Insignia NS-37D20SNA14 Backlight going out. Flickering! Help!
  • youngkenzie
    • 20
    Re: Insignia NS-37D20SNA14 Backlight going out. Flickering! Help!
    What should i do next?
    • youngkenzie
      • 20
      Whats next?
      • CapLeaker
        Leaking Member
        • 8352
        I this case, there is no short or anything like that in the PS / LED driver, so fix that what you know is broken (the caps). I'd be changing those 3 caps C523, 524 and 525 and see if that problem went away. Caps are cheap.
        • youngkenzie
          • 20
          The caps are 47uf 100v High Temp Radial. Having 0 luck locally. Looks like I will be getting them shipped.
          • youngkenzie
            • 20
            Caps are here. Replacing them now wish me luck!
            • youngkenzie
              • 20
              Ok caps replaced still no screen. Any other directions? ill post my pictures of the work i did maybe i didnt do it right...Plz help!
              • CapLeaker
                Leaking Member
                • 8352
                Back to the X602 connector. There should be something like 30V to 70V there. Try to measure that again with both meter leads on those 2 pins. Then try the same thing again with the connector unplugged. What does the back light do when you turn on the tv? Does it come on for a brief period and turn off, or is it off all the time? Another idea is that the backlight cable is shorted out to the chassis.
                btw... 36$ buys a new power supply / led driver board.
                • youngkenzie
                  • 20
                  ok.... bought new power supply/ led driver board, installed it, still nothing....anybody have a solution?
                  • CapLeaker
                    Leaking Member
                    • 8352
                    What is the TV doing now? Does it turn on? Is there something on the LCD and sound, but no backlight? Is the backlight trying to come on, flickering or something? If you have a good board and you get something on the LCD itself and sound, then there is only 2 more things. Either a LED wiring harness problem or a LED has burnt out. But I asked you questions already on my last post, I didn't get any answer for.
                    • youngkenzie
                      • 20
                      running test in the morning. Ill have answers around noon. Again thank you to everyone contributing the time to help.
                      • rosettastoned
                        • usa
                        #31
                        Wondering what you found to be the problem. I have the same model doing the same thing.
                          • 12332
                          • U.S.
                          #32
                          maybe double check your solder joints on your new caps.
                          • nomadder
                            • Aug 2015
                            I have the same model tv and had the same problem. I replaced all of the caps on the led driver side of the power board and the tv now works well.
                            Thanks this thread helped me.
                            • OgreX
                              • Mar 2014
                              • 7
                              • usa
                              #34
                              Did you replace every single capacitor?
                              I replaced only the 3 100v caps.(C524,C525,C523) in my grandfather's tv. It lasted 3 weeks before going right back to no leds, with sound playing.
                              It lasted a week just taking the tv apart, unplugging the led cable and putting it back together the first time(evil tv.)
                              • OgreX
                                • Mar 2014
                                • 7
                                • usa
                                #35
                                Anyone have any clue to the actual issue that all these tv's seem to inevitably face?..(seems quite common sadly..) and "nomadder I'd have to wager against your fix lasting too terribly long sadly...(happy to be wrong though!)
                                Pretty obvious they are designed to fail.... overheating seems a "large" concern.
                                ..grandfather wanted me to order a new power board. not worth his money imo.
                                • CapLeaker
                                  Leaking Member
                                  • 8352
                                  Capacitors are not equal... there are good ones and there are bad ones. We don't know what brand, what series and what temperature rating he put in. If he had replaced them with a generic capacitor that is only good for 85C, 3 weeks sounds about right!
                                  • OgreX
                                    • Mar 2014
                                    • 7
                                    • usa
                                    #37
                                    Kinda assuming that was aimed at me:
                                    "Nippon Chemi-Con Hi Temp 105°C
                                    47uF 100 volt 20% radial leaded electrolytic capacitors."
                                    Were those a terrible choice?
                                    Idk, there's not much info on this tv on the net.. only people replacing caps/whole power supply with the problem still persisting that I can find... thoughts?
                                    • CapLeaker
                                      Leaking Member
                                      • 8352
                                      Maybe make your own tread, put in some hi res pictures of your boards, describe exactly what your TV is doing or not doing, provide measurements with pin out on the connector that goes from the PSU to the main board, service manual etc.
                                      That will wake more interest in things. Since your TV isn't working anymore, we have to start again at square one.
                                      • cutlassbenbr
                                        • Nov 2014
                                        • 3
                                        Here is what I found with this TV. LED's have bad connections.
                                        • ajshoe
                                          ajshoe
                                          • Dec 2012
                                          • 477
                                          • usa
                                          #40
                                          have exact same tv - have apart like yours. can set be turned on without lcd screen attached ? so that the backlight leds come on by themselves ? Or are you applying 50 VDC to X602 to light LEDS ??? thanks
                                          • k24a1
                                            TongFang GK5CN5Z (CyberPowerPC Tracer III Xtreme) LCD backlight flickering
                                            by k24a1
                                            Hello, I have a strange issue with a laptop that I'm working on fixing up for a friend of mine, and it appears as though the LCD backlight control is not reliable. The LCD backlight flickers sometimes with inconsistent brightness. The controls are no better.. when I go 1/3 of the way in the brightness controls it will get bright but flicker quite obviously, and when I go all the way to what SHOULD be full brightness, it becomes darker. The flickering is less severe at lower brightness, but more severe at higher. the backlight will literally flicker on and off when I set it to the lowest brightness...
                                            06-11-2024, 05:45 PM
                                          • sliceypete
                                            Samsung LE52B620 - Flickering backlight
                                            by sliceypete
                                            Hello All,
                                            My Samsung LE52B620 started to have backlight flickering about a year ago, it would only last for about 10 mins and then the backlight would stay on.
                                            about a month ago the backlight flickering is constant and does not stop.
                                            I think it's a problem with the power supply board (BN44-00267b) or maybe the backlight is dying?
                                            I checked and all the caps look to be fine.
                                            I do not believe it is a problem with the mainboard, since I unplugged it from the power supply and the backlight came out but still flickers.
                                            08-04-2021, 05:11 AM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • EffiSon
                                            Lenovo Y50-70 - LA-B111P Rev:1A Flickering laptop screen after shorten the R205 resistor/ backlight restoration ?
                                            by EffiSon
                                            Hi. Could anyone on the forum help me find the cause of the problem?
                                            The board is LA-B111P Rev:1A comes from Lenovo Y50-70.
                                            I have a identified the damaged R205 resistor, and connect a jump wire over it So it restores the backlight but causing strange problems
                                            1. With Battery ONLY plugged in laptop works fine
                                            2 .With Charger ONLY plugged in laptop works fine as well
                                            3. Connecting both battery and charger at the same time shows a strange flickering screen. The flickering is not constant, it is completely random (and I think it depends on the load
                                            01-29-2024, 04:03 PM
                                          • HighwayStar89
                                            Lenovo B50-80 won't boot, backlight flickering
                                            by HighwayStar89
                                            Hi to all,
                                            I have this laptop that suddendly won't boot.
                                            When I plug the power adapter, the charging LED turns on.
                                            When I press the power button, I can hear the fan spinning, and the screen start flashings, with the frontal green LED flashing too.
                                            No other vital signs.
                                            I reseated the RAM, changed the RAM, changed CMOS battery, disassembled, cleaned, and reassembled all the boards, changed thermal paste and reflowed, tried the NOVO button (the tiny reset button on the right side) to enter BIOS, tried F2 or Fn + F2, changed power adapter, but with no luck.
                                            I think...
                                            11-08-2025, 08:04 AM
