ViewSonic N2750W - 0 secs to black
  • zedron
    • Jul 2014
    • 20
    Re: ViewSonic N2750W - 0 secs to black
    RadioShack T-RMS DMM #2200075 it is new less than a week.
    Now that you suspect that the meter may be faulty I tried my other meter and obtained similar results.
    Commercial Electric MS8260A
    I can post pics of the display when I take pics of the board later this evening.
      That would be helpful, maybe it has an odd display.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5035
        • New Zealand
        If the reading changes when you test things, it probably isn't faulty, probably just has a different way of showing open circuit than other meters.
        My Metex and Fluke say 0.L for an open circuit but my cheap Dick Smith meter shows a 1 in the leftmost digit and all other digits are blank.
        -David VanHorn
        • retiredcaps
          • Apr 2010
          • 9271
          Originally posted by zedron
          Yep positive.
          0
          Once I touch them together it goes to .1 Ohms
          Are you sure it doesn't say 0F in ohms mode? Some Radio Shack meters use 0F to indicate "infinity, open loop", etc.
          If it truly says 0 and not 0F, you have a faulty meter.
          --- begin sig file ---
          --- end sig file ---
          • retiredcaps
            • Apr 2010
            • 9271
            If a meter used 0 to designate an open circuit on the display, it would lead to a lot of confusion and potential death.
            A picture from the OP is worth a thousand words.
            • zedron
              • Jul 2014
              • 20
              Tiny caveat. It does read 0F for loop. I was stating 0 as it was giving a reading of no Ohms/No resistance but thinking in my head open loop. Sorry for the confusion.
                So you do have some blown 3A fuses, so you have some shorted out MOSFET's that drive those inverter transformers.
                • zedron
                  • Jul 2014
                  • 20
                  Instead of messing with it I bought an inverter board from shopjimmy for $20. So far I would have replaced 3 bad caps on the main board and the inverter board. If this doesn't do it does anyone want a TV?
                  • lostone
                    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                    by lostone
                    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                    05-19-2024, 11:40 AM
                  • x_orange90_x
                    Vizio E55-E1 bad backlights or bad inverter?
                    by x_orange90_x
                    I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                    I don't know how exactly to test the inverter itself. Is it...
                    01-29-2025, 09:24 PM
                  • Gentian
                    APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                    by Gentian
                    I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                    It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                    03-06-2023, 07:07 AM
                  • valvashon
                    Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                    by valvashon
                    For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                    History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                    01-04-2024, 01:44 PM
                  • Tips
                    Inverter 316827000001-R0A transformers
                    by Tips
                    I have a failed inverter board, 316827000001-R0A from an Acer Aspire Z5700 AIO PC. (I know I am asking this question under TV's and video sources as I believe it is more relevant here than under PC's and I hope that is not an issue)
                    The transformers have failed and I am struggling to identify them or find a suitable replacement for them. The only code printed on them is 273001050372 10252. (Please see attached pictures)
                    Any advise or suitable compatible replacements would be most welcome, and thank you in advance....
                    12-13-2020, 06:15 AM
