Vizio E701i-A3 no Picture
  • bjorkson
    • Apr 2012
    • 127
    Need some help or assistance please on a Vizio E701i-A3. Working on one where the power comes on using either remote or side panel power button. When power on, the backlight comes on and stays on, just no picture. I suspect it's a bad T-con board model RUNTK5261TP-ZH. When I measured the F101 fuse, label (5A @32V), getting less than 1 V. I suspect it to be bad. So, I order one off of Ebay and put in in. No change, still getting the backlight on, no picture. But with the new tcon board in there. I am getting a 12.32V reading, but not the 32V. Is it supposed to be a full 32V for the picture to come on? Did I buy a bad Tcon board? Can anyone please advised. Thanks in advance.
    • 12206
    • U.S.
    Re: Vizio E701i-A3 no Picture
    could use more details, I'd start with making sure all the voltages at the plugs are correct on the power supply board, careful HIGH VOLTAGE on ac side, could be a tcon, voltage at tcon can be checked.
      • 12206
      • U.S.
      service manuals http://elektrotanya.com/?q=showresul...oria=&kat2=all
      • bjorkson
        • Apr 2012
        • 127
        OK, I will check it tonight when I get home and report the voltage readings.
        • bjorkson
          • Apr 2012
          • 127
          I use the link provided and my TV model number is not coming up for the service manual
            • 12206
            • U.S.
            ouch, that's about the only site I know of, check one of tom66's posts, he has his manual links stuck to his posts.
              12V at the SMD fuse of the T-CON is correct, the 32V is the fuse Voltage rating.
                Try disconnecting one of the panel ribbons, just connect one at a time, see if part of the picture comes back. Could be a defective LCD panel.
                • bjorkson
                  • Apr 2012
                  • 127
                  Hi Tom, already try that, still getting the blank (black) screen with just the blacklight on. Wondering what else is causing this.
                  • bjorkson
                    • Apr 2012
                    • 127
                    if you suspect a bad panel, the backlight will just flash and shut off?
                    • bjorkson
                      • Apr 2012
                      • 127
                      Is there any test points on the Tcon board to measure each voltage drop, don't see it on this particular board.
                      • bjorkson
                        • Apr 2012
                        • 127
                        One other thing I did not include in my original posting is my original T-con board RUNTK5261TP has a ZH prefix. I replaced it with a RUNTK5261TP ZG prefix. All the plugs seen to fix ok. The ZH is for a 70in panel, where your ZG is a 60in panel. Would this cause the picture not to come on? Or they compatiable?
                        • aaronwt6
                          • Apr 2013
                          • 855
                          • US
                          That's absolutely the issue and I've experienced this myself. You need the ZH T-con. I'm not sure what the difference is on them but they are not interchangeable.
                          • bjorkson
                            • Apr 2012
                            • 127
                            Great, that's really good news. I will try to get a orignal board replacement and see if that will fix it. Will report back when I get one order. Thanks Aaron.
                            • aaronwt6
                              • Apr 2013
                              • 855
                              • US
                              No problem. I'm not sure why, but some places list these as interchangeable and they aren't. Please give us an update once you have the correct T-con.
                              • bjorkson
                                • Apr 2012
                                • 127
                                When I brought the ZG Tcon board on EBAY, some guy listed for a 70in panel so I assummed that it was interchangeable. I guess this is not the case since I did more research and that ZG board belongs to a 60in panel. Well, at least I know that board is good. Geting a 12.32V reading where my original ZH board was getting less than 1 V.
                                I will definately get a replacement and see if that fixes it up. Will report back once I do.
                                • aaronwt6
                                  • Apr 2013
                                  • 855
                                  • US
                                  Just because it has 12V doesn't necessarily mean it's good. Regardless, I'd return the board as it was not as described. The guy probably listed it for the 70" as that one sells for more.
                                  • Blakertj75
                                    • U.S.
                                    Hey All,
                                    I'm having this exact same problem. I bought a replacement T-Con board with the proper ZH suffix and put it in today...television worked again for about 2 hours straight then went black again. I'm stuck now as to know what the problem is...bad T-con board again? Something causing the T-con boards to fail? I had read somewhere else that bad caps can cause black screen but I saw no apparent failures on the power board? Another issue entirely that I'm missing? Thanks for any help/ideas on troubleshooting!
                                    • bjorkson
                                      • Apr 2012
                                      • 127
                                      My Tcon board is still not in yet to test and confirmed my original problem. Maybe someone on this board can give their input on your problem. Thinking you might have a bad panel causing your tv to lose picture.
                                      • bjorkson
                                        • Apr 2012
                                        • 127
                                        They sent me a bad tcon board and will shipped another one out here soon. Will see if that fixes the issue.
                                        • Fly_Among_Stars
                                          VIZIO E70-E3 Half picture with half TCON
                                          by Fly_Among_Stars
                                          I have a VIZIO E70-E3.
                                          Symptoms: Black screen, no picture, but LED backlights are working.
                                          I probed the power board and voltages are as listed on the board.
                                          Main board appears fine, too.
                                          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                          There are two separate ribbon cables feeding the LCD.
                                          If both are connected, the screen is black.
                                          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                          04-24-2023, 08:20 PM
                                        • ggil44
                                          Vizio M65-E0 No Picture, No Sound
                                          by ggil44
                                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                          09-03-2024, 08:30 PM
                                        • maricm
                                          Vizio m65-c1 picture flashing on and off on the screen
                                          by maricm
                                          HI all,
                                          hope someone point to the possible issue before I start buying replacement parts.
                                          Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                          Backlight stays on all the time,
                                          Sound works fine.
                                          screen keeps changing form black to full picture in about 1sec intervals.
                                          Picture looks fine with no visible artifacts.
                                          I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                          Disconnecting left and right ribbons on...
                                          11-25-2023, 06:32 PM
                                        • jason123
                                          Vizio P602UI-B3 No Picture or Sound - No TCON Voltage
                                          by jason123
                                          Help is much appreciated as I don't have any experience with this model TV.
                                          Picked it up and it was smoking in the back when powered.
                                          Open opening the LED Driver board was charred (see last photo.)
                                          I noticed some blown caps on the Power board as well.
                                          Replaced the LED driver board, and bad caps on Power supply.
                                          Voltages on CN301 (upper power supply connector to LED driver board)
                                          X000017 - All 24.39V
                                          GND - 0.001
                                          OD - 0.015
                                          VSNS - 0.009 (does that imply bad backlight or bad LED Driver?)
                                          11-14-2020, 08:43 AM
                                        • shelby5041
                                          Samsung LCD TV no picture backlight on no 12v at tcon
                                          by shelby5041
                                          hi
                                          i have a samsung lcd tv
                                          it powers on with sound and backlight but no picture
                                          all voltages from PS are good 12v 3.3v and 5v
                                          whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                          i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                          no 12v at the tcon fuse
                                          i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                          the odds of having 2...
                                          10-08-2021, 08:21 AM
