Bush (Vestel) led40127fhdcntd - turns off and on repeatedly
  • tn245
    • Oct 2013
    • 530
    Re: Bush (Vestel) led40127fhdcntd - turns off and on repeatedly
    The script I posted should extract mboot from SPI to usb from a set with a working mboot.
    • gabiz_ro
      • Mar 2011
      • 171
      • Romania
      #102
      Didn't test this.
      But I think we need two kind of usb_auto_update_A1.txt
      One to backup mboot and read or save enviroment.
      If that command is available,at least print and save env exist but save it on spi chip.
      Second way is to open dumped mboot and somewhere in area 0x01d0000 -0x01f0000 (may be wrong address from my memory) here is saved enviroment,then we can adjust other address to correct ones to dump nand
      Second one prepared with address obtained from first step.
      • michael dranfield
        • Jan 2016
        • 232
        • England
        #103
        Originally posted by tn245
        I just have one like this: http://www.ebay.co.uk/itm/25-SPI-Ser...UAAOSwGotWk17h
        It didn't list the SPI chip I had but it worked anyway.
        Oh dear I paid over £500 for mine and that was 10 years ago, I looked at dataman 48 but at over £1k it will have to wait until christmas !
        I have just ordered one now , many thanks for that.
        • vinceroger69
          • Mar 2012
          • 6714
          #104
          I have one of the ebay cheap programmers they dont come with any software in this you tube link theres a download link for it as it also lets you change the language to english
          https://www.youtube.com/watch?v=L0ChYNwunUE
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            #105
            Im buying one, slowly getting all much equipment rather than using my uncles all the time. Thanks
            • tn245
              • Oct 2013
              • 530
              Originally posted by gabiz_ro
              Didn't test this.
              You can just comment out the unneeded lines in my script to just dump the bits you want (SPI, RFS/CONF etc..).
              I think actually the values were the same on all the versions I played with so maybe it will work for most. I just wanted to point out that it could possibly be a problem to look out for.
              • gabiz_ro
                • Mar 2011
                • 171
                • Romania
                #107
                I know that,but is more ... easy to have two file,to comment uncomment line every time.
                Can use two usb sticks,one to dump mboot and address ,second one modified with what you need,according to what you get from first one.
                I don't think they are the same address,many times when programming spi flah boot sequence on TV stop like a kernel panic.
                Looks like tryied to boot but encountered problem and in log window two or three segments of few hex line .
                • michael dranfield
                  • Jan 2016
                  • 232
                  • England
                  #108
                  I have tried the program again on a different set and still cant get it to download any files from the TV to a usb stick , is there something I am doing wrong ?
                  I held ok button down and after a slight pause the led blinks for a bit and then goes back to ST/BY but there is nothing on the USB stick apart from the reader program.
                  • tn245
                    • Oct 2013
                    • 530
                    Interesting. I will have to dig mine out to test it and see what's going on.
                    • gabiz_ro
                      • Mar 2011
                      • 171
                      • Romania
                      #110
                      Stick must be FAT32
                      If FAT windows complain that disk must be checked,after files are gone.
                      Try to open files without checking disk disk file error.
                      On FAT32 works.
                      On UBIA seems to hang,wait for some time then commented in file.
                      ON UBIB I get some error
                      Code:
                      >> nand read.e 80400000 UBIB
                      NAND read: device 0 offset 0x86A0000, size 0x7860000
                      Bad block at 0xFE00000 in erase block from 0xFE00000 will be skipped
                      Seems to hang too,so I commented in file
                      Console log
                      Code:
                      À keypad_pressed is [0]
                       ir_pressed is [1]
                      check_sw_upgrade
                      no OAD Flag
                      Check USB port[1]:
                      No USB is connecting
                      usb init failed
                      Error, couldn't init Lowlevel part
                      Check USB port[0]:
                      Host type:2
                      scanning bus for devices... 1 USB Device(s) found
                      port_switch is:0
                          scanning bus for storage devices... bulk max packet size:200
                      iobuf[0]:0
                      max USB Storage Device reached: 1 stopping
                      1 Storage Device(s) found
                      no need to start factory usb download
                       #* 1. NAND is already programmed (not Empty) ***
                      reading usb_auto_update_A1.txt
                      1 bytes read
                      746 bytes read
                      >> spi_rdc 80400000 0x00000000 0x0200000
                      offset 0x0, size 0x200000
                      >> fatwrite usb 0:1 80400000 mboot.bin 0x0200000
                      file mboot.bin not found
                      fd:0, cur_cluster:2, cursect:8192, offset:7
                      #set getno = 16 and clust_size = 8
                      >> envbin
                      (Re)start USB...
                      Check USB port[0]:
                      Host type:2
                      iobuf[0]:0
                      buff:spi_rdc 0x82000000 0x1D0000 0x10000
                      offset 0x1D0000, size 0x10000
                      crc:5F9F844F,crcNew:5F9F844F
                      buff:fatwrite usb 0 0x82000000 env.bin 0x10000
                      file env.bin not found
                      fd:0, cur_cluster:2, cursect:8192, offset:8
                      ok
                      >> nand read.e 80400000 KL
                      NAND read: device 0 offset 0x0, size 0x500000
                      Reading data from 0x0x -- 100% complete.
                       5242880 bytes read: OK
                      >> fatwrite usb 0:1 80400000 KL.BIN 0x500000
                      file KL.BIN not found
                      fd:0, cur_cluster:2, cursect:8192, offset:9
                      >> nand read.e 80400000 CONF
                      NAND read: device 0 offset 0x500000, size 0xFA0000
                      Reading data from 0x5242880x -- 100% complete.
                       16384000 bytes read: OK
                      >> fatwrite usb 0:1 80400000 CONF.BIN 0xFA0000
                      file CONF.BIN not found
                      fd:0, cur_cluster:2, cursect:8192, offset:10
                      >> setenv bootdelay 5
                      >> saveenv
                      Saving Environment to spiflash...
                      Flash is detected (0x0507, 0xC2, 0x20, 0x15)
                      Write addr=0x001D0000, size=0x00010000
                      >> reset
                      • tn245
                        • Oct 2013
                        • 530
                        Good point about FAT32. Could be Michael's problem?
                        UBIA is a much larger volume than the others so takes longer to read and write. It may complete if you just leave it for a long while.
                        UBIB seems to be used for backups of the other volumes so could be useful to restore if other volumes have been corrupted.
                          • 31293
                          your not reading the forum much,
                          i have been collecting, cleaning up, and posting that software on this forum for months!
                          https://www.badcaps.net/forum/showpo...3&postcount=11
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #113
                            I think i actually posted in that thread as well too be honest, and yes your software is a lot newer as soon as ive reformatted my laptop i will have ask you for a download link/files.
                              • 31293
                              it's in that thread.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #115
                                Cheers just found the thread now
                                https://www.badcaps.net/forum/showth...rom+programmer
                                • michael dranfield
                                  • Jan 2016
                                  • 232
                                  • England
                                  #116
                                  Stick must be FAT32
                                  On FAT32 works.
                                  Code:
                                  Console log
                                  Code:
                                   ir_pressed is [1]
                                  check_sw_upgrade
                                  no OAD Flag
                                  Check USB port[1]:
                                  usb init failed
                                  Check USB port[0]:
                                  Host type:2
                                  port_switch is:0
                                  iobuf[0]:0
                                  1 bytes read
                                  746 bytes read
                                  >> envbin
                                  (Re)start USB...
                                  Check USB port[0]:
                                  Host type:2
                                  iobuf[0]:0
                                  ok
                                  >> setenv bootdelay 5
                                  >> saveenv
                                  >> reset
                                  First of all I would very much like to thank TN245 and GABIZ-RO for there help with this project I still have much to learn but am making good progress, I have got both programs to work but the one from Gabiz_ro is much quicker at downloading to the stick,
                                  I have observed the following , this set has 2 x USB inputs , when I run the program in the top USB it only downloads file only M Boot 2048Kb, but if I download from the bottom USB it downloads 4 files M Boot 2048Kb , Config 16,000Kb , KL 5120Kb and Env 64Kb,
                                  How would I open these files in something more meaning full so I can search for the remote control commands ? All I have at the moment is Hex workshop.
                                  • gabiz_ro
                                    • Mar 2011
                                    • 171
                                    • Romania
                                    #117
                                    My TV has also two USB ports,didn't notice something strange,but from console messages,after reading mboot,seems like enumerating again USB ports.
                                    In other words after mboot dumped and saved,search again and some messages like USB 1 cannot enable low level or something like this,next was USB 0 found,storage ...
                                    Is much quicker because I commented dump for UBIA and UBIB
                                    To make some useful from dumps I think you must use some UBI filesystem tools.
                                    can't find one for windows,so must be done under linux.
                                    TV was returned to customer.For now no more tests possible.
                                    I have tryied other methods,need to have one file on usb stick,enter service menu and choose usb operation.
                                    Config file as hwprofile and swprofile are saved to stick.
                                    Modifying of swprofile info was found on some german forum and blog.
                                    Attempts to modify hwprofile (did too many once) resulted in some kind of kernel panic.
                                    Anyway I see here something remote type,can't remember but was something like RC1912 and other one RC48
                                    • tn245
                                      • Oct 2013
                                      • 530
                                      Remote control info seems to be in the file mb95_hwprofile.bin in CONF. You can extract files from CONF.BIN using the scripts downloaded from https://github.com/jrspruitt/ubi_reader
                                      • gabiz_ro
                                        • Mar 2011
                                        • 171
                                        • Romania
                                        #119
                                        Maybe just a dumb ideea.
                                        Many items in hwprofile are 00h after reading dump.
                                        If we make that 01h maybe then option isn't read only in service menu.
                                        And like I see in swprofile in german forum, take address of next byte,reverse it,like 0x006c1A become 1a6c,search for hex value, then experiment.
                                        In swprofile
                                        Is something like
                                        00 00 00 00 1a 6c 00 00 function disabled (but I'm not sure about last 00 00)
                                        01 00 00 00 1a 6c 00 00 function enabled ( but ... like I said in previous example)
                                        But in hwprofile seems that string is shorter.
                                        01 00 XY ZC (xy zc are address)
                                        Or maybe I'm wrong.
                                        Edit
                                        You can extract hwprofile and swprofile alone.
                                        Info here http://blog.loetzimmer.de/2015/01/fo...l3433.html?m=1
                                        • tn245
                                          • Oct 2013
                                          • 530
                                          I changed the tuner type succesfully just by changing the line here from Si2156 to Si2157 (see image). Just above that you can see Rc5117. I guess this refers to the remote control. There are codes for many remote listed elsewhere in the file including some with brand names (most without):
                                          Panasonic-Rc4861
                                          Sharp-RC484x
                                          Technisat-Rc4850
                                          Technisat-Rc4852
                                          TOSHIBA-Rc3412
                                          TOSHIBA-Rc4826
                                          TOSHIBA-Rc4827_8
                                          I think you should be able to replace that with the code for your remote if you can figure out which one it is.
                                          • FlailingEngineer
                                            Help with Bush Tv (Vestel 17mb95m Mainboard)
                                            by FlailingEngineer
                                            Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                            Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                            05-31-2023, 06:52 AM
                                          • Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                            by Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                            03-15-2024, 09:37 AM
                                          • Jaime Morillo
                                            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                            by Jaime Morillo
                                            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                            The TV was stuck on the logo and I couldn't access the update menu.
                                            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                            The image result was good, but the image is inverted.
                                            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                            08-18-2025, 11:38 AM
                                          • www
                                            LG L192WS-BN backlight turns off after 1 second
                                            by www
                                            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                            03-24-2024, 05:26 PM
                                          • Chrissygizmo
                                            Bush led40127fhdcntd possile firmware issue?
                                            by Chrissygizmo
                                            I've picked up a bush led40127fhdcntd & the standby led is constantly flashing .. It flashes around 10 seconds then the backlights come on with a blank screen, led continues to flash for about 20 - 30 seconds & then the backlights go off , this is a continuous cycle..
                                            I will upload photos of the mb ,...
                                            11-03-2021, 08:28 PM
