e701i-a3 no picture but backlights
Re: e701i-a3 no picture but backlights
Here you all go! This is a repair on a Sony KDL-70r 550a model that someone brought to me for repair. This is using the failure -prone Sharp 70 inch LCD panel. The only difference between this panel and the Vizio model which also uses the Sharp 70 inch panel is this model is 3D. It doesn't play any difference on the design of the panel though. This was the second of this model TV that somebody had brought to me in a week. The first one that I tried to repair had vertical tab failure so it was inevitable useless. This one however had the same symptoms as that one shutting down with with a 5 blink code but as soon as I started unplugging one or the other side of the panel from the t-con board I knew exactly what I was in for and this is the result. After this video I have fixed another Sony of the same model for another customer and another Vizio. The other Sony was the left side driver boards instead of the right and the Visio I just repaired was the right side driver boards not the left so with this information either side can go bad so don't jump to conclusions right away before you do testing. The lucky thing about the Sonys and Sharp models is that they're OCP shut down doesn't destroy the t-con board like the Vizio does so it helps in the determining factors of trying to pinpoint your diagnosis without having an array of t-con boards on hand to get to your diagnosis like the Vizio. Unless you're handy with soldering to have an array of transistors ready to replace the original coxa that goes bad, you would have to be quick with the power cord if you don't get a picture right away on the Vizio and sometimes when you're lucky you will not blow up the tcon board by unplugging it before it does imminent failure to the COXA transistor on the board.
https://youtu.be/A9UaWnsF2MgComment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by maxim2511My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
Then I get an idea to take it apart and clean boards from dust.
In side of Tv was not so bad, I take compressed air in can, and gently blow up.
Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher... -
I have a VIZIO E70-E3.
Symptoms: Black screen, no picture, but LED backlights are working.
I probed the power board and voltages are as listed on the board.
Main board appears fine, too.
I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
There are two separate ribbon cables feeding the LCD.
If both are connected, the screen is black.
If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and... - Loading...
