Vizio E701i-A3 no Picture
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Vizio E701i-A3 no Picture
    Originally posted by Blakertj75
    Hey All,
    I'm having this exact same problem. I bought a replacement T-Con board with the proper ZH suffix and put it in today...television worked again for about 2 hours straight then went black again. I'm stuck now as to know what the problem is...bad T-con board again? Something causing the T-con boards to fail? I had read somewhere else that bad caps can cause black screen but I saw no apparent failures on the power board? Another issue entirely that I'm missing? Thanks for any help/ideas on troubleshooting!
    Did you make sure the thermal pad and cover were back in place before you ran it? Sounds like it may have overheated.
    • bjorkson
      • Apr 2012
      • 127
      I got the new Tcon board in and looks like the problem is still there. I think I might have a panel issue, might have to do more testing to find out. Does anyone have a service manual for this Tv set?
      • CapLeaker
        Leaking Member
        • 8325
        Do you actually have LVDS video coming out of the main board?
        • bjorkson
          • Apr 2012
          • 127
          no, the backlight comes on and stays on, but no video. I have replaced the main board and also the Tcon board with no sucess.
          • triplefour
            • May 2014
            • 1747
            how do you test that?
            Don't fear the repair...
            • CapLeaker
              Leaking Member
              • 8325
              with my 100Mhz oscilloscope. LVDS = Low Voltage Differential Signal. Remember the signal is small, but you can see the changes on the oscilloscope, when you have the TV on some channel and turn on and off the menu all the time, while poking into the LVDS connector.
              • triplefour
                • May 2014
                • 1747
                ahh that reminds me i need to fix up that scope i scored months ago. been so busy!
                • Ltank
                  • Jun 2013
                  • 776
                  I had one. Had backlight and sound but screen was light blue. Vizio had a recall on the set with certain Serial numbers and they extended the warranty to two years. The set I had was not in that range of numbers but the gave the customer a new 70" set
                  • triplefour
                    • May 2014
                    • 1747
                    they gave them a whole new 70" tv?? how did they do that? the shipping must be insane
                    • Ltank
                      • Jun 2013
                      • 776
                      Vizio shipped him the new one and he was told to return the old set to where he bought it if feasible.
                      • triplefour
                        • May 2014
                        • 1747
                        thats crazy. awesome. but still crazy. my friend bought this tv used on craigslist. if it turns out to be a bad panel is there any chance vizio will send him a new tv? we live in hawaii by the way!
                        • schwabee
                          • Aug 2015
                          I also have a Vizio E701i-a3 that had the picture go out on it. Called Vizio and they gave me the same line that there was nothing they can do and that I should shell out more money on a new Vizio TV. The sound and backlight are still working so I attempted the repair and bought a replacement T-Con board gambling that was the probelm. Just installed the new one today and the picture was working! Unfortunately that lasted for only a few minutes before the picture faded out again and back to where I started. Any idea what would be frying the T-Con boards?
                          • GoneGault
                            • Sep 2013
                            • 105
                            Schwabee, I wonder the same thing. Did you find any sort of service manual for the TV?
                            • ecking767
                              • Oct 2009
                              • 492
                              Post a picture of the T-CON board ( close up). I'm believed this T-CON board is having the same problem as the Vizio E601i-A3.
                              Shopjimmy does have a repair kit for the T-CON board
                              • sleepingAwake
                                • Jan 2014
                                • 10
                                Hello everyone.
                                So I picked up an e701i-a3 with sound but no pic. Got a replacement T-Con and it work for a couple of mins before going right back to blank screen no sound. Now I'm wondering if it's a bad panel blowing the T-Con or I got another T-Con in the defective range.
                                Pretty sure the eBay seller of the T-Con is just selling NOS boards that may have been made with the defective components. This was a ZH T-Con. Should I forget it and chalk it up to a bad panel?
                                • schwabee
                                  • Aug 2015
                                  Here is the original T-Con board that I pulled out. I haven't had a chance to open the TV back up and remove the replacement board.
                                  I checked last night and they were out of repair kits. Additionally, it doesn't seem like the issue is with the T-Con board but rather something that is killing these boards since it worked for a few minutes.
                                  Were you able to find a solution for the E601i-a3's?
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Well I have been following this thread closely I also obtained this model TV. The symptoms are sound back light no picture. I found no 3.3 volt or 1.0 volt on the tcon board. It tries to come up upon start up but then dies off quickly. This is with or without the panel ribbon cables connected to the tcon board. So I found a supplier on eBay that says that he has a brand new t-con board never used and I purchased it put it in today without connecting the panel and I had no 1.0 or 3.3v still. And of course it does not provide an image. So my philosophy is a bad batch of t-con boards and I'm understanding the EEPROM on the t-con board is the culprit. I'm suspecting that this board probably had an issue and was removed from someone thinking it was a bad panel. There seems to be an awfully lot of these boards failing with this model TV. Of course the screen is made by sharp. I have had nothing but good luck with Sharp LCD panels so I highly doubt the panel is suspest.
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Hey bjorkson did you ever get that tv straightened out?
                                      • bjorkson
                                        • Apr 2012
                                        • 127
                                        No, I think mine was due to a defective panel, since all my voltage was fine on my Tcon board. This model TV has a known issue with the Tcon/panel issue. You might try to get the correct Tcon and see if it works for you.
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          I picked up the tcon with the proper ZH abbreviation on the end. the supplier swears up and down that the tcon board was brand new never used directly from vizio or sharp. Like I said right out of the box it had no low voltages to the core CPU
                                          • Fly_Among_Stars
                                            VIZIO E70-E3 Half picture with half TCON
                                            by Fly_Among_Stars
                                            I have a VIZIO E70-E3.
                                            Symptoms: Black screen, no picture, but LED backlights are working.
                                            I probed the power board and voltages are as listed on the board.
                                            Main board appears fine, too.
                                            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                            There are two separate ribbon cables feeding the LCD.
                                            If both are connected, the screen is black.
                                            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                            04-24-2023, 08:20 PM
                                          • iglitare
                                            by iglitare
                                            09-04-2025, 07:13 AM
                                          • ggil44
                                            Vizio M65-E0 No Picture, No Sound
                                            by ggil44
                                            Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                            09-03-2024, 08:30 PM
                                          • maricm
                                            Vizio m65-c1 picture flashing on and off on the screen
                                            by maricm
                                            HI all,
                                            hope someone point to the possible issue before I start buying replacement parts.
                                            Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                            Backlight stays on all the time,
                                            Sound works fine.
                                            screen keeps changing form black to full picture in about 1sec intervals.
                                            Picture looks fine with no visible artifacts.
                                            I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                            Disconnecting left and right ribbons on...
                                            11-25-2023, 06:32 PM
                                          • jason123
                                            Vizio P602UI-B3 No Picture or Sound - No TCON Voltage
                                            by jason123
                                            Help is much appreciated as I don't have any experience with this model TV.
                                            Picked it up and it was smoking in the back when powered.
                                            Open opening the LED Driver board was charred (see last photo.)
                                            I noticed some blown caps on the Power board as well.
                                            Replaced the LED driver board, and bad caps on Power supply.
                                            Voltages on CN301 (upper power supply connector to LED driver board)
                                            X000017 - All 24.39V
                                            GND - 0.001
                                            OD - 0.015
                                            VSNS - 0.009 (does that imply bad backlight or bad LED Driver?)
                                            11-14-2020, 08:43 AM
