ViewSonic N2750W - 0 secs to black
  • zedron
    • Jul 2014
    • 20
    Someone was going to throw out a ViewSonic N2750W but I said Ill take it and give it a shot at repair. We could always use another TV somewhere in the house right? My last attempt at Tv repair was very successful so I said why not. I have nothing really to lose besides maybe a few bucks in replacement caps, etc.
    TV turns on and I can see the image in the back with a flashlight. I didn't hook it up to an input source but instead hit the menu button to get the OSD to appear and it does with a flashlight of course. So, I said OK, cant be to hard of a problem. Just got to get those back lights to turn on.
    So far I tested the inverter board's transformers with the below results:
    Trans#---Pins 1-8-----Pins 4-5
    1-----------0.969--------0.966
    2-----------0.959--------0.961
    3-----------0.982--------0.981
    4-----------0.986--------0.986
    5-----------0.975--------0.972
    6-----------0.967--------0.973
    7-----------0.959--------0.961
    Nothing is screaming out "IM BAD" here in relation to the transformers. I don't have a spare CCFL to test or a CCFL tester. The way this TV/Panel is setup makes it extremely hard to test as the inverter board is covered by the panel that the main board and PSU are on.
    Any more help on what needs to be tested let me know. Appreciate the help. Pictures are below.
    Pics#1,2 = Inverter Board with transformers numbered in red and caps circled in yellow. Didnt test caps as I think they are in parrellel adn I have not removed.
    Pics#3,4 = Power Unit
    Pics#5,6 = Main Board
    Pic#7 = CCFLs
  • zedron
    • Jul 2014
    • 20
    Re: ViewSonic N2750W - 0 secs to black
    After looking over the boards some more thinking that it cant be this hard I noticed three caps on the main board looking a little bloated.
    (2) Elite 1500uF 10V 105C
    (1) Elite 1000uF 16V 105C
    Survey says?
    • R_J
      • 9625
      You did look at these pictures before uploading right? There should be some fuses on the inverter board, some are easy to spot and there is usually one that is very small and marked with a letter (fuse rating) that supplies the drive ic circuit.
      Yes those caps are bad.
        I would replace those bad caps first, then verify that you do have 24VDC and BL_ON signal feeding the inverter board.
        • zedron
          • Jul 2014
          • 20
          Pulled the caps out and tested.
          The 1500 uF caps tested around 450-600uF
          The 1000 uF cap tested around 200uF
          I looked on the inverter board for F fuses and the only ones I found are F1-4 but they are empty.
          Im gonna buy some replacement caps and see how she does.
          Ill post back my results.
          • zedron
            • Jul 2014
            • 20
            Unfortunately the cap replacement did not solve the issue. I checked the output from the PSU to the inverter board and it read 23.06V. I'm going to guess it a CCFL or something with inverter board. Anyone have any ideas to check? I don't have any CFLs lying around either or a CCFL tester. I was thinking about buying one of those CCFL tester on eBay for $6 to check and to keep in my tool box for other projects.
              "I looked on the inverter board for F fuses and the only ones I found are F1-4 but they are empty" They are not empty, there two footprints for two sizes of the fuses, next to the empty pads are white fuses, as you can see some of them has '3' printed on top to indicate 3A fuse which is also printed on the board.
              http://www.shopjimmy.com/media/catal...40.027-top.jpg
              http://www.shopjimmy.com/media/catal...j27d000703.jpg
              • Agent24
                I see dead caps
                • Oct 2007
                • 5095
                • New Zealand
                It's probably not a lamp fault since faulty lamps usually seem to at least try to light up, and then get shut down.
                Check fuses like the others have said, if any are blown, I would say start with checking for shorted drive transistors in the inverter
                -David VanHorn
                • zedron
                  • Jul 2014
                  • 20
                  Ahh I see what you mean. Whats the best way to check fuses, continuity? Forgive me if my questions are rather simple. Im in no way a electronics person but rather a network/voice engineer, lol.
                  Thanks for the reply. Checking fuses.
                  • selldoor
                    Slow Learner
                    • 7870
                    Fuses - No power to board you are testing - set meter on ohms 200
                    one probe to each side of fuse - should be same as touching the probes together.
                    • zedron
                      • Jul 2014
                      • 20
                      Got it, thanks.
                      Im going to go ahead and say that 3/4 fuses are shot. Im going to replace all 4 though since I am already in there. What kind of fuse would that be? There are no markings on it except the amperage rating.
                        If you found 3 fuses blown there's probably a fault on the board somewhere.
                        • zedron
                          • Jul 2014
                          • 20
                          Any suggestions for locating that or easier to get a new board?
                          • selldoor
                            Slow Learner
                            • 7870
                            Are you absolutely sure the fuses are open. You did not actually give the result of the test.
                            It would possibly have a "1" on the left of the meter or "OL" or whatever your meter shows when the probes are apart. (obviously with the meter on)
                            First easy check would be the caps - just to see if they are shorted
                            Perhaps post pictures of the inverter in 3 sections close up for us to inspect better.
                            Nothing on the back?
                            • zedron
                              • Jul 2014
                              • 20
                              Meter reads 0 when leads are apart
                              Meter reads .1 Ohms with leads together
                              Meter reads .1 Ohms testing "good" fuse
                              Meter reads 0 or bounces around and eventually ends back at 0 on "bad" fuses
                              Nothing on back.
                              Ill get some updated pics later this evening.
                              shopjimmy has a board for $20... :-/
                              • selldoor
                                Slow Learner
                                • 7870
                                Board may be the way to go BUT make sure you get the exact same model /series and even when you think it is ok ring them up and make sure - we have had a few people buying the wrong boards lately . The important number is often the one on the barcode label
                                - not necessarily the one silkscreened on the board.
                                  "0" with leads apart -- are you sure?
                                  • zedron
                                    • Jul 2014
                                    • 20
                                    Yep positive.
                                    0
                                    Once I touch them together it goes to .1 Ohms
                                    I sent an email to jimmy regarding the part number to verify. While I have been here on the site I have been lurking around and noticed that too with regards to incorrect item purchases. That's what prompted me to email them for verification.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      We dont disbelieve you but I dont think we have ever seen that before.
                                      What is the make model of your meter? Picture of it?
                                        I think your meter might be faulty...
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
                                        • eccerr0r
                                          inverter H tree driver imbalance in an AC inverter
                                          by eccerr0r
                                          My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                                          11-16-2025, 12:34 PM
                                        • x_orange90_x
                                          by x_orange90_x
                                          01-29-2025, 09:24 PM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
