I have replaced one burnt thermistor with a new 10 Ohm one (https://uk.rs-online.com/web/p/thermistor-ics/1857867), left the other old ones in place as they did not look damaged.
The TV is working fine again, hopefully this will be a permanent fix.
Thanks to this forum and specifically to lotas and slybunda for detailed guidance.
Bush (Vestel) led40127fhdcntd - turns off and on repeatedly
I have opened the TV, and can see that TH2 (just one of the three) thermistor is burnt, photo attached. I do not see any markings, but based on the earlier post from slybunda it must be SCK 102.
lotas, I see you have suggested to replace it with 20 Ohm (https://www.badcaps.net/forum/troubl...e9#post1867354), is that right? or did you mean replacing two of the old ones with one 20 Ohm? I believe slybunda said original ones were 10 Ohm each.
thanks in advanceLeave a comment:
I have Toshiba TV 75u6763db, now 6 years old, experiencing symptoms, exactly as slybunda has described: works fine but when entering standby mode after a couple of seconds it powers back on and then keeps turning off and on..
I did not open the TV yet so can't at present confirm if the same thermistors are burnt.
slybunda – is your TV still working a year after your repair?
I am also in the UK, so would you still advise to use NTC 1512 Thermistor (https://uk.rs-online.com/web/p/thermistor-ics/1857833)? Any other tips or advise for DIY troubleshooting and repair?
Thanks in advance
Re: Bush (Vestel) led40127fhdcntd - turns off and on repeatedly
just an update, tv is still going great. still dont get why the thermistors popped. i do feel like getting a working tv with smashed screen and using its powerboard for full recap and upgrade of other components and to keep as spare? what way can switch over with no downtime.Leave a comment:
TV still doing great. was wondering how long are these thermistors supposed to last when used as inrush current limiters? i thought they should go 10-15 years atleast?Leave a comment:
hey all, i replaced the 2 thermistors and now its working properly. tv turns off and stays off.
question is now, the 3rd thermistor on the board that is not blown up should i replace it too or leave it as it is?
had to buy a 5 pack of thermistors total cost was £2.90ish so iv got 3 left.
got to thank everyone for their support.Leave a comment:
38.5ohms and 226kohms - These are no longer workers, especially the second one.Leave a comment:
can i use these ones linked in the pic below or will they blow up?
also i noticed the data sheet says they have a cycle life of 1000 could this by why the original ones popped after 5 years of use with tv being used multiple times every day?
also i forgot to add i got a multimeter across the blown thermistors and the have values of 38.5ohms and 226kohms. the working one has 14.2ohms (around 16c temp in my room) and when i hold it with my fingers its ohms start dropping down.Last edited by slybunda; 11-08-2023, 10:04 AM.Leave a comment:
Replace them, you can put one at 20 Ohm.Leave a comment:
i had the batteries out of the remote and this same issue happens, once tv is on it wont power off. im wondering if those thermistors are blown are they responsible for power off the tv and keeping it off?Leave a comment:
thanks for that info. do i have to use the exact original thermistors that were there or can i use any which are marked as 10ohm 2 amp?Leave a comment:
They (thermistors) are connected in series to the closing contacts of the relay, for a soft start.Leave a comment:
reason is im trying to find ones which i can use instead of ordering the same ones from china which will take a month to arrive.
the shop near me is RS components, which i can get to easily and they have a lot of stuff in stock.
also i believe the website here: https://www.lcsc.com/product-detail/...Y_C211173.html
seems to have different info on the product page compared to the datasheet. webpage says its 3A but datasheet says its 2A so thats where i was getting some confusion from.
there is this one here: https://uk.rs-online.com/web/p/thermistor-ics/1857867
that seems to be close on specs rated at 2A has 30second Thermal cooling time constant but only 1.4w power rating which is less than the original ones 2.3w. capacitance at 240v is also a lot less at 100uf vs the originals 220uf.
im in the United Kingdom so if anyone know what i can get a hold of quickly it would be much appreciated.Leave a comment:
website above has given me this info on the SCK102
pic attached.
when selecting a thermistor what does the specs need to match? is it just got to be the ohm rating at 25c temp?
what is thermal time constant rating? i see this vary on similar spec thermistors. the SCK102 has 38 seconds and im struggling to find one that matches that exactly, most are 30s or 60s or more?Last edited by slybunda; 11-07-2023, 03:07 PM.Leave a comment:
Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu... -
by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by wwwI am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....-
by ChrissygizmoI've picked up a bush led40127fhdcntd & the standby led is constantly flashing .. It flashes around 10 seconds then the backlights come on with a blank screen, led continues to flash for about 20 - 30 seconds & then the backlights go off , this is a continuous cycle..
I will upload photos of the mb ,...11-03-2021, 08:28 PM - Loading...
