Monitor Audio RSW12 - Green light but no audio
  • MOSSEP
    • Jan 2025
    • uk
    Hi
    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
    I have already tried replacing all of the capacitors after reading this post - https://www.badcaps.net/forum/troubl...dio-rsw-12-sub
    Since replacing them the green light now comes on straight away, but I no longer have any sound from it. All of my external connections are ok, and the internal plugs are all connected, so Im assuming I may have done something when replacing the capacitors?
    Does anyone have any idea of what I could check?
    Thanks for any advice!
    • Jul 2011
    • 6070
    Please post all of the boards in this unit front and back of each board
    • MOSSEP
      Monitor Audio RSW12 - Green light, but no sound
      by MOSSEP
      Hi
      I have already tried replacing all of the...
      01-26-2025, 08:33 AM
    • ItepK
      Panasonic TX-P42G30E green light blinking, no video, no audio
      by ItepK
      Hey everyone!
      I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
      This post describes my entire troubleshooting process of this TV.
      When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
      I've taken the unit apart, and I've started to check some voltages:
      • On the P11 connector, there is 15V DC only for a brief moment, then it goes
      12-22-2023, 05:06 AM
    • lcdcaps1
      820-2610-A Sys onewire help, no green light. Please help from the gurus
      by lcdcaps1
      Hi
      I have an 820-2610-A motherboard that has no green light.
      I have noticed is when I do a SMC reset the light on the Magsafe blinks.
      From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
      The sys onewire circuit on this model and others is more involved
      I was hoping if anyone knows about this and how it works, can reply and let me know
      I know this is an old model but I am sure there are people who still works on these or knows about them
      I get 1.1v on the C7771 capacitor and will replace...
      11-06-2023, 01:28 PM
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • matthewmcconaughey
      I need help with my friend Sony GDM-FW900 24” CRT
      by matthewmcconaughey
      Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
      I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
      1. It started with a bright and greenish picture upon starting a cold monitor.
      2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
      05-16-2023, 03:15 PM
