using ATX PSU for TV's?
  • triplefour
    • May 2014
    • 1747
    the guy i buy TV's from at the E-waste recycler told me that he has sometimes used an ATX power supply instead of the power board to diagnose TV's...
    im sure he's not lying, but is this something we can do safely?
    it makes sense to me since the average PSU for a tv only needs some 5v, 12v , and 24v which you can make just fine with an ATX PC power supply...
    then just a matter of putting the wires in the right places?
    there has to be some major reason why this is a bad idea. please, educate me!
    Don't fear the repair...
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: using ATX PSU for TV's?
    Typical ATX PSUs output 3.3V, 5V, and 12V. Not sure how you'd get 24V, though.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      you're forgetting the negative rails....
      -12v + 12v = 24v would have thought you knew that, with how you tried to make your own PSU tester and all.
      Follow the white rabbit.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        lol, no need to be snarky.
        I don't participate in Hardware Insights anymore, so there is no need to have a PSU tester. I thought I was going back into it but after some more thought I realized it was not my passion anymore nor a priority so I ended up not doing it. I would have done it for the money and it doesn't make sense to do something just for money especially because it's not a very good source of income. I can charge $60-120 an hour for managed services or I can spend 4 hours on a review and make a couple bucks selling the PSU afterward - which makes more sense? I still proofread some of the articles and do minor site maintenance over there but that's it.
        Now let's not derail the entire thread, ok? If you have a problem PM me, and I'd be happy to work it out, but this thread doesn't belong to us.
          Since the -12V and the +12V of the ATX will have common gorund, then for you to make 24V with negative ref to ground for the inverter board, then you will need to lift the ground of the -12V and the +12V ground. The 24V will also have to be rated at about 4~5A for typical inverter board.
          I am sure you have some TV that is beyond fixing, then you can use the power supply from it for testing.
          • triplefour
            • May 2014
            • 1747
            yes that probably is the easiest solution...save a working PSU (the more "normal" the better?) from a tv with a broken screen and use that...
            as long as you rewire it correctly, there shouldnt be any danger to the main board?
            • Shinju
              • Mar 2014
              • 1239
              Samsung power supplies are pretty awesome for the fact you can take a ps from one TV and if the mainboard plugs match you can use it to power on another panel.
              I have done this with a few LCD PS for some Sammy plasmas to trouble shoot mainboard on/off voltages
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                Also the -12v rail won't supply very much current.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5084
                  • New Zealand
                  Yeah, usually less than 1 Amp. Most seem to use just an LM7912.
                  -David VanHorn
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Yes. I was gonna say that. Most PSUs have around 0.5A to 0.8A capacity - not really useful.
                    • Hypersapien
                      Artist seeking to tinker with electronics safely
                      by Hypersapien
                      Howdy folks! I'm an artist in the video game industry, and my job entails making a lot of mechanical and sci fi assets. I thought it might be a good practice to start disassembling some electronics to be more familiar with how real electronics are manufactured and assembled, which is how i found my way to these forums.
                      When I started researching what tools I might need, I quickly encountered the warning "Some devices can maintain a potentially lethal charge in their capacitors, even up to years after last being powered on", which was enough of a scary thought for me to...
                      10-22-2023, 01:31 PM
                    • Chaks
                      The ups takes 3 x 18650 cells in Parallel - Can I extend to 6 x 18650 safely?
                      by Chaks
                      I need help to extend the runtime of the ups board (see attached image).
                      This is ups board for a CM4 which has 3 18650 cells in parallel. Can I extend the 3 cells to 6 cells for a longer runtime? by soldering a wire to each of the battery terminal and connecting it to a separate battery case with 6 cells.
                      Thanks and kind regards,
                      chaksindia...
                      01-21-2025, 11:39 AM
                    • eccerr0r
                      how hot can a toroid inductor go safely?
                      by eccerr0r
                      Well, since I now have a grid tie inverter, I have to follow its input requirements. So, I designed/built a small switch mode supply to feed it.
                      After several iterations of pitfalls with a very uncooperative solar panel, I got the supply to behave - except the toroid inductor gets to 165°F (74°C) ... though granted I'd rather it get this hot than the 75N06 which only gets to 108°F (42°C) despite on average passing 5-6 amps when the panel is in full sunlight.
                      Not quite sure if it's due to core saturation, eddy losses, or just I*R losses yet but it is hot...but how...
                      08-18-2023, 02:20 PM
                    • Francesc V.
                      Am I working safely?
                      by Francesc V.
                      Hi:
                      I would like to ask you a couple of questions regarding my work station.
                      1. Is this a right isolation transformer to isolate it from ground and work more safer for instance with SMPS?
                      I bought this transformer where I have plugged a serial lamp and from it I plug the PCBs I want to test.
                      2. Isolating correctly the oscilloscope
                      I am not sure if connecting the oscilloscope at the isolation transformer will be good idea when measuring things with HOT GROUND........or maybe better to use batteries...
                      12-29-2022, 01:46 PM
                    • guix
                      How to safely handle a 75inch LCD panel ?
                      by guix
                      I have a Sony KD75XD8505, 75 inch edge-lit tv to repair, unfortunately one of the LED strip was damaged by liquid so I need to open it, but I'm affraid to break the panel since it's so big...
                      I can do 55 or even 58 inch alone, by slowly sliding a big piece of cardboard (covered with cloth) under the panel, same for 65 inch but need another person to help.
                      I've seen suction cups mounted on a rigid chassis but it's not cheap!
                      What is your technique to safely move such big panels ?
                      03-09-2020, 07:59 PM
