sharp lc-65ub30u plays but screen is flashing on and off
  • JunkmanJimbo
    • Mar 2017
    • 194
    Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
  • Diah
    • Feb 2013
    • 6449
    no way the screen will flashing on & off... but the BL will do,, open it and show us the boards
    • JunkmanJimbo
      • Mar 2017
      • 194
      Here's pictures of the boards. The backlights are flashing on and off. Thinking it might be a bad power supply. What's your opinion?
      • Diah
        • Feb 2013
        • 6449
        go to setting ,menu and reduce the BL level to 30% . see if remain on
        • JunkmanJimbo
          • Mar 2017
          • 194
          This Sharp TV backlight settings are from +16 to -16. I set them all the way to -16 and nothing changed.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4478
            • Italy - Milan
            My ipotesis is that one or more sector power transistor led driver is not ok, the reason? The electrolitic caps i guess no, set is too.young, maybe all sector leds are gone, i dont think so, maybe controlling big IC has to be solder renewed because they driven bad those..
            • Diah
              • Feb 2013
              • 6449
              you have bad one or more shorted led... give attention on screen you will see some shadow on rand when it goes off& on
              • JunkmanJimbo
                • Mar 2017
                • 194
                Actually I don't see any shadows on the screen. Not saying they're not there but from what I can see the picture looks great except for the flashing. So, do you still think my problem is still the backlights? Is there any way it could be the LED driver board that's mounted on the power supply? Thanks for your help. If you still feel like it's the backlights I will pull the screen to check them but I probably can't do thet until Monday or Tuesday. Thanks again!
                • Diah
                  • Feb 2013
                  • 6449
                  disconnect the yellow cable socket from LED driver boards which it come from Main boards and turn on tell the result
                  • JunkmanJimbo
                    • Mar 2017
                    • 194
                    Thanks Diah. It might be a few days so I will tell you the result then. Thanks again!
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4478
                      • Italy - Milan
                      i.was meaning bad power transistor on the blue board...simply..
                      • JunkmanJimbo
                        • Mar 2017
                        • 194
                        Hey Diah. I decided to pull the yellow cable today. When I pulled the yellow cable between the LED driver board and the mainboard the backlights would not come on. When I plugged the cable back in the backlights still wouldn't come on. I had to unplug the power cord and plug it back in for the backlights to come back on, still blinkiing. What's your opinion on this? Thanks!
                        Something else I noticed.....when I turn the power off by the power button the backlights contnue to flash for another 20 seconds before they turn off.
                        • JunkmanJimbo
                          • Mar 2017
                          • 194
                          Can you tell me which one is the power transistor? Thanks!
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4478
                            • Italy - Milan
                            No is not one, there are many all identical, you have to find which one suffers if any
                            • JunkmanJimbo
                              • Mar 2017
                              • 194
                              I checked all the transistors and all of them appear to be good.
                              • Diah
                                • Feb 2013
                                • 6449
                                first don't follow other with his confusion, as usual irresponsible technician clarification
                                use yours DM in DC mode measure each channel of LED at start up you have 4 each have LED + & LED -
                                or try to unplug one channel at time.
                                • JunkmanJimbo
                                  • Mar 2017
                                  • 194
                                  I unplugged each of the 4 connectors of the LED cables one at a time. The backlights still blinked off and on. I tried unplugging all 4 and then there were no backlights.
                                  But why would the backlights stay on for another 20 seconds after I power off the TV?
                                  • Diah
                                    • Feb 2013
                                    • 6449
                                    stay on for 20 seconds or it remain flashing for 20 seconds after you put it in STBY.=
                                    if remain ON for 20 seconds.... we need to tray log in first in service menu and do clear chip as hard reset... to avoid any mistake at BL_ON signal send BY MB.
                                    also take out the power boards and the LED driver boards and inspect the down side of cracking joint solder
                                    • Diah
                                      • Feb 2013
                                      • 6449
                                      when there are open circuit at discharging power boards or ceramic cap changed value this will happen.
                                      • JunkmanJimbo
                                        • Mar 2017
                                        • 194
                                        The backlights remain flashing for 20 seconds after powering the TV off.
                                        • HTR-Informatique
                                          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                          by HTR-Informatique
                                          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                          I also changed the screen because the PC fell and the screen was broken.
                                          I changed the battery with a new and original battery.
                                          I also had corrosion/oxidation on the...
                                          02-09-2025, 06:51 AM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • EazyBone
                                          Sharp LC-65Q620U White Screen
                                          by EazyBone
                                          Another TV topic!!
                                          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                          08-21-2024, 12:56 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
