Replacing AS15-F did not fix solarized image
  • binsonk
    • Apr 2014
    • 182
    Re: Replacing AS15-F did not fix solarized image
    Thanks, tom66. Measuring as you describe, the voltage is 215 to 218 VDC, reading same voltage w.r.t. chassis ground on both sides of the SMD fuse.
      I think you should check that again, no offence intended but I do not believe you. 218V?
      • binsonk
        • Apr 2014
        • 182
        Yeah, you're right, my voltmeter is shot. But it measures *something*, so I took a reading of a 12-volt car battery (2 samples), and obtained by ratio an approximation for the SMD fuse voltage at 17.4 VDC. Best I can do, until a get a new voltmeter.
          • 31291
          put a new battery in the meter!
          • binsonk
            • Apr 2014
            • 182
            With brand new batteries, the fuse voltage reads about 100 VDC on this multimeter. I originally expected a value between 12 and 16 VDC, since it's just a logic card. An SMD fuse, code K, is rated at 1.5 A / 32 V, but I don't know if those values apply to this particular fuse. Does anyone know the actual expected value for the fuse voltage of this T-Con board?
              Show us what range you are measuring on, maybe your meter is bust and you need to replace it. If we cannot trust the meter readings it creates problems for us.
              • binsonk
                • Apr 2014
                • 182
                Purchased new digital multimeter. The SMD fuse reads 11.85 VDC, on either side, w.r.t. chassis ground.
                • tom thumb
                  • Jul 2013
                  • 66
                  Thanks for the data sheet I noticed right on the 1st page
                  The EC5575 is available in a space saving
                  48-pin TQFP package, and the operating
                  temperature is from –20°C to +85°C. we all know they get hotter than 85°C and
                  I have added some sort of heatsink whenever possible to them on the tv's I work on
                  because alot of them don't use any metal shield or anyway to disipate the heat
                  • binsonk
                    • Apr 2014
                    • 182
                    The SMD fuse voltage is 11.85 VDC, either end. What else should I measure? In order to return this board in a timely way, I need to establish whether it works by the end of today, Friday, July 25. I bought a new digital multimeter for the purpose.
                    • binsonk
                      • Apr 2014
                      • 182
                      I returned the T-Con board that would not produce video, got a replacement, installed it. Now the TV is working fine.
                        Thanks for the follow-up.
                        • rimwall
                          Sony KD-65x7500D - double image - Tcon or Panel?
                          by rimwall
                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                          11-18-2025, 02:09 AM
                        • Focus2005
                          HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                          by Focus2005
                          Hello everyone.
                          I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                          05-01-2025, 05:41 AM
                        • reach7458
                          philips 37pf8404 solarized image (changed as15f already)
                          by reach7458
                          I got here an philips 37pf8404 with a solarized image. image one
                          First guess its a bad as15f. so I replaced it with another. Same issues
                          So I replaced it again with a rm5101. Same issues
                          Problem is that is projecting a solarized image irregularly. When I pull the hdmi cable and put it back all is okay for a undetermined time. It also helps if I change the input from one hdmi port and back.
                          One thing thats weird and I don't remember if it was the case with the previous tvs I repaired.
                          When the image is solarized it doesn't affect...
                          08-03-2020, 08:27 AM
                        • jason123
                          ASUS PG27V Rolling Image - TCON?
                          by jason123
                          Hi there,
                          My son's gaming monitor started having rolling image (vertical roll - See Video) similar to vertical sync issue, or T-CON problems in TVs. Has anyone see this? is it fixable or a throw away?
                          I haven't even opened it up yet. Does it have a T-CON? Help is appreciated.
                          It does this even with the monitor not connected to a computer / graphics card....
                          11-01-2025, 05:41 PM
                        • jason123
                          Hisense 65R6E3 double-image / horizontal strips - TCON?
                          by jason123
                          Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                          07-19-2025, 08:07 AM
