LE37R88BD Backlight Turns Off After 2 - 3 Seconds
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Hi all, I have here a Samsung le37r88bd tv and when turned on its fine but 2 or 3 seconds later the backlight goes off, I still get sound and can see the image using a torch, I replaced 2 bulged 1000uf 35v caps on the power board and also tried a new inverter board but neither helped, Would anyone know what else might cause this fault?? All voltages from the power board are as they should be when the set is on so i dont think its that.....
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: LE37R88BD Backlight Turns Off After 2 - 3 Seconds
    do any of the voltages drop out on the psu when this happens after the one or two seconds whilst its working?
    • ivoh
      • Jun 2014
      • 41
      like he said check the voltages, also make sure that the inverters signal to turn on is not disappearing. you might also have a fault or protect pin, measure that too if you have one.
      • Easky15
        • Sep 2013
        • 285
        • Ireland
        All voltages remain constant when the backlight is on and when its off, Also when it's off the inverter is still receiving the 5v power on signal and the 24v supply, The main board is a BN41-00813B and i tested a BN41-00813E in it, only thing different was the t-con lvds cable connection, again i got the same fault with the backlight, went out after 2 seconds so i think its not the main board,
          How about the dim signa (see if it use PWM for dimming or Analog dimming)l? Also is there a cable between the T-CON and the inverter board?
          • Easky15
            • Sep 2013
            • 285
            • Ireland
            Sorry still learning budm.. ;-) How do i test the dim signal and how do i check if it's PWM or analog dimming??
              Let me see the pictures of connector so I can see the labels. Pictures of the whole back side of the TV and the whole boards.
              • Easky15
                • Sep 2013
                • 285
                • Ireland
                Hope these help...
                http://tinypic.com/r/9zwn7s/8
                http://tinypic.com/r/fx3tj5/8
                http://tinypic.com/r/favu6d/8
                http://tinypic.com/r/11w356p/8
                http://tinypic.com/r/334uf0z/8
                http://tinypic.com/r/1znbsbs/8
                • Easky15
                  • Sep 2013
                  • 285
                  • Ireland
                  • Easky15
                    • Sep 2013
                    • 285
                    • Ireland
                    Would anyone have anymore ideas what could be wrong with this set??
                      OK, here is the SCH provided by TOM.
                      Check the DC voltage on CNM804 BL_ON, ADIM, PWM, 24DET. Also check the 24VDC PIN.
                      • bammbammfran
                        • Apr 2014
                        • 476
                        FIRST : Please post your pictures on this site instead of a site that shoves ads down your throat !!
                        Your inverter board is probably having issues. one of the seven transformers may be bad or a transistor on it may have gone.
                        Pictures of that board with the cover off of it would help
                        • Easky15
                          • Sep 2013
                          • 285
                          • Ireland
                          Was not able to upload here due to crappy file size restrictions so thought it was easier just to upload it there rather than piss about reducing the resolution, Also if you read my first post i have already bought another inverter from ebay and it does the exact same thing, (whats the chance both have the exact same fault) prety unlikely i think so the only board i think it can be is the power board,
                          • Easky15
                            • Sep 2013
                            • 285
                            • Ireland
                            Thanks BUDM, trying this now
                            • bammbammfran
                              • Apr 2014
                              • 476
                              I missed where you said you tried a different inverter.
                              It is possible that they do have common issues especially with those style transformers, but I do not know for sure.
                              What you can do is try to see if one bulb might be totally cooked by trying to turn it on with one bulb plugged in at a time
                              Changing your desktop background to all white may help you see each bulbs brightness a little better
                              if for some reason one does not light or looks really dark, loosen the inverter so that you can slide the board a little and try that same bulb in another transformer plug and/or another bulb into the transformer that showed dark
                              this can sometimes show an issue if a transformer or bulb is really bad
                              • zklgfs
                                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                by zklgfs
                                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                08-11-2025, 02:14 PM
                              • alpersen
                                Philips 40 PUK6809/12 Backlight turns off after 10-20 seconds
                                by alpersen
                                Hello
                                Mother called and said TV turns off after switching on. So after turning on Philips logo shows and probably 10-20 seconds image disappears, sat receiver is connected and sound is heard from source. So I turned on my phones light and I can see the image it seems backlight was off after some time. I dis assembled the cover hoping to see a distinc cap blown or leakage. Here are photos I took (I was after 22:00 pm and maybe some of them are dark). Should I order and change caps on the power circuit or what would you recommend? Thanks...
                                07-25-2024, 12:50 AM
                              • www
                                LG L192WS-BN backlight turns off after 1 second
                                by www
                                I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                03-24-2024, 05:26 PM
                              • twonk9098
                                Lenovo Legion 5 high fan spin turns off after 34 seconds
                                by twonk9098
                                I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                I have tried a few new bios but exactly...
                                07-14-2024, 11:19 AM
                              • frannyjunk
                                Hisense 40H4F no backlight but turns off after splash screen
                                by frannyjunk
                                So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                                TIA.
                                09-24-2025, 10:59 AM
