and on the fence about doing the fix, just go for it, there's little to risk if the tv is the same as mine was.
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • maxim2511
            LG 55EC930V OLED - swich on swich of no screen
            by maxim2511
            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
            Then I get an idea to take it apart and clean boards from dust.
            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
            05-14-2021, 02:21 AM
