Monitor Audio RSW12 - Green light, but no sound
  • MOSSEP
    • Jan 2025
    • uk
    Hi
    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
    I have already tried replacing all of the capacitors after reading this post - https://www.badcaps.net/forum/troubl...dio-rsw-12-sub
    Since replacing them the green light now comes on straight away, but I no longer have any sound from it. All of my external connections are ok, and the internal plugs are all connected, so Im assuming I may have done something when replacing the capacitors?
    Does anyone have any idea of what I could check?
    Thanks for any advice!​
  • dobrykamil
    • Jun 2013
    • 62
    Does the speaker relay kicks in?
    • MOSSEP
      Monitor Audio RSW12 - Green light but no audio
      by MOSSEP
      Hi
      I have already tried replacing all of the...
      01-26-2025, 08:18 AM
    • lcdcaps1
      820-2610-A Sys onewire help, no green light. Please help from the gurus
      by lcdcaps1
      Hi
      I have an 820-2610-A motherboard that has no green light.
      I have noticed is when I do a SMC reset the light on the Magsafe blinks.
      From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
      The sys onewire circuit on this model and others is more involved
      I was hoping if anyone knows about this and how it works, can reply and let me know
      I know this is an old model but I am sure there are people who still works on these or knows about them
      I get 1.1v on the C7771 capacitor and will replace...
      11-06-2023, 01:28 PM
    • arctor
      samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
      by arctor
      hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
      04-26-2025, 05:22 AM
    • matthewmcconaughey
      I need help with my friend Sony GDM-FW900 24” CRT
      by matthewmcconaughey
      Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
      I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
      1. It started with a bright and greenish picture upon starting a cold monitor.
      2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
      05-16-2023, 03:15 PM
    • jheunne
      A1466 macbook no boot green to orange light help
      by jheunne
      i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
      in first image there is 0v out for lcd
      https://ibb.co/5XppmpkH
      in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
      https://ibb.co/fdJkbJs8
      06-10-2025, 10:52 PM
