emerson 32" lc320em1
  • timmypeeps
    • Jan 2015
    • 26
    I have a emerson lc320em1 that flashes a green light the screen comes on for about 2 seconds then shuts off and the red standby light comes on. all the caps look good. If i unplug the video board the tv still flashes the green light 10 or 12 times but it stays on. Any help would be greatly appreciated.
  • timmypeeps
    • Jan 2015
    • 26
    Re: emerson 32" lc320em1
    Hello?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Pictures of all the boards please and do you have a Digital multimeter ?
      • AFajitas
        • 183
        This was actually the first TV I fixed in my foray into TV troubleshooting. Mine wasn't powering on at all. There are 4 or 5 diodes on the power supply that are notorious for going bad, could be your issue as well.
        • timmypeeps
          • Jan 2015
          • 26
          Trying to upload some pics of the boards but I keep getting a server error. I will load some by the end of the day. I do have a dmm but it's dcm it will test ac, dc, continuity and amps.
          • timmypeeps
            • Jan 2015
            • 26
            I do have 2 new boards for the tv but they are not an exact match so they don't work but I was thinking I have to good doner boards they came out of a tv with a cracked screen but they did work.
            • AFajitas
              • 183
              Found this today, not sure if it helps.
              Seems to be the same model.
              • timmypeeps
                • Jan 2015
                • 26
                Looks identical on the outside but the internals look different. It could be the same issue I will test the items he described in his article. Thanks for the help
                • timmypeeps
                  • Jan 2015
                  • 26
                  AFAJITAS do you remember the ones that you replaced?
                  • timmypeeps
                    • Jan 2015
                    • 26
                    Still can't figure this tv out . Still turns on for 2 sec and shuts off again. Any help would be great thanks.
                      • 12273
                      • U.S.
                      could be a bad capacitor.
                      • timmypeeps
                        • Jan 2015
                        • 26
                        None of the caps look bad and if any were in question I replaced them. If I disconnect a ribbon cable between the power supply and the video board it will turn on and stay on but no picture. That's the only wire I remove and it works without picture
                        • timmypeeps
                          • Jan 2015
                          • 26
                          This seams to be a common problem with this model tv. I find it hard to believe no one has figured it out
                          • MagicSmoke
                            • Feb 2011
                            • 275
                            Need pics and P/N's of your boards. I have one of these that has the PSU/Backlight inverter all in one.
                            There were numerous failed diodes, resistors, and a mosfet. When psu failed it damaged mainboard also.
                            I got lucky and found both boards from a seller on ebay.
                            • timmypeeps
                              • Jan 2015
                              • 26
                              Here's some pics of the boards
                              • timmypeeps
                                • Jan 2015
                                • 26
                                I have 2 boards from another tv but they aren't an exact match so they don't work. I was hoping to use parts on the new boards to fix the original's
                                • splitcrete
                                  • Dec 2012
                                  • 387
                                  • usa
                                  Check the inverter wires for shorts circled in red.
                                  • splitcrete
                                    • Dec 2012
                                    • 387
                                    • usa
                                    Did you ohm out the inverter transformers ? May be a bad one or two...
                                    • timmypeeps
                                      • Jan 2015
                                      • 26
                                      No shorts, tested all one at a time and they all light up individually and all at the same time. I have not done an ohm test on the inverter transformers. Your talking about the black square with copper coils right.
                                      • timmypeeps
                                        • Jan 2015
                                        • 26
                                        ? I think I'm right
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:33 AM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light but no audio
                                          by MOSSEP
                                          Hi
                                          01-26-2025, 08:18 AM
                                        • lcdcaps1
                                          820-2610-A Sys onewire help, no green light. Please help from the gurus
                                          by lcdcaps1
                                          Hi
                                          I have an 820-2610-A motherboard that has no green light.
                                          I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                          From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                          The sys onewire circuit on this model and others is more involved
                                          I was hoping if anyone knows about this and how it works, can reply and let me know
                                          I know this is an old model but I am sure there are people who still works on these or knows about them
                                          I get 1.1v on the C7771 capacitor and will replace...
                                          11-06-2023, 01:28 PM
                                        • esqmooo
                                          HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
                                          by esqmooo
                                          I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
                                          03-07-2025, 05:55 AM
                                        • blazzelia
                                          MBP A1286 820-2915 green light only, no start
                                          by blazzelia
                                          Hi guys,
                                          I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating...
                                          09-30-2024, 07:20 AM
