Hisense 40H4F no backlight but turns off after splash screen
  • frannyjunk
    • Oct 2010
    • 82
    So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
    TIA.
  • frannyjunk
    • Oct 2010
    • 82
    • Diah
      • Feb 2013
      • 6504
      no risk its just 40 size.... take the screen apart you will see the led defect
      • lotas
        • Jan 2016
        • 4819
        • Russia
        Basically, when the backlight doesn't work, Hisense triggers a protection switch and the power supply cuts off the secondary voltage.
        • Diah
          • Feb 2013
          • 6504
          this is early version from Hisense.. 1080 pixels not 4K or later no protection , and the LED they used as direct LED or Edge one was with zener protection , which they are now with old of production dead already.
          • frannyjunk
            • Oct 2010
            • 82
            After some research, I located the reset button so I reset the tv. Now the backlight is still off, but the tv boot loops. Part of the protection circuitry? I have ordered the backlights from Aliexpress but they won't arrive for another 2 weeks. In the meantime, I am wondering if I should also buy a main board. Seems like a lot to spend on a 40" tv. Any guesses if the main board is ok?
            • lotas
              • Jan 2016
              • 4819
              • Russia
              I'm not familiar with this chassis and can't comment on this reboot, but it could be due to a faulty backlight. Try disabling the Wi-Fi module, then disconnecting the LVDS cable. If that doesn't help, try connecting to the UART and checking the boot log to see where it's failing. There might be an eMMC issue.
              • frannyjunk
                • Oct 2010
                • 82
                Thanks! At this point, I will wait for the backlights to arrive then will replace them on the tv. Should the tv still bootloop, my next couse of action is to update the firmware using a USB drive. If that fails, then replace the main board. I hope the eMMC is on the main board and not on the lcd panel board.
                • lotas
                  • Jan 2016
                  • 4819
                  • Russia
                  Yes, the eMMC is located on the motherboard, most likely under the heatsink on the processor.
                  • HTR-Informatique
                    Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                    by HTR-Informatique
                    YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                    I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                    On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                    I also changed the screen because the PC fell and the screen was broken.
                    I changed the battery with a new and original battery.
                    I also had corrosion/oxidation on the...
                    02-09-2025, 06:51 AM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                  • turmix
                    AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                    by turmix
                    Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                    The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                    At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                    During another reassembly, I made a mistake, and...
                    01-29-2024, 03:48 AM
                  • FallenOne008
                    Asus G712L No Screen Backlight
                    by FallenOne008
                    Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                    The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                    03-31-2025, 08:27 PM
                  • JunkmanJimbo
                    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                    by JunkmanJimbo
                    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                    No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                    Please help. Thanks in advance!
                    08-12-2025, 11:45 AM
