KDL-40S4100 lcd help please
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Re: KDL-40S4100 lcd help please
    Originally posted by shinju
    at least parts for your sony are cheap and plentiful
    i do have a universal here. What would i do?
    • Shinju
      • Mar 2014
      • 1239
      You will need to find out how to access the hidden service menu. Each manufactor has their own button combo to get in. I would suggest googling your Panels model number and xxx-xxxxxx how to access the service menu via remote ect.
      • mattstolte
        • Dec 2013
        • 612
        • usa
        Tom this is what i got on my test points on tcon. Top left side
        1.174,3.176,4.724,2.198
        bottom left side
        540.1,2.361,4.071,5.047,6.35
        now right top side
        8.90,10.40,11.19,12.57,14.72
        right bottom
        10.30,10.69,11.89,13.79
        i dont have microsoft office so i couldnt open that file if u can do it for me i would apprecaite it, thanks
          You need to show it like this to make it easier for us the understand:
          VGMA1 = XXX V
          VGMA2 = XXXX V
          • mattstolte
            • Dec 2013
            • 612
            • usa
            Originally posted by budm
            you need to show it like this to make it easier for us the understand:
            Vgma1 = xxx v
            vgma2 = xxxx v
            sorry didnt know, ive never done this
            1=14.72
            2=13.79
            3=12.57
            4=11.89
            5=11.19
            6=10.69
            7=10.40
            8=10.30
            9=8.90
            10=6.35
            11=5.198
            12=5.047
            13=4.724
            14=4.071
            15=3.176
            16=11.89
            17=1.174
            18=540.1
            • mattstolte
              • Dec 2013
              • 612
              • usa
              #26
              Originally posted by Shinju
              At least parts for your Sony are cheap and plentiful
              I tried looking up how to get into the service manual I cant find it. panel number is lty400ha11
                "16=11.89" that is bad.
                • mattstolte
                  • Dec 2013
                  • 612
                  • usa
                  #28
                  VGMA1 = XXX V
                  VGMA2 = XXXX V
                  I did put it there now thanks
                  • mattstolte
                    • Dec 2013
                    • 612
                    • usa
                    #29
                    so bad tcon for sure?
                      I let Tom put the numbers in his spread sheet to see what he thinks.
                        Please recheck #16 & #18 but it doesn't look right to me... so bad t-con IMO.
                        • mattstolte
                          • Dec 2013
                          • 612
                          • usa
                          #32
                          ok 16= 2.36
                          but 18 is the same
                            Is your meter perhaps an autoranging meter?
                            The curve looks suspicious, especially around #6 to #8, but apart from that, I can't see any major problems.
                            So it's hard to be sure, I wouldn't expect image to look that bad with the voltages slightly out.
                            • mattstolte
                              • Dec 2013
                              • 612
                              • usa
                              #34
                              UPDATE. I changed the tcon after having solarized image same thing. So tcon and main have both been changed.. so now what do I need to do to get into the service menu and what do I need to adjust there? Also when I press power it takes almost 60 sec for the picture to show...
                              • mattstolte
                                • Dec 2013
                                • 612
                                • usa
                                #35
                                Can anyone tell me how to access service menu and what to adjust?
                                • iosubida
                                  • Jun 2009
                                  Hi.
                                  The new main board is not compatible with the old board ,different firmware.
                                  There are no files available to download for this model.
                                  I have tried 3 different A boards 2 different t-cons .
                                  Go by the serial number of the TV.
                                  • chrismurphy
                                    • May 2014
                                    • 251
                                    • australia
                                    #37
                                    Your best option would be to download and install firmware update before going any further
                                    • dchang0
                                      • Jun 2014
                                      • 33
                                      I too had the solarized picture after fixing the "power led goes green, no picture or backlight" problem by replacing the main board in my KDL40S4100, part number 48.71H01.031.
                                      I figured the solarized image problem out by Googling and finally finding shopjimmy's Youtube video on Samsung solarization after main board replacement: the Panel Version that the main board is expecting is different than the panel actually in the TV.
                                      I found another thread somewhere with the Sony service menu code. Using the Sony remote, press in sequence: Power on, wait for TV to come completely on, left, right, muting, center button, muting, menu.
                                      You will see the service menu, and at the bottom there is the critical data you need, namely the Model Name and Panel Version. Make sure you were sold the right board. I was sold a board pulled from Model Name KDL46S4100, which of course is configured to expect a different Panel Version than the Panel Version that is actually in my KDL40S4100 (which is LCD_AU037_1920).
                                      Armed with this knowledge, you can then ask better questions of the sellers when buying the main board.
                                      I'm asking the ebay seller to swap me the correct board since he technically sold me the wrong product.
                                      It is POSSIBLE that a firmware update will reconfigure the main board as the correct Model Name and Panel Version, but I do not know if this is will occur since I cannot actually find the firmware anywhere. Sony's website does not carry it any longer, and after hours of Googling, I have not found anyone sharing it.
                                      I am looking for the firmware file "KDL40S4100_V1.115.zip" specifically named in the software update manual (Google "Servicer Software Update Procedure"). Does anybody have this to share here?
                                      • R_J
                                        • Jun 2012
                                        • 9625
                                        I have this from Sony:
                                        • dchang0
                                          • Jun 2014
                                          • 33
                                          @R_J:
                                          Thank you from both me and all the other KDL40S4100 owners out there who are stranded firmware-wise!
                                          The funny thing is, the seller has agreed to RMA the board, so I won't be attempting the firmware update on this KDL46S4100 board (don't want to risk bricking it). So we won't find out whether the firmware overwrites the configuration's "Model Name" or not--this time. I'll use the firmware on the next board I buy, though, so thanks!
                                          Perhaps someone else who is stuck with a KDL46S4100-configured board and has no option to return it can try flashing it now and seeing if it works...
                                          I am not certain about this, but it appears the LCD panel in my KDL40S4100 is a LTY400HA11. At least that's what the sticker says. IF that is true, then that means the KDL46S4100-configured board is expecting to see a LCD_AU037_1920 LCD panel. ShopJimmy's online store seems to support the sticker: his items for the KDL40S4100 are organized by "Panel Sticker Number: LTY400HA11"
                                          Unfortunately, his items for the KDL46S4100 are organized by "Panel Sticker Number: LTY460HB10, LTZ460HB10" so there is no obvious correlation between the sticker number and the "LCD_AU037_1920" reported by the factory service menu.
                                          • Fly_Among_Stars
                                            VIZIO E70-E3 Half picture with half TCON
                                            by Fly_Among_Stars
                                            I have a VIZIO E70-E3.
                                            Symptoms: Black screen, no picture, but LED backlights are working.
                                            I probed the power board and voltages are as listed on the board.
                                            Main board appears fine, too.
                                            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                            There are two separate ribbon cables feeding the LCD.
                                            If both are connected, the screen is black.
                                            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                            04-24-2023, 08:20 PM
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • shelby5041
                                            Samsung LCD TV no picture backlight on no 12v at tcon
                                            by shelby5041
                                            hi
                                            i have a samsung lcd tv
                                            it powers on with sound and backlight but no picture
                                            all voltages from PS are good 12v 3.3v and 5v
                                            whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                            i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                            no 12v at the tcon fuse
                                            i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                            the odds of having 2...
                                            10-08-2021, 08:21 AM
