820-2610-A Sys onewire help, no green light. Please help from the gurus
  • lcdcaps1
    • Oct 2011
    • 322
    Hi
    I have an 820-2610-A motherboard that has no green light.
    I have noticed is when I do a SMC reset the light on the Magsafe blinks.
    From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
    The sys onewire circuit on this model and others is more involved
    I was hoping if anyone knows about this and how it works, can reply and let me know
    I know this is an old model but I am sure there are people who still works on these or knows about them
    I get 1.1v on the C7771 capacitor and will replace this when I get a green light but, My first priority is to get a green light
    I have been doing some voltage checks
    I get the 16V rail and the 8.4V rail.
    When it comes to the sys onewire rail I get nothing.
    I will really appreciate it very much
    Thanks all
  • mon2
    • 14677
    Re: 820-2610-A Sys onewire help, no green light. Please help from the gurus
    Are you using a known good REAL 85W charger?
    You have the power on chime? Display working?
    https://boards.rossmanngroup.com/thr...-turn-on.3703/
    • lcdcaps1
      • Oct 2011
      • 322
      Thanks for the reply
      Yes using a genuine charger
      No green light on magsafe
      no display
      I am sure something is wrong with the sys onewire circuit but need some help who knows the circuit well
      As it is an old circuit not many people know about it or work on them
      but i am hoping someone that knows the circuit can reply and help me
      please
      • reformatt
        • Feb 2020
        • 1510
        This is an older circuit compared to later models but the principles are still the same.
        SYS_ONEWIRE is a bidirectional bus between the charger and the SMC. So regardless of the intermediate circuitry, the SMC needs to have PP3V42_G3H as valid, SMC_RESET_L from U5000 is high. You can always have a dead SMC on occasion.
        SMC_AC_BCOK (=CHGR_ACOK) from U7000 also needs to be high. This will allow PP18V5_DCIN_CONN to pass via Q6910. This in turn powers the overvoltage detection op amp and enable FET Q6915. This in turn switches on dual FET Q6920 to pass your SYS_ONEWIRE data bus to the charger.
        In addition, 15" machines need 85W chargers. SMC determines via SYS_ONEWIRE the charger that is connected, and won't assert PM_BATLOW_L if it's underrated. So you won't get PM_SLP_S4_L going high.
        • lcdcaps1
          • Oct 2011
          • 322
          Do you still work on these old circuits, please
          I know the SMC is working because when i try and do smc reset the magsafe blinks
          • reformatt
            • Feb 2020
            • 1510
            Correlation does not imply causation. Make proper measurements and report what each are based on the circuit description I gave you.
            And I don't work on these older machines anymore. Unless an owner has a particular emotional attachment to it, no one wants to spend any money on them. In addition, they only run very old versions of MAC OS and no longer supported by Apple or anyone else. Google for example no longer updates their Chrome browsers on High Sierra anymore so most customers are complaining about web pages not displaying correctly. You either run Core Legacy Patcher, Linux or Chrome OS Flex.
            The other issue with putting in time on these very old machines is that the likelihood of them bouncing on you is pretty high. A white 2009 macbook I did last year came back 3 times in a 6 month period, each with different faults. Customers always try to wrangle it as a warranty job. Just not worth the effort.
            • lcdcaps1
              • Oct 2011
              • 322
              Thanks for your reply
              This machine is close to me that is why i want to get it going
              I know that it has life in it and it is only the one wire circuit that is not working
              I just did some measurements now
              I jumped the power on pads and got
              adapter sense 0v
              smc reset l 3.4v
              • reformatt
                • Feb 2020
                • 1510
                Sys_onewire=?
                Smc_bc_acok=?
                Pp18v5_dcin_onewire=?
                Onewire_en=?
                • lcdcaps1
                  • Oct 2011
                  • 322
                  Sys_onewire=?
                  Smc_bc_acok=?
                  Onewire_en=?
                  I will be getting these measurements shortly
                  • lcdcaps1
                    • Oct 2011
                    • 322
                    Hi
                    Below are the voltages i have got so far
                    My CHGR_ACOK voltage seems low
                    If someone can verify this. I will appreciate it very much
                    PPBUS_G3H 08.39v
                    PPBUS_CPU_IMVP_ISNS 08.39v
                    PPDCIN_G3H 16.63v
                    PP3V42_G3H 03.40v
                    PP5V_S3 0v
                    PP5V_S0 0v
                    F7040 08.38V
                    F6905 16.63V
                    D6900, PIN 1 0V
                    U6915 PIN 1 08.29V
                    U6915 PIN 2 GND
                    U6915 PIN 3 0V
                    U6915 PIN 4 08.15V
                    U6915 PIN 5 16.62V
                    Q6920, PIN 1 source 0V
                    Q6920, PIN 2 gate 0v
                    Q6920, PIN 3 drain 0v
                    Q6920, PIN 4 source 0v
                    Q6920, PIN 5 gate 0v
                    Q6920, PIN 6 drain 3.4v
                    CHGR_ACIN 3.9V
                    PPDCIN_G3H 16.62V
                    CHGR_ACOK 3.2V
                    L6995 PIN 2 3.4V
                    • lcdcaps1
                      • Oct 2011
                      • 322
                      Here are some more measurements
                      PPBUS_G3H 08.39v
                      PPDCIN_G3H 16.63v
                      PP3V42_G3H 03.40v
                      PP5V_S3 0v
                      PP5V_S0 0v
                      F7040 08.38V
                      F6905 16.63V
                      D6900, PIN 1 0V
                      U6915 PIN 1 08.29V
                      U6915 PIN 2 GND
                      U6915 PIN 3 0V
                      U6915 PIN 4 08.15V
                      U6915 PIN 5 16.62V
                      CHGR_ACIN 3.9V
                      PPDCIN_G3H 16.62V
                      CHGR_ACOK 3.2V
                      L6995 PIN 2 3.4V
                      pin 1 D6905 16.46v
                      pin 2 D6905 08.39v
                      pin 3 D6905 16.16v
                      Pin 1 L6995 3.413v
                      Pin 2 L6995 3.409v
                      pin 1 J6900 16.63v
                      Pin 2 J6900 16.63v
                      pin 2 of Q6910 gate 6.68v
                      Q6910 pin 1 and pin 2 ressistance 467.3k ohms
                      Q6915 pin 1 0v
                      Q6915 pin 2 3.2v
                      Q6915 pin 3 0v
                      Q6915 pin 4 0v
                      Q6915 pin 5 8.15v
                      Q6915 pin 6 0v
                      From My reading and looking at my measurements
                      The transistors are not working
                      I read that U6915 screws up and kills the transistors and should replace everything in one go
                      how can i be sure U6915 is good or not
                      thanks
                      • lcdcaps1
                        • Oct 2011
                        • 322
                        Hi
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          U6915 not doing its job as a comparator, should pull pin 4 low when voltage on pin 3 is lower than voltage on pin 1.
                          • lcdcaps1
                            • Oct 2011
                            • 322
                            Thanks for the reply piernov
                            Really appreciate it very much
                            Do I replace U6915 as well as the transistors
                            The reason I am asking this is because I read that one blows the other and this keeps on happening
                            Thanks again
                            • reformatt
                              • Feb 2020
                              • 1510
                              U6915 is open collector. I can't see how it would destroy Q6915. It's supposed to remove the bias from Q6915 by turning on when ONEWIRE_ESD is less than ONEWIRE_DCIN_DIV.
                              When Q6915 is off, then Q6920 is turned on for SYS_ONE_WIRE.
                              Would seem U6915 is faulty.
                              • MOSSEP
                                Monitor Audio RSW12 - Green light, but no sound
                                by MOSSEP
                                Hi
                                Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                I have already tried replacing all of the...
                                01-26-2025, 08:33 AM
                              • MOSSEP
                                Monitor Audio RSW12 - Green light but no audio
                                by MOSSEP
                                Hi
                                01-26-2025, 08:18 AM
                              • blazzelia
                                MBP A1286 820-2915 green light only, no start
                                by blazzelia
                                Hi guys,
                                I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating...
                                09-30-2024, 07:20 AM
                              • jheunne
                                A1466 macbook no boot green to orange light help
                                by jheunne
                                i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
                                in first image there is 0v out for lcd
                                https://ibb.co/5XppmpkH
                                in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
                                https://ibb.co/fdJkbJs8
                                06-10-2025, 10:52 PM
                              • techrepairheide
                                MacBook Pro (A1502 / 820-3476-A) - No orange/green light and no power
                                by techrepairheide
                                Hello again,
                                got an MacBook Pro from 2015, model A1502 and motherboard version 820-3476-A.
                                Device died over night on charger.
                                Currently I did the follow things:
                                1. Checked visuell the board, test with another MagSafe-Charger and with another DC-IN-board too
                                2. Measured 16,5V on ​PP18V5_DCIN_FUSE but 0V on ADAPTER_SENSE and 0V on PP_3V42_G3H and 0V on PPBUS_G3H but 16,5V goes to U7090
                                3. Because of corrosion and bad resistor values I changed these components: U7090 / C7094 / C7095 / R7095 / R7096 / L7095 / C7099 -> But further...
                                01-26-2025, 05:37 AM
