Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
So now what to do with these small panels?
I could sell them...
Or I could shim them. Meaning, add more cells to the chain. Unfortunately I don't know if this is worth it. The 36-cell panel seems okay as it's half of the 72-cell panels, so the 32-cell needs to be shimmed with 4 extra cells and seriesed with the 36 to make 72, but the 30-cell panels would need a whopping 12 additional cells to be shimmed up to the 72.
Is it worth to DIY build a 4- and a 12-cell panel? Seems individual cells are $2 a piece or so, not sure where to get them cheaper, so a 12-cell panel is up to $24 and I'll need to solder and seal them some way such that they won't crack.
So, sell or shim?
So, sell or shim?
