how hot can a toroid inductor go safely?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8704
    Well, since I now have a grid tie inverter, I have to follow its input requirements. So, I designed/built a small switch mode supply to feed it.
    After several iterations of pitfalls with a very uncooperative solar panel, I got the supply to behave - except the toroid inductor gets to 165°F (74°C) ... though granted I'd rather it get this hot than the 75N06 which only gets to 108°F (42°C) despite on average passing 5-6 amps when the panel is in full sunlight.
    Not quite sure if it's due to core saturation, eddy losses, or just I*R losses yet but it is hot...but how hot is too hot?
    (the smps works! Efficiency is nothing to write home about, probably because of that inductor, albeit if I don't use the panel at all it's 0% efficient...)
  • diif
    • Feb 2014
    • 6978
    • England
    Re: how hot can a toroid inductor go safely?
    Surely the question should be "How does my design look ?", not how how is too hot.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8704
      Well, for one thing I used parts that I had on hand, so I don't have many options on redesigning so unless it's a gross swap, it is what it is. Just wonder how long this thing will last being that hot before it loses its characteristics and fries the device, or could I just run it as it is and hopefully I'll have another solution down the road.
      I think this coil came out of a dead off-line PSU probably some filter inductor. I really should characterize the core to know exactly what I have, but well, it is what it is...
        • Jul 2011
        • 6070
        I would be concerned about if is getting so hot that the enamel paint degrades and you end up with a shorted coil but I could not tell you how hot it has to be for this to happen
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8704
          I had a toroid filter core go short in a Antec PSU after it overheated so definitely a concern. I don't have a fan for the toroid (it's the energy storage element in a boost supply). Hoping to run fanless so I could pot it, it may need to be left outdoors someday...
          Running through back of envelope math the component selection doesn't seem way too far off actually (inductor around 270µH), the troubles I was having initially was due to bad assumptions (555's reset LOW) and not taking brownouts into consideration. So right now I think it may be core loss or IR loss, don't think it should be saturating at 40KHz.
          hmm....
            • 31262
            this is the concern.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8704
              Oh man... I totally screwed up on my oscillator frequency, was running around 10kHz (spied on gate drive with a scope) when I was expecting 40KHz. It was probably core saturating. Let's see if speeding it up a bit helps though now the mosfet probably will take some more heat...
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8704
                Nope, still getting hot, so I*R loss is still highly suspect. The windings aren't that thin, probably at least 18 AWG if not 16 AWG. I've never seen a 14AWG+ inductors yet except probably welders and induction heaters...
                For those of you who have measured temperatures on inductors under load... what are typical?
                The varnish on the windings probably could take some heat but yes they will eventually melt, sublimate, or even burn... plus not sure of what the binding material in the core can deal with.
                  master hoarder
                  • May 2008
                  • 12175
                  I've measured a few output toroids in ATX PSUs, but not under full load and with a type -K thermocouple... so not the most precise measurements. I was getting about mid-50's C @ medium load and and mid-40's C with a light load. Higher loads or highly unbalanced 5V-12V loads (crossloads) resulted in the output toroid running the hottest, reaching almost 60C in some instances.
                  I've seen them in some higher power PSUs (over 500W.)
                  Most manufacturers prefer to put two or more parallel runs of thinner wire than a single run of thicker wire - less losses due to "skin" effect at higher frequencies.
                  By the time the varnish starts to melt, the core will be long overheated and damaged.
                  IIRC, 80-90C is about where most cores will start to get damaged from heat. In contrast, the varnish / enamel on "magnet" wire is usually specified for at least 120C. That's why most "class II" line frequency transformers are specced for up to 120C - the steel laminate plates in the core can take more (being steel and all), but the wire enamel and varnish will start to soften and could allow a short-circuit to develop somewhere.
                  Well, if you haven't done that part...
                  This is probably the most important thing to do here. First you have to identify if the core can even handle any kind of high switching frequency or not. And second, you need to size the core appropriately. Even if the core is right for the switch frequency, you can still saturate the core if you have too many turns or too much current through fewer turns. So you really need to hunt a datasheet for the core material.
                  The few common ones used in ATX PSUs are:
                  Micrometals -26 type (yellow core with one side painted white): good for up to 50 KHz and has decently high initial permeability.
                  Micrometals -52 type (light green core with one side painted blue): same permeability specs as -26 type material, but with lower core losses and thus could be used at 100+ KHz switching frequency.
                  Micrometals -45 type (completely black core): good for ~100 KHz, but has even higher permeability compared to -26 and -52 type cores... actually, the highest for iron powder cores.
                  Nowadays, I see many PSU manufacturers use completely blue cores, but I'm not sure what those are. I've seen them used frequently on some P4 / Athlon 64 -era boards, along with the all-black -45 type cores, so I imagine similar characteristics overall.
                  Was thinking the same thing.
                  Plus, it would be interesting just to see the circuit design itself. Maybe someone here could even suggest improvements without having to change the circuit too much or too many parts.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8704
                    hmm...another thought, well, this thing was intended for around 100W and all that power needs to be stored in it. This is starting to push it for some atx psu parts.
                    Now not sure how I can characterize cores without a high power frequency generator. I'm not even sure I can trust the color of the core, though it is yellow and estimated cross section (since there's a winding on it, have to guess) is around 0.7cm² or so, ID around 1.5-2cm (again winding is already on it). Really don't want to unwind it, because I'd eventually have to rewind it...
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8704
                      hmm looked at it again, ID is more like 1cm. Perhaps not quite big enough for the job?
                      suspecting that there should be a rule of thumb somewhere on size of transformer and wattage it can pass, but I thought this should be about right, though maybe a little small. I also have a huge toroid core that has like 3-4cm² cross section and 4cm ID, but that one is in use for another design... and that one does not get hot with even 200W passing through...
                      oh boy I totally forgot the capacitor to filter the diode output! Ack! I was wondering why it was completely bonkering out AM reception, worse than I thought it should be. Added a cap there and now I don't have a few meters worth of cabling radiating switching pulses!
                        • Jul 2011
                        • 6070
                        I following this post to see what you come up with
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8704
                          Oh fun! I found another toroid that was definitely used as a filter coil for a multi-output flyback PSU. This toroid has at least another mm² of cross section and its ID is a bit larger. It unfortunately does not have as many windings on it, and it has multiple windings. I suppose I'll ignore the 26-gauge windings and use the thicker 18-ish AWG windings and see if this behaves any different...
                          This one since it has fewer windings clearly is yellow with one white stripe on one side, implying a micrometals -26 core...
                            master hoarder
                            • May 2008
                            • 12175
                            Oh I suppose I'll ignore the 26-gauge windings and use the thicker 18-ish AWG windings and see if this behaves any different...
                            You can also connect the 18 AWG and 26 AWG windings in series if they are wound in the same direction to get a higher inductance... though I think the 26 AWG windings probably won't be good for too much current.
                            If it has about 27 mm (1") for the outter diameter, 14-15 mm for the inner diameter, and 11-12 mm thick, it's probably a T106-26 core - a very commonly used core for older cheapo group-regulated PSUs and even non-cheapo older PSUs rated at 250W or less.
                            Real limit for these cores is around 300 Watts at the lower output voltages that ATX PSUs usually output, or probably could do 400-450W with much higher output voltages (and lower associated output currents.)
                            If the PSU it came out of had an output toroid, then it didn't use flyback (discontinuous) topology. With flyback/discontinuous topology, the "transformer" primary side serves as the output toroid. I put transformer in quotes, because for flyback, the transformer is gapped and actually functions more like a coupled inductor. In contrast, the transformer of a continuous topology is not gapped and does not store energy. A pulse on the input / primary side directly produces a pulse on the output / secondary. With flyback, a pulse is produced on the output after the pulse on the primary is ended and the magnetic field in the inductor collapses.
                            So in fewer words...
                            Output toroid = continuous topology only
                            No output toroid = discontinuous topology (what's commonly referred to as flyback)
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8704
                              As a filter coil (why not use linear cores as filter inductor cores?) does it really handle that much power? I suppose that's the concern and perhaps I need an even bigger core. 100W is the target since that's one solar panel, and the thin 26-gauge windings are useless, they can't handle the multiple amps needed to deal with 100W at 18-36V... though even if they are wound in the wrong direction, just reverse the connections? A little loss here and there is okay and no worries about cross coupling or insulation limits for now.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8704
                                Now what if I connected a second toroid in series with the existing toroid, what will happen?
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  LOL, this is like watching an episode of Garage54, except instead of messing about with old Lada's, we're observing experiments with some mystic home-brew PSU circuit.
                                  Inductance of the two inductors added up??
                                  As for how the circuit will react... well, that I can't tell you. We have no details or schematic of what your circuit is exactly, so my guess is probably as good as that of a squirrel.
                                  All of the output current does pass through it, so yes.
                                  If you look at any regular half-bridge or forward topology ATX SMPS, you have square wave pulses produced on the primary side (by the MOSFETs / BJTs) and reduced amplitude square wave puses at the output side of the transformer corresponding to the turns ratio. These then go through the rectifying diodes and into the output toroid, where they get "averaged" into rectangular waves (with a DC offset) and further smoothed into DC by the output caps.
                                  As for "linear cores as filter inductor cores", not sure what you mean by that. If you're implying of using a transformer's winding as an inductor, that won't work (too well.)
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8704
                                    Well the problem is that filter cores indeed have a LOT of DC component/offset compared to one used for boost/buck which can go MUCH further and could go discontinuous or get close to saturation. Therefore there isn't as much of -something- that the core does not need to handle.
                                    I see a lot of PSU filter inductors wound on toroid cores but why not use I-cores... and why not E-I cores (shape, not the laminated sheets used for 60Hz)?
                                    BTW the curiosity of two series inductors, if one inductor is saturating, adding another identical one series, would they still both saturate or can they take more now since energy is now spread among two cores.
                                      Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                      by momaka
                                      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                      09-19-2021, 08:44 PM
                                    • Bartoloni
                                      Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
                                      by Bartoloni
                                      Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
                                      everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
                                      there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
                                      replaced the capacitor (330) and the inductor (R15) without any change
                                      any idea? very thank you!
                                      input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
                                      12-09-2024, 12:42 PM
                                    • badcap111
                                      How to read inductor specs?
                                      by badcap111
                                      I have a broken samsung galaxy s10 with missing inductor. I want to replace the missing inductor and I have found some vendors. But I don't understand how to read the specifications of the inductor. The specs are:
                                      INDUCTOR-SMD;470NH,20%,2520,T0.8,0.029OH
                                      I understand that the inductor is 470 nH with 20% margin, and the size is 2520 or 1008 (imperial measure), but what do T0.8,0.0290OH mean? I can't find any explanation on the web.
                                      09-12-2023, 01:25 PM
                                    • silver60618
                                      Blown Inductor on WD My Passport
                                      by silver60618
                                      Hi Guys, my WD My Passport drive powers on, then powers off. Ive taken out the motherboard and identified a blown Inductor. Im trying to recover my data only
                                      Reading between leads show nothing. If I removed this Inductor, what would be a suitable replacement? am I correct that its a ferrite Inductor is to just filter noise?
                                      Ive seen people just bridge them, any harm in replacing it with a differnt value Inductor?
                                      Lastly am I correct in thinking there is no polarity on the smd component?
                                      Thanks!...
                                      04-05-2024, 09:54 AM
                                    • slybunda
                                      Damaged GPU Inductor Query
                                      by slybunda
                                      Hey all, iv got a graphics card ( Nvidia RTX A1000) it has a chipped inductor on it. Now the card seems to work perfectly fine with no issues so i get the feeling i should just leave it be and carry on using it but to be on the safe side i would like to keep a spare inductor in stock incase i feel like replacing it one day.
                                      Any one know which part number i should get? the pics show it to be a 1R0 but not sure on package size etc. RS components is close by to me and my preferred place to go for genuine electronics stuff.
                                      10-01-2025, 02:27 PM
