emerson 32" lc320em1
  • splitcrete
    • Dec 2012
    • 387
    • usa
    Re: emerson 32" lc320em1
    Yes check those out . unplug them all and put probes in the sockets of the transformers. They should all be I think 10% of each other.
    • splitcrete
      • Dec 2012
      • 387
      • usa
      Don't waste a lot of time and money on it. They are crap TVs.
        Inverter transformer HV windings.
        • selldoor
          Slow Learner
          • 7870
          Think we may be all wrong footed here.
          When he unplugs the main the back lights stay on
          Posts 1 and 12
          • splitcrete
            • Dec 2012
            • 387
            • usa
            I believe he is talking about the standby LED staying on. Post 1&12 says nothing about back light staying on.
            • splitcrete
              • Dec 2012
              • 387
              • usa
              #26
              budm posted better test points. Ohm those points.
              • CapLeaker
                Leaking Member
                • 8352
                All you can try to do is taking the main board and that other board on the bottom out of the game, rig the main power supply and the inverter up to force the power supply and the backlight on and see what happens. Problem is that the boards have cables coming out of everywhere and hard to see what is what. Next problem is even if you could figure it out the flat band ribbon are so damn small not funny. Not sure if I like to play around too much, when 360V DC are on the inverter board. I just fixed one that had a blown power supply. What a piece of junk design and I thought that one I had here was bad.
                • timmypeeps
                  • Jan 2015
                  • 26
                  Tested all the hv windings like in the picture all of them were .3 ohms.
                  • timmypeeps
                    • Jan 2015
                    • 26
                    If I remove this cable and this cable only the power will come on and the green light stays on. But without this cable the screen will not come on at all. Soon as I plug it in the tv will shut off and the red standby light comes on.
                    • timmypeeps
                      • Jan 2015
                      • 26
                      Sorry forgot the pic
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        Are you saying at any point the panel ( the screen not the led) lights up and stays on for more than a few seconds.
                          "Tested all the hv windings like in the picture all of them were .3 ohms." That does not look right, 0.3 Ohms or 0.3K Ohms, or 0.3M Ohms?
                          Check the resistance readings of the 3 MOSFET's pin combination:
                          1 & 2,
                          1 & 3
                          2 & 3
                          BTW, board is on;y $20.
                          http://www.shopjimmy.com/emerson-mag...verter-cba.htm
                          • timmypeeps
                            • Jan 2015
                            • 26
                            The screen will only come on for about 2 seconds. If I used the remote to turn it on and hold the volume - or + down it stays on about 4 or 5 sec and you can see the volume bar then it will shut off
                              So the backlights did come on then.
                              • timmypeeps
                                • Jan 2015
                                • 26
                                I changed all 3 of those mosfets with good ones I tested them before installing them. Thsted them on 200kohm setting . Retested them on 2000ohm setting an got 474 on the lowest and 486 on the highest
                                • timmypeeps
                                  • Jan 2015
                                  • 26
                                  Yes the back light does come on
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #37
                                    BUT only for a few seconds? this is very important which is why I am laboring
                                    the point
                                    • timmypeeps
                                      • Jan 2015
                                      • 26
                                      Not sure what your getting at selldoor?
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        We just need to establish for sure how long the back light /screen stays on.
                                        In post 12 you say
                                        If I disconnect a ribbon cable between the power supply and the video board it will turn on and stay on but no picture. That's the only wire I remove and it works without picture
                                        What will stay on? and how long for?
                                        • timmypeeps
                                          • Jan 2015
                                          • 26
                                          The powe board stays on and the power light stays on.
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light, but no sound
                                            by MOSSEP
                                            Hi
                                            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                            I have already tried replacing all of the...
                                            01-26-2025, 08:33 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light but no audio
                                            by MOSSEP
                                            Hi
                                            01-26-2025, 08:18 AM
                                          • lcdcaps1
                                            820-2610-A Sys onewire help, no green light. Please help from the gurus
                                            by lcdcaps1
                                            Hi
                                            I have an 820-2610-A motherboard that has no green light.
                                            I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                            From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                            The sys onewire circuit on this model and others is more involved
                                            I was hoping if anyone knows about this and how it works, can reply and let me know
                                            I know this is an old model but I am sure there are people who still works on these or knows about them
                                            I get 1.1v on the C7771 capacitor and will replace...
                                            11-06-2023, 01:28 PM
                                          • esqmooo
                                            HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
                                            by esqmooo
                                            I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
                                            03-07-2025, 05:55 AM
                                          • blazzelia
                                            MBP A1286 820-2915 green light only, no start
                                            by blazzelia
                                            Hi guys,
                                            I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating...
                                            09-30-2024, 07:20 AM
