  • ygorsan
    • Jul 2025
    • 10
    • Brasil
    🧩 Problem Summary:
    • I did a factory reset, and it didn’t help.
    ⚙️ Troubleshooting so far:
    • Verified no damage or oxidation on the main board.
    • Completely disconnected the button board (confirmed no connection to KEY_IN or IR_IN).
    • Tried disabling potential ADC input by removing the flat cable that includes KEY_IN.
    • Planning to remove the pull-up resistor on the KEY_IN line to isolate any residual voltage or short.
    • Also considering checking ESD/TVS diodes on the same line, as well as the 3.3V LDO that powers the ADC input circuit.
    ❓ The main question:
    • Could the KEY_IN or ADC input circuit still generate phantom signals even after removing the flat cable?
    • Would removing the pull-up resistor and/or TVS diodes actually eliminate the false signal?
    • Is there any known issue or workaround specific to this LG board (EBU66792103)?
    • Any chance the SoC itself is interpreting noise due to a faulty capacitor, LDO, or grounding issue?
    Any help, schematics, or technical advice would be really appreciated. I’m trying to avoid replacing the entire main board unless absolutely necessary.
    Thanks in advance!
ID:	3692331 Click image for larger version
ID:	3692326 Click image for larger version
ID:	3692327 Click image for larger version
ID:	3692329 Click image for larger version
ID:	3692330 Click image for larger version
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
