KDL-40S4100 lcd help please
Re: KDL-40S4100 lcd help please
You will need to find out how to access the hidden service menu. Each manufactor has their own button combo to get in. I would suggest googling your Panels model number and xxx-xxxxxx how to access the service menu via remote ect.Comment
Tom this is what i got on my test points on tcon. Top left side
1.174,3.176,4.724,2.198
bottom left side
540.1,2.361,4.071,5.047,6.35
now right top side
8.90,10.40,11.19,12.57,14.72
right bottom
10.30,10.69,11.89,13.79
i dont have microsoft office so i couldnt open that file if u can do it for me i would apprecaite it, thanksComment
You need to show it like this to make it easier for us the understand:
VGMA1 = XXX V
VGMA2 = XXXX VNever stop learning
sorry didnt know, ive never done this
1=14.72
2=13.79
3=12.57
4=11.89
5=11.19
6=10.69
7=10.40
8=10.30
9=8.90
10=6.35
11=5.198
12=5.047
13=4.724
14=4.071
15=3.176
16=11.89
17=1.174
18=540.1Comment
"16=11.89" that is bad.Never stop learning
I let Tom put the numbers in his spread sheet to see what he thinks.Never stop learning
Please recheck #16 & #18 but it doesn't look right to me... so bad t-con IMO.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Is your meter perhaps an autoranging meter?
The curve looks suspicious, especially around #6 to #8, but apart from that, I can't see any major problems.
So it's hard to be sure, I wouldn't expect image to look that bad with the voltages slightly out.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
UPDATE. I changed the tcon after having solarized image same thing. So tcon and main have both been changed.. so now what do I need to do to get into the service menu and what do I need to adjust there? Also when I press power it takes almost 60 sec for the picture to show...Comment
Can anyone tell me how to access service menu and what to adjust?Comment
Hi.
The new main board is not compatible with the old board ,different firmware.
There are no files available to download for this model.
I have tried 3 different A boards 2 different t-cons .
Go by the serial number of the TV.Comment
Your best option would be to download and install firmware update before going any furtherComment
I too had the solarized picture after fixing the "power led goes green, no picture or backlight" problem by replacing the main board in my KDL40S4100, part number 48.71H01.031.
I figured the solarized image problem out by Googling and finally finding shopjimmy's Youtube video on Samsung solarization after main board replacement: the Panel Version that the main board is expecting is different than the panel actually in the TV.
I found another thread somewhere with the Sony service menu code. Using the Sony remote, press in sequence: Power on, wait for TV to come completely on, left, right, muting, center button, muting, menu.
You will see the service menu, and at the bottom there is the critical data you need, namely the Model Name and Panel Version. Make sure you were sold the right board. I was sold a board pulled from Model Name KDL46S4100, which of course is configured to expect a different Panel Version than the Panel Version that is actually in my KDL40S4100 (which is LCD_AU037_1920).
Armed with this knowledge, you can then ask better questions of the sellers when buying the main board.
I'm asking the ebay seller to swap me the correct board since he technically sold me the wrong product.
It is POSSIBLE that a firmware update will reconfigure the main board as the correct Model Name and Panel Version, but I do not know if this is will occur since I cannot actually find the firmware anywhere. Sony's website does not carry it any longer, and after hours of Googling, I have not found anyone sharing it.
I am looking for the firmware file "KDL40S4100_V1.115.zip" specifically named in the software update manual (Google "Servicer Software Update Procedure"). Does anybody have this to share here?Comment
I have this from Sony:Attached Filesif you find these attachements useful please consider making a small donation to the site
@R_J:
Thank you from both me and all the other KDL40S4100 owners out there who are stranded firmware-wise!
The funny thing is, the seller has agreed to RMA the board, so I won't be attempting the firmware update on this KDL46S4100 board (don't want to risk bricking it). So we won't find out whether the firmware overwrites the configuration's "Model Name" or not--this time. I'll use the firmware on the next board I buy, though, so thanks!
Perhaps someone else who is stuck with a KDL46S4100-configured board and has no option to return it can try flashing it now and seeing if it works...
I am not certain about this, but it appears the LCD panel in my KDL40S4100 is a LTY400HA11. At least that's what the sticker says. IF that is true, then that means the KDL46S4100-configured board is expecting to see a LCD_AU037_1920 LCD panel. ShopJimmy's online store seems to support the sticker: his items for the KDL40S4100 are organized by "Panel Sticker Number: LTY400HA11"
Unfortunately, his items for the KDL46S4100 are organized by "Panel Sticker Number: LTY460HB10, LTZ460HB10" so there is no obvious correlation between the sticker number and the "LCD_AU037_1920" reported by the factory service menu.Last edited by dchang0; 06-21-2014, 03:46 AM.Comment
I have a VIZIO E70-E3.
Symptoms: Black screen, no picture, but LED backlights are working.
I probed the power board and voltages are as listed on the board.
Main board appears fine, too.
I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
There are two separate ribbon cables feeding the LCD.
If both are connected, the screen is black.
If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and... -
by iglitareHi,
Or is it always a bad/shorted... -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by shelby5041hi
i have a samsung lcd tv
it powers on with sound and backlight but no picture
all voltages from PS are good 12v 3.3v and 5v
whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
no 12v at the tcon fuse
i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
the odds of having 2... - Loading...
