Vizio E470i no power
  • AcGeorgiegirl
    • Jun 2013
    • 202
    Re: Vizio E470i no power
    Just a quick note of sincere thanks to all who helped me with my tv.... I had an unexpected surgery, and didn't get to tell you that I learned some valuable stuff, and appreciate your kindness! I am planning to try a go at figuring out which LED(s) are faulty as soon as I recover my thinker!
    • newtothis
      • Mar 2013
      • 1556
      • england
      #82
      Hope you have a speedy recovery and no problem
      • Nicegut
        • Jan 2016
        • 5
        Hey guys, anyone have these backlights available? Mines completely stripped down and i have bad strips and a few single ones not flashing on when I power on. Is there a way to fix these on the component level? Someone is offering repair service on E-bay. Thanks in advance!
        • mcross
          • Sep 2011
          • 201
          I have the same tv. I do not get 12v , i get 6 to 7v on pins 6-7, rest is good
          Any ideas or do i need to post new thread
          mike
          • Nicegut
            • Jan 2016
            • 5
            Fixed mine, soldered in 2 new leds.
            • Daveleone
              • Apr 2016
              • 267
              I have this same TV and the same problem (when I turn on my TV the backlight comes on for a split second and then turns off). All of the voltages between the power supply and the main board look ok, and when the TV is powered on I can see the Vizio logo, and then "No channels programmed" on the screen (so the TV is actually powered on, just with no backlight).
              If I measure vout1 and vout2 to the LEDs during power-on I see them both jump up to ~129v for a second (when the light comes on) and then drop to ~69v (but not 0). What does it mean? Does that mean I have bad LEDs?
              Your help is greatly appreciated. Thanks!
              https://www.youtube.com/watch?v=AclsDZ8glK4
                Sounds like it. You probably get the about same readings without (no load) the LED connector in place, right?
                • Daveleone
                  • Apr 2016
                  • 267
                  Yes, I get ~exactly the same voltages (up to ~129v then down to ~69v) without the LEDs connected.
                  Know where I can get a set of LED strips that are in stock?
                    http://www.shopjimmy.com/catalogsear...Vizio+E470+LED
                    Not sure which LCD panel maker you have in your TV, so I would contact SJ to see.
                    • Daveleone
                      • Apr 2016
                      • 267
                      These are the strips I need and they're out of stock at ShopJimmy.
                      http://www.shopjimmy.com/lg-6916l-11...-12-strips.htm
                      I checked eBay but the cheapest is $18.95 PER STRIP (and there are 12 strips - ugh).
                      Any other source that has them in stock?
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        #91
                        Maybe if you PM Nicegut who posted earlier and see where he got his from.
                        • Daveleone
                          • Apr 2016
                          • 267
                          He didn't buy replacement strips. He repaired his existing strips by soldering in new LEDs. I'd rather replace all my strips. Still looking for a source...
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            #93
                            Maybe searching online for an identical model as yours but cracked screen could be the cheapest option.
                            • SLK001
                              • May 2014
                              • 264
                              I have one of these E470i-A0 with two LEDs out. Does anyone know of a source for the LEDs (components, not strips)? I've looked at both Digikey and Mouser, but I have yet to be able to sift through all the available devices. These devices have the large pad on the anode (+ side) of the LED. The LED size is 2.8mm x 3.5mm x 0.65mm.
                              • Daveleone
                                • Apr 2016
                                • 267
                                Can anyone tell me in what order the diffusion layers go (between the LEDs and the lcd panel)? I took the thing apart to repair the LEDs and can't remember in what order to put it back together, lol! I should've taken pictures.
                                There are 2 thin white plastic sheets, a thin highly reflective sheet, and a thick white plastic board. What order do they go in, from LEDs upward?
                                Your help is greatly appreciated!
                                • Daveleone
                                  • Apr 2016
                                  • 267
                                  I think I figured it out. I believe it goes - thick plastic board, thin plastic sheet, prism reflective sheet, thin plastic sheet (from LEDs upward).
                                  My guess is based on the diagram in Figure 4 on page 2 here: https://cdn.badcaps-static.com/pdfs/...214da42065.pdf
                                  I put the tv back together this way and I'm happy with the way it looks
                                  Special thanks to @nicegut for the help!
                                  • lfhlaw
                                    • Mar 2014
                                    • 102
                                    I came into this E470i-AO. I've replaced both boards(PSU and main) of this TV and I cant get it to Power up at all. Will a bad LED strip cause the TV to not power on at all on this TV?
                                      No indicator lights at all or what?
                                      Do you have meter to test Voltages?
                                      • lfhlaw
                                        • Mar 2014
                                        • 102
                                        Nope no indicator lights at all. Normally, most Tv's will at least light up the indicator light, but even that's not coming.
                                        I do have a meter, but not very good with it lol.
                                          Well, at this point you need to upload good clear pictures of the top and bottom side of your power supply board, you will need to test Voltages on the connector that goes to the main board.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            09-06-2024, 05:59 AM
