Removing large LCD panels
  • Storyteller12
    • Jun 2020
    • 625
    Re: Removing large LCD panels
    [QUOTE=KYBOSH;1193819]When you say you use your hands do you mean you lift it and grip it vertically (like a suitcase) or horizontally (like you would carry an extra extra large pizza)?
    Both. Smaller screens up to 65” I can do like a “pizza” as you say. 75-86” I stand vertically and let them kinda fall out as I hold them.
    • Chungalin
      • Jul 2014
      • 423
      • Spain
      I thought that my method of disassembling the panel with LCD screen looking down laying on the table was safe, until today. It’s very safe for disassembling, but reassembly can be catastrophic, because you don’t see how the LCD glass aligns with the backlight chassis guides. This is what has happened to a Samsung UE48JU6060K with a LSF480FN05-K04 LCD cell (attached image). When reassembling the TV, the glass was trapped by the black guide and cracked when pressed against the front bezel. Now that side of the screen is darker and has motion artifacts.
      So now I face either to stop repairing anything that implies opening panels larger than 40" (which basically means leaving the business), or either to find another way to disassemble/reassemble them.
      Suction cups seem to be risky and can produce mura effect or even break the glass due to excess of force. What do they use at factories to assemble the TVs? I guess that they use suction cups connected to a vacuum pump with controlled pressure.
      What about a set of smaller and simpler suction cups attached to a structure?
      I’m only interested in solutions that can be performed by a single person, because I work alone and nobody can help me. I’ve already ruled out TVs larger than 55", because I can understand that a single person cannot safely lift a 65" glass.
      • Storyteller12
        • Jun 2020
        • 625
        I work by myself also with no help. And only broken screen with suction cups that failed.
        Personally I don’t work on anything smaller than 50” as there’s just no money to be made for me.
        Every screen is different. Some have no bezel and are glued. Some lift right out.
        You just have to figure out what works best for you and what you’re comfortable with.
        • Chungalin
          • Jul 2014
          • 423
          • Spain
          https://www.youtube.com/watch?v=_-cKfX3WmSM
          In this video we can see a chinese assembly factory of LCD TV. At minute 10:00 there's a contradictory view: first, a worker grabs a large LCD cell by hand and places it over a light table for testing, and after that, a machine with about 12 computer controlled small suction cups moves the cell over a pre-mounted backlight. Before that, it rotates 90 degrees to let a worker peel a protective sheet.
          In attached picture we can see a cheap chinese tool with simple suction cups. Anyone uses this?
          • KYBOSH
            • Oct 2011
            • 581
            • Unknown
            I believe the panel she is handling still has protective film on it. Possibly both sides. That film may give the LCD increased rigidity so I can be handled as shown. At 10:45 you can see the film being removed prior to being assembled into the display assembly.
            • zezone
              • Jun 2022
              • 4
              • Italy
              #26
              has anyone tried this method? The guy in the video uses duct tape to lift the panel. I want to change the LED strips on my 48" TV, but I don't have suction cups, and lifting the panel with my hands from below, like pizza, makes me very nervous.
              https://youtu.be/pUIKa7QSEO8?t=264
              • sigmeyer
                • Feb 2020
                • 157
                • Serbia
                #27
                I use the big double suction cup technique . Sometimes you will get like a circle mark on the screen if it has been on the for a long time, but it goes away in a short time. I always clean the sdie of diffusor that points to the leds , because it is known there for dust to settle. Also when putting back the screen , check for fitment on every corner , make sure the plastic saddle is clipped all the way around , and then you can put the bezzle on the screen. Pretty straight forward , i made a video showing the full process with some advices here and there , but i still havent posted it. Also i would prefer to have an air compressor nearby or some elctrical blower to clean before putting back the screen.
                • kiko1
                  • Apr 2016
                  • 48
                  • croatia
                  #28
                  this ones are perfect...easily lifts 50" to 60" panels. Larger I did not try but I cannot see any problem.
                  • sintv
                    • Feb 2015
                    • 37
                    • scotland
                    #29
                    2 suction cups and put to the side of chassis - my bench is long enough for that. Before cups I had large piece if cardboard, Id lift a corner and slide the cardboard in.
                    • NolesFan
                      Can LED panels be used from different TV's ( or the internals to the panel )?
                      by NolesFan
                      I have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you
                      06-23-2025, 09:19 AM
                    • Storyteller12
                      QN55Q60R Service Menu Panel Help
                      by Storyteller12
                      I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                      I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                      I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                      the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                      01-13-2024, 01:57 PM
                    • Helikvar
                      Hisense 58A6KV
                      by Helikvar
                      No picture ,tv appears to turn on and off using remote as standby led goes from red to nothing when on and red again when off
                      . Backlights also light up when tv is powered on.
                      Removing panel ribbon cable from left side screen still dark.
                      Removing panel ribbon cable from right side the right panel is white and left panel is dark but within a few seconds the left panel has a large green vertical bar and beside it many thin red lines.This whole screen dims down to dark within a few seconds and the right side slowly turns white again.
                      . Tcon gets 12 volt
                      . Tried taping...
                      02-21-2025, 03:52 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • maneatingmonkey
                      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                      by maneatingmonkey
                      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                      03-27-2024, 07:17 AM
