Sharp AQUOS LC-60LE633U--Power light flashing 5 times fast and then 2 slow flashes
  • esteve
    • Jan 2015
    • 10
    Gentlemen.
    I am new to the forum...but not to TV repair.
    I can't find the service manual but all the similar case histories call for a "Panel power supply error" or power supply.
    I purchased a power supply from Ebay it did not fix it.
    Does anyone have access to the service manual and /or some suggestions...
    Thanks,
    Steve B
  • nuala
    • Aug 2013
    • 37
    Re: Sharp AQUOS LC-60LE633U--Power light flashing 5 times fast and then 2 slow flashe
    UNPLUG HOLD DOWN POWER AND MENU BUTTONS PLUG POWER IN FOR 5 SECONDS, THEN RELEASE POWER AND MENU BUTTONS TV LIGHTS UP, HAS CRACKED DISPLAY HAD 2 0F THESE TO COME IN TODAY
    try this/
    • Shinju
      • Mar 2014
      • 1239
      Interesting, does this work for the older Sharp models too?
      • esteve
        • Jan 2015
        • 10
        you cant hold them down as they are touch sensitive ,,,,,
        • R_J
          • 9549
          Try disconnecting the pannel ribbon connectors from the T-con board, and then powering the tv on. Its possable the panel is damaged
          • esteve
            • Jan 2015
            • 10
            re:
            • esteve
              • Jan 2015
              • 10
              I tried "disconnecting the panel ribbon connectors from the T-con board", and that allowed the set to power on with the backlight.....and there is was ..a big spider web..(cracked screen)
              Good call RJ..
                The crack probably shorts out some of the panel drivers, making them trip an error. That's the first I've heard or seen of an LCD doing that after damage though.
                • Rpl313
                  • May 2016
                  • 3
                  Hi i have the same exact problem my tv is flashing 2 slow lights 5 fast lights, i have zero picture at all no matter what i do, when plugged into cable it shows sharp logo then goes black , i tried a new power supply board but didnt help i unplugged the tcon board and the screen backlight lights up for a few then shuts off no cracks or damage
                  • vwynn
                    • Aug 2016
                    • 4
                    adding to this thread but with a twist as my problem is similar yet different..
                    TV Model: Sharp LC-60EQ10U
                    Blink code: 2 long 5 short. (Panel Power Supply)
                    What actually happens:
                    When i plug in the TV everything appears to be working. The TV lights turn on and im able to turn on the TV. THe picture looks great and audio works aka everything works. about 1 or 2 minutes into it the screen starts to appear all glitchy before the screen turns off and the blink codes appear.
                    I opened the back and looked for any blown caps on the power supply board but could not see anything... i do not see any damage on the T-Con board as well..
                    my next thing to try is to grab a DMM at start measuring but has anyone else have this same issue and found a solution? Im hoping its not the back panel....
                      What dcV do you have for the 12v_panel?
                      https://www.badcaps.net/forum/showthread.php?t=49088
                      • budwich
                        • Jul 2015
                        • 3097
                        You can probably get to the "end" faster if you follow the "remove one cable from the tcon and check the resulting picture" test (repeat with the other cable). If you get any "stable result", depending on what the pictures look like, you will have your direction for further investigation.
                        • vwynn
                          • Aug 2016
                          • 4
                          Ill give that a try soon.
                          heres a video of my TV's current state in yall are more interested in videos instead of descriptions.
                          https://youtu.be/4ri3wgZhSnE
                          disregard the sounds... its just me texting.
                          • Malachi
                            • Dec 2015
                            • 1077
                            • Usa
                            I read this whole thread. I don't see anyone interested in videos or asking for a video.
                            • vwynn
                              • Aug 2016
                              • 4
                              I applaud you for your efforts on reading the whole thread and congratulate you for accomplishing it. I appreciate your help thanks!
                              • realdealthill
                                • Nov 2016
                                • 53
                                hi, I have a LC-60LE640U with 2 short and 5 long blink code
                                I get no backlight or imagae
                                I get a good picture on the left side with just left tcon cable connected
                                No backlight or image when just the right tcon cable connected.
                                No Visable blown caps, or burn marks on powerboard
                                6v at all four backlight power wires
                                Is 6v right??
                                • realdealthill
                                  • Nov 2016
                                  • 53
                                  This with the right tcon cable disconnected. Same side that is all white
                                  • martino
                                    Not so "senior"
                                    • Aug 2013
                                    • 997
                                    • canada
                                    for the 60" you can do the same as the 70",rip the bad tabs off....
                                    Read up on the 70" model first!!!!!!!!!
                                    Proud owner of dozens of broken TV's and many,many,many boards.
                                    Our website and passion:http://hollenhundshepherds.com/
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      what happens when you do a similar thing for the other side?
                                      oops... didn't read the previous post about this side... sorry. As suggested, look at some of the 70 in posts on dealing with side tabs. The difference in the set is that there are no side boards as the tabs run to a type of flex "board" down to the bottom boards. If you look closely at the bottom corner of each side, you should see where there is a connection to the bottom boards. You can try your "test" again keeping the tcon fully connected, but disconnect at the corner. You should get a "full picture" on your set when you disconnect the right corner.
                                      The reason for doing the test at the corners is to isolate the problem strictly to the side tabs as opposed to a possible problem with the lower / bottom boards as there have been posts of people finding a fixable issue with the bottom boards that given similar problem appearances.
                                      • realdealthill
                                        • Nov 2016
                                        • 53
                                        Thanks a bunch guys, I i have read alot on the 70" model. just wasnt sure if it applied to the 60"
                                        No need to yell martino. Gezzzzzz ehhhhh.
                                        Much appreciated Budwich
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • SONY_E-WASTER
                                          Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                          by SONY_E-WASTER
                                          Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                          The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                          then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                          does...
                                          12-26-2021, 05:46 PM
                                        • Egidio85
                                          SHARP LC-40LE814E does not turn on 2 flashes
                                          by Egidio85
                                          hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
                                          the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
                                          reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
                                          now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
                                          to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
                                          07-21-2023, 11:49 AM
                                        • joblo37pam
                                          Sharp LC-80LE844U Blinks 2 slow, 5 fast
                                          by joblo37pam
                                          It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                                          The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                                          10-26-2023, 02:17 PM
                                        • klassic
                                          Sharp Aquos LC-60LE635E three blinks
                                          by klassic
                                          Hi community,
                                          I will describe my problem with a TV in those short following terms to be the most precise :
                                          What i have :
                                          power board DPS-162KP-1
                                          main logic board QPWBXF733WJN2
                                          symptoms :
                                          white led light logo at startup,
                                          after 2 minutes, blinking 3 times a row, repeating
                                          no backlight (and apparently no picture, checked panel with flashlight)
                                          no startup sound
                                          powerboard investigations :
                                          1-2 PNL : 0v
                                          3-4 GND
                                          5-6-7-8 UR : 13.15v
                                          9-10-11-12...
                                          10-24-2023, 01:39 PM
