SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
  • dmcabs
    • May 2023
    • 7
    Hey guys,
    I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
    This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
    FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
    I'm a bit rusty but still have ability to dig right down.
    I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about 5%.
    I found a few so decided to replace all electrolytic caps in the power supply and the Tcon board given the age of the tv.
    In the service menu the power on hours was almost 25,000hrs, so fair to replace all electrolytic caps.
    On the Tcon board there are 3 switching regulators that are filtered by SMD Ceramic caps. I have ordered these caps but have not replaced them yet.
    This would be the last section of total re-capping the TV (apart from anything on the CPU board which I have ignored so far).
    After the re-capping, the time between the intermittent display issues has lengthened significantly but not totally resolved.
    Has anyone had any experience with this model and issue?
    The AC ripple on the 3 switching regulators on the Tcon board are under 1%, but does not rule out ceramic cap faults.
    Any ideas guys?
    Thanks so much.
  • lotas
    • Jan 2016
    • 4710
    • Russia
    In this chassis, the BGA processor usually fails, requiring reballing of the BGA processor.
    And according to backlight errors, errors are written to the eeprom (if the number of “Lamp error” errors exceeds 5), the TV is blocked.
    • dmcabs
      • May 2023
      • 7
      Hey Lotas, thanks for the quick reply.
      Are you referring to the BGA processor on the CPU board or the Tcon board?
      Are you saying the solder joints under the BGA fail, or the BGA device itself fails and requires replacement?
      Regarding the "lamp error" counter exceeding 5 and the "TV is blocked", what do you mean it is blocked? The display still works, just intermittently drops out.
      • lotas
        • Jan 2016
        • 4710
        • Russia
        Yes, the CPU on the motherboard is destroying the bga soldering. If the backlight is not working properly, if you turn on the TV 5 times, then the 6th time it will not turn on, you need to change the backlight and reset the error codes.
        If it turns off, check the panel, disconnect the cables going from the T-con to the panel one by one and check if it turns off.
        • dmcabs
          • May 2023
          • 7
          Thank you for the information. Since the TV is quite old now, instead of reballing the BGA processor, I want to try just reflowing it first. Is this worth doing in your experience?
          I found that the thermal pad on the back of the BGA processor has been seeping silicone everywhere, on the back of the pcb and also through the vias under the processor and then under the processor and on the top of the pcb. In this situation if any connections to the processor have become slightly disconnected, the silicone oil will make conductivity worse. I rinsed under the processor with 100% isopropyl alcohol already in preparation for reflowing it.
          • Diah
            • Feb 2013
            • 6425
            what you did saw had nothings to do with BGA... since the set old the martial of main boards and soldering are different as now fays.. they can hold ext ern heat for example use your kuchen oven​ to 260 " heat it and put the board for 10 minute.. turmoil and don't move it till it cool down..... ye this is nor my way to write but its better than to scrap the TV before to try
            • dmcabs
              • May 2023
              • 7
              Thanks for the information. I agree the quality of manufacturing has reduced now days. Older equipment was made better.
              About the BGA, you said has nothing to do with it. What do you mean? What do you think the fault is?
              Should i still consider reflowing the BGA?
              • Diah
                • Feb 2013
                • 6425
                Originally posted by dmcabs
                I found that the thermal pad on the back of the BGA processor has been seeping silicone everywhere, t.
                regards to this.... however u need to give try for BGA
                • dmcabs
                  • May 2023
                  • 7
                  Thanks, I will reflow the BGA with proper flux for BGA and use SMD hot air rework station.
                  I powered on the TV today and now it will not turn on. It has two short red led flashes then off. Service manual says CPU communication error, so I would say you are right, it's the BGA.
                  • nomoresonys
                    • 12235
                    • U.S.
                    check some of the diy reflows on youtube, you need to get the chip to the right temp, too hot and can kill the chip, not hot enough then nothing happens. Best to bring the temp up gradually, some type of temp gauge is handy for that. Goal is to bring up temp gradually to melt solder, go another 30 seconds or so with same heat keeping the nozzle moving around the chip, back nozzle off gradually.
                    • dmcabs
                      • May 2023
                      • 7
                      Thanks for the tips! I have done lots of smd soldering by hand and using a hot air rework station, all for.small parts, but I have never reflowed a BGA.
                      I have a few type K thermocouples. I can use them to monitor temperature.
                      Should I also apply heat to the back side of the board?
                      I only have a metal hotplate, i guess this is better than nothing.
                      • 90Ninety
                        Crappy Vestel/Sharp LC-40FG3141K Set Backlight going off randomly
                        by 90Ninety
                        Hello
                        Model Code Sharp LC-40FG3141K
                        Firstly perhaps I should save myself the agony and throw this set out ? Then again I hate E-waste , or giving a person further headace in the far east or Agbogbloshie . So I digress to my last hope of fixing this pile of shite , with the dash of hope from your combined experiences
                        So this set is randomly turning off its backlight ( could be days, hours, minutes or seconds ) , my research suggests this maybe an over current protection , or leaky/faulty LEDS , or a bad LED driver circuit . So I opened it up , stabbed my Multi...
                        07-06-2022, 07:09 AM
                      • pcwhiz24
                        Lenovo IdeaPad 3 14ADA05 NVME keeps randomly disconnecting
                        by pcwhiz24
                        This issue has me stumped! I have this Lenovo IdeaPad and the SSD (NVME) keeps on randomly disconnecting. It'll stop being detected in BIOS randomly and when I turn it off and back on sometimes it'll detect again and boot up just fine...only to crash after a few minutes and either boot again or stop being detected.
                        Things I tried so far:
                        - Reset the CMOS by removing battery, held power buttons 60 seconds, all that jazz.
                        - BIOS is fully updated (had to use CHA341 because I bricked it the first time trying to update it)
                        - Tried multiple working NVME drives...
                        04-08-2025, 06:59 PM
                      • Joekhoe
                        Sharp Aquos Quattron LC-52LE835X Totally Dead, no output voltages
                        by Joekhoe
                        Hello all, I'm Joekhoe, a newbie here and ask your masters permissions and solutions for the problem i'm facing at the present.
                        I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
                        The replacement as follows:
                        1. IC7905 : TNY264PN (first found exploded)
                        2. Q7915 : BT169D (exploded too)
                        3. IC7901 : 1608B (controller ic)
                        4. IC7601 :...
                        09-17-2020, 05:52 AM
                      • advant
                        by advant
                        02-03-2020, 12:25 AM
                      • Jeryswan
                        LC-52LE81OUN Sharp Aquos turning off randomly.
                        by Jeryswan
                        I had a customer bring in their tv that shuts off randomly. The model # is LC-52LE81OUN. Aside from the television shutting off whenever it wants there doesn't appear to be any more symptoms. Any suggestions would be very much appreciated.
                        11-12-2020, 05:25 PM
