MBP A1286 820-2915 green light only, no start
  • blazzelia
    • Nov 2019
    • 40
    Hi guys,
    I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating quite decently.
    About an year ago the laptop died. It was not charging the battery anymore (green light only) and, when a start was attempted, a click sound was heard from the inside. I had no time then to look into it but now I would actually need it again for one of the projects I'm working on so I'm tempted to fix it if possbile. I bought some donor mobos from the flea market and I think I have a good chance to fix it if I get the proper direction from someone with experience in Apple laptops. I'm good with replacing chips, I have the proper tools, however I'm not familiar with Apple stuff.
    So, as I said, green light only, the battery is dead (0.4V on it), laptop not starting, no fans moving, not even the click noise I heard a year ago. Obviously, I did some reading and start measuring some voltages but at some point I did not know where to go next. I know there is a pulsating voltage somewhere where it isn't supposed to be, but I don't remember the name of the rail. I guess that, at some point, it's going to show up again...
    Now, if someone has the amability to help me with it, I would appreciate it.
    Thanks,
    B
  • mon2
    • 14685
    Measure and share the voltage to ground measurements of:
    PPBUS_G3H ; F7000 (check both sides)
    SMBUS_SMC_BSA_SCL ; at the battery connector
    SMBUS_SMC_BSA_SDA
    Use DC volts mode on your meter (not diode mode).
    • blazzelia
      • Nov 2019
      • 40
      PPBUS_G3H - 12.5V
      F7000 - I only see F7040 and F7041 in my board schematic, both connected to PPBUS_G3H, both ok, 12.5V on both ends
      SMBUS_SMC_BSA_SCL - 3.4V
      SMBUS_SMC_BSA_SDA - 3.4V​
      Best
      • mon2
        • 14685
        Are you using the original 85W power adapter?
        • blazzelia
          • Nov 2019
          • 40
          Yes
          • mon2
            • 14685
            Share the voltage to ground of ALL_SYS_PWRGD. Use DC volts mode on your meter (not diode mode).
            • blazzelia
              • Nov 2019
              • 40
              ALL_SYS_PWRGD - 0V
              • mon2
                • 14685
                This implies you have at least one power rail that is not good. Go through the power rail tree that is being monitored to determine which rail is failing.
                • blazzelia
                  • Nov 2019
                  • 40
                  PP3V3_S5 - oscillating
                  PP3V3_S0 - oscillating
                  PP1V05_S0 - 0V
                  P1V5S0_PGOOD - 0V
                  P1V8S0_PGOOD - 0V
                  P5VS3_PGOOD - 0V
                  CPUVCCIOS0_PGOOD - 0V
                  PVCCSA_PGOOD - 0V
                  So I went on the PP3V3_S5 line which comes out of Q7260 through L7260 and I'm lost here ... P3V3S5_TG is oscillating, PPVIN_S5_HS_OTHER_ISNS is a solid 12.5V, P3V3S5_DRVL is oscillating.
                  • kevingill
                    • Jun 2013
                    • 152
                    • England
                    What does PP3V3_S5 measure in resistance to ground?
                    • blazzelia
                      • Nov 2019
                      • 40
                      It starts with a few MOhms, then quikly drops and stabilize around 19 KOhms.
                      • kevingill
                        • Jun 2013
                        • 152
                        • England
                        Do a check on all the power rails to see which one isn't coming up. The critical ones are in the schematic.
                        Start at S5, then S4, etc.
                        • blazzelia
                          • Nov 2019
                          • 40
                          Here they are:
                          PP5V_S5 - osc
                          PP5V_SUS - osc
                          PP5V_S3 - 0
                          PP5V_S0 - 0
                          PPBUS_G3H - 12.5
                          PPVIN_S5_HS_COMPUTING_ISNS - 12.5
                          PPVIN_S5_HS_GPU_ISNS - 12.5
                          PPVIN_S5_HS_OTHER_ISNS - 12.5
                          PPDCIN_G3H - 16.7
                          PP3V42_G3H - 3.4
                          PPVRTC_G3H - 3.4
                          PP3V3_S4 - osc
                          PP3V3_SUS - osc
                          PP3V3_S5 - osc
                          PP3V3_S3 - osc
                          PP3V3_S0 - osc
                          PP3V3_T29 - 0
                          PP1V05_T29 - 0
                          PP15V_T29 - 0
                          PP1V8_S0 - 0
                          PP3V3_S0GPU - 0
                          At this point I stopped with the 1.8V/1.5V/1.2V/1.05V rails ...
                          osc = oscillating up and down
                          • mon2
                            • 14685
                            Remove all power. Meter in resistance mode.
                            What is the resistance to ground (in ohms) of these osc rails?
                            PP5V_S5 - osc
                            PP5V_SUS - osc​
                            • blazzelia
                              • Nov 2019
                              • 40
                              PP5V_S5 - 100K
                              PP5V_SUS​ - 290K
                              • mon2
                                • 14685
                                Not shorted. Check the EN pins on the regulator IC that creates the above rails. Are they also pulsing? Check if you are missing any current sense resistors which can result in the regulator believing there is a too high of a current draw since the feedback is missing and will power cycle the rail(s).
                                • kevingill
                                  • Jun 2013
                                  • 152
                                  • England
                                  It's looks as though it's trying to get to S0 with PP3V3_S0 pulsing. However, PP5V_S3 is at 0. I'd take a good look around U7201 to find out the issue.
                                  Have you removed all non essential cables/RAM/etc?
                                  • blazzelia
                                    • Nov 2019
                                    • 40
                                    Two of the EN signals also pulsing, one in 0V. The current sensing resistors are fine.
                                    • blazzelia
                                      • Nov 2019
                                      • 40
                                      RAM was still in but the signals are the same without it.
                                      I pulled C7205 to measure it - 9.6uF. When I measure the voltage on it (PP5V_S5) there is a clicking noise - I guess it's comming from one of the inductors from the back of the board.
                                      • kevingill
                                        • Jun 2013
                                        • 152
                                        • England
                                        Have you replaced C9560 BTW?
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:33 AM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light but no audio
                                          by MOSSEP
                                          Hi
                                          01-26-2025, 08:18 AM
                                        • lcdcaps1
                                          820-2610-A Sys onewire help, no green light. Please help from the gurus
                                          by lcdcaps1
                                          Hi
                                          I have an 820-2610-A motherboard that has no green light.
                                          I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                          From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                          The sys onewire circuit on this model and others is more involved
                                          I was hoping if anyone knows about this and how it works, can reply and let me know
                                          I know this is an old model but I am sure there are people who still works on these or knows about them
                                          I get 1.1v on the C7771 capacitor and will replace...
                                          11-06-2023, 01:28 PM
                                        • jheunne
                                          A1466 macbook no boot green to orange light help
                                          by jheunne
                                          i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
                                          in first image there is 0v out for lcd
                                          https://ibb.co/5XppmpkH
                                          in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
                                          https://ibb.co/fdJkbJs8
                                          06-10-2025, 10:52 PM
                                        • techrepairheide
                                          MacBook Pro (A1502 / 820-3476-A) - No orange/green light and no power
                                          by techrepairheide
                                          Hello again,
                                          got an MacBook Pro from 2015, model A1502 and motherboard version 820-3476-A.
                                          Device died over night on charger.
                                          Currently I did the follow things:
                                          1. Checked visuell the board, test with another MagSafe-Charger and with another DC-IN-board too
                                          2. Measured 16,5V on ​PP18V5_DCIN_FUSE but 0V on ADAPTER_SENSE and 0V on PP_3V42_G3H and 0V on PPBUS_G3H but 16,5V goes to U7090
                                          3. Because of corrosion and bad resistor values I changed these components: U7090 / C7094 / C7095 / R7095 / R7096 / L7095 / C7099 -> But further...
                                          01-26-2025, 05:37 AM
