Replacing AS15-F did not fix solarized image
  • binsonk
    • Apr 2014
    • 182
    My Samsung LN37A550P3F_A (June 2008) flat panel TV is showing a solarized image. This is the only thing wrong with it, as far as I can tell. Based on my research I replaced the gamma IC, AS15-F Channel Voltage Buffer on the T-Con board. Or rather, by trading favors, I had a competent colleague remove and replace the chip using special equipment for surface mounting. After the repair, the solarized image persists, and if anything, got worse. What can be deduced from this?
    a. The problem is elsewhere, not the gamma IC
    b. The chip is DOA
    c. The chip is improperly installed
    a. What else might cause the image to be solarized? Is there another component on the T-Con board that might cause a solarized image? Would replacing the T-Con board fix this issue with good certainty?
    b. If the chip were DOA, would the image be solarized, as before? Could I remove the chip from the board and observe the solarized image? In other words, would I be seeing the same solarized image if the chip were DOA?
    c. Same query as b. If the chip were improperly installed, would the image still be solarized?
    I am discouraged with troubleshooting the T-Con board. Barring a quick fix with high probability of success, I will likely replace the entire T-Con board if I can be reasonably sure of success. Where would be a good place to find and purchase such a replacement?
    T-Con part numbers: AUO 55.37T04.C02 or SKU sj-55.37T04-C02
  • mmartell
    • Oct 2013
    • 3189
    Re: Replacing AS15-F did not fix solarized image
    Check the voltage points with a meter and report back with them. If the graph is bad then the chip or the way in which it was replaced is still bad.
    • Glitcher
      • Mar 2013
      • 673
      • USa
      If one of the legs on the chip is not soldered on properly, it would still cause the image to be solarized, probably not in the same degree as the original though, but still solarized.
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        Seen several threads of DOA AS15 chips lately, Check voltages as mmartell advised. A loose or corroded lvds can also cause this, or possibly failing tab bonds
        If your set on a new tcon ShopJimmy has them in stock, kinda pricey though.
        Liberating magic smoke one part at a time
          1 out 5 replacement AS15 ICs I get from EBAY is bad.
          • binsonk
            • Apr 2014
            • 182
            Please provide data sheet for AS15-F voltage points. Or do I take 48 readings? Unfortunately, there is a large frame bar nearly on top of this chip. I don't have a microscope to examine the solder job, but it looks pretty good with a magnifying glass.
            • tibimakai
              • Jan 2012
              • 3680
              I would go over the pins again, it happened to me before. The second time going over, with the soldering it fixed the problem.
              • Ltank
                • Jun 2013
                • 776
                I buy AS15-F from China, usually takes just over two weeks to get parts. Heck it is cheaper to get parts from China than across the US. Whats wrong with this picture? Odd that Digi-Key or Mouser does not sell them.
                  binsonk: you need to take the DCV at the test points for GAMMA voltage readings, they should be labeled VGMA1, VGMA2,......
                    As you can see, around top right by the connector J1, you can see a bunch of test pads with
                    VGMA1~22.
                    http://www.shopjimmy.com/media/catal...37t04c02_1.jpg
                    • binsonk
                      • Apr 2014
                      • 182
                      I ordered a replacement T-con board, installed it. Result: No image. The lamp or backlight of TV is full on, audio is fine, but no image. I let TV run for an hour, with no change. Then turned TV off and on several times, occasionally producing a set of vertical lines covering a total width of 1 inch or so, located left of center. Mostly, the screen remains blank. I have re-seated the two ribbon cables to T-con board maybe 5 times. Don't know what else to do.
                        What DC voltage do you get at the T-CON SMD fues, check both ends of the fuse for dc Voltage.
                          Originally posted by binsonk
                          I ordered the T-com card, installed it. Result: No image. The lamp or backlight is full on, audio is fine, but no image. I let it run for an hour, with no change. Then turned TV off and on several times, occasionally producing a set of vertical lines covering a total width of 1 inch or so, located left of center. Mostly, the screen remains blank. I have re-seated the two ribbon cables to T-com card maybe 5 times. Don't know what else to do.
                          Try with old T-con and see if you get original solarised picture, will confirm new board is bad, some people do not thoroughly test their boards.
                          • Shinju
                            • Mar 2014
                            • 1239
                            Sounds like a bad panel/tab bond issue.
                            • binsonk
                              • Apr 2014
                              • 182
                              @tom66
                              The AS15-F chip is now completely missing on the old T-Con board. Does this change your recommendation?
                              @budm
                              Is this SMD fuse in the bottom left quadrant of the board, about 1.75" from left edge, 0.5" from bottom edge, labelled "AVDD F1" ? There's another F1 in the bottom right quadrant of the board, 2.25" from right edge, 0.25" from bottom edge, a white-colored component with "K" on top. Where is the SMD fuse on the board?
                                Yes, it probably would not work without AS15-F.
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  @tom66
                                  If you want to solider the old one back on, otherwise you might need to find another board.
                                    • 31290
                                    datasheet
                                    • binsonk
                                      • Apr 2014
                                      • 182
                                      The voltage across the component (SMD fuse?) with "K" on top reads 0.015 VDC, with TV turned on, of course.
                                        You shoulfd check both ends with black lead on chassis ground, red on fuse.
                                        • rimwall
                                          Sony KD-65x7500D - double image - Tcon or Panel?
                                          by rimwall
                                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                          11-18-2025, 02:09 AM
                                        • Focus2005
                                          HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                                          by Focus2005
                                          Hello everyone.
                                          I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                                          05-01-2025, 05:41 AM
                                        • reach7458
                                          philips 37pf8404 solarized image (changed as15f already)
                                          by reach7458
                                          I got here an philips 37pf8404 with a solarized image. image one
                                          First guess its a bad as15f. so I replaced it with another. Same issues
                                          So I replaced it again with a rm5101. Same issues
                                          Problem is that is projecting a solarized image irregularly. When I pull the hdmi cable and put it back all is okay for a undetermined time. It also helps if I change the input from one hdmi port and back.
                                          One thing thats weird and I don't remember if it was the case with the previous tvs I repaired.
                                          When the image is solarized it doesn't affect...
                                          08-03-2020, 08:27 AM
                                        • jason123
                                          ASUS PG27V Rolling Image - TCON?
                                          by jason123
                                          Hi there,
                                          My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
                                          I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
                                          It does this even with the monitor not connected to a computer / graphics card....
                                          11-01-2025, 05:41 PM
                                        • jason123
                                          Hisense 65R6E3 double-image / horizontal strips - TCON?
                                          by jason123
                                          Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                                          07-19-2025, 08:07 AM
