Any use for cracked panels?
  • AFajitas
    • Dec 2014
    • 183
    I just started acquiring cracked LCD and plasmas TV's lately and should have a steady flow going forward. I have just been removing the modular parts to resell them, and any scrap metal. Are the back lights worth harvesting? Is there anything else inside the panel that is worth removing? I am a big fan of recycling and reusing things when possible. I have been putting what's left of the TV on the curb and someone always takes them, but I'm guessing they ultimately end up in a land fill somewhere.
    I also have a large box of built in speakers from TV's, as their resale value is terrible. I've been thinking about removing the magnets and scrapping what's left.
    I managed to place high on Google for "sell broken lcd/plasma" and similar search terms. If any of you guys live in a metro area and want me to send some broken tv traffic your way, hit me up. This forum has already been a great resource for me and I'd like to give something back when I can.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Any use for cracked panels?
    larger ones (60"+), remove the cracked LCD, leaving only the backlight & diffuser. Using the inverter to light it, they are very bright white light. I've seen quite a few guys make pool table lights out of them.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      its fun to put cleaning agents in the cracked screens, makes lots of trippy effects.
      or poke the screen and make the lines change. you could take them out on the firing range and look so rich that you use LCD screens for target practice! or see what a high voltage high current transformer such as the one that drives the magnetron in a microwave oven does to them, i heard plasmas look cool!
      Follow the white rabbit.
        I turn TV with broken LCD panel into light table, or light sources for taking pictures.
          I use the bulbs from them to repair sets with bad bulbs, though it's sometimes hard to get one that match, usually if the size/length and connectors are identical it'll work well.
          Good stress relief to put a few dents in the LCD, after everything good is removed.
          • zomi
            • Nov 2011
            • 509
            use them to switch tv's at night
            with loved ones to play pranks lol
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              As stated above, pool table lights are a good idea. Also you can make nice luminous signs for advertising whatever.
              A working TV? How boring!
              • TechOp
                • Oct 2013
                • 21
                I like the way you think....Hooora
                sigpic
                Anything can be fixed with enough TIME and enough MONEY
                • eccerr0r
                  Sell or Shim Solar panels?
                  by eccerr0r
                  Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                  However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                  So now what to do with these small panels?
                  I could sell them...
                  Or I could shim them....
                  03-29-2025, 01:07 AM
                • earz
                  Removing large LCD panels
                  by earz
                  I'm curious what techniques everyone uses to remove/move/lift large LCD TV panels when doing backlight repairs. I typically use two large suction cups, but lifting a 65" panel off a LG a month ago and I got a little too close to the wall and accidentally crammed the corner of the panel into the wall (gouged the drywall even) which resulted in a single crack all the way across the panel. Thankfully I just do this as a hobby on TV's that I scrounge up to repair and sell, so I didn't have to make a dreaded phone call to a customer.
                  That incident got me thinking about making some...
                  05-19-2021, 10:42 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • wasyl
                  HH51R AN515-46 LA-M001P cracked MPS2207 MP2845A
                  by wasyl
                  As I mentioned i have cracked component found many on aliexpress MP2845A but MPS2216 someone know would it fit ?
                  Link to aliexpress here...
                  09-15-2025, 07:12 AM
                • howardc64
                  Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                  by howardc64
                  TV was fixed just after removing Samsung's rear snap cover.
                  This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                  Maybe PSU->backlight connector didn't have a good contact?...
                  07-23-2025, 12:34 AM
