KDL-40S4100 lcd help please
  • dchang0
    • Jun 2014
    • 33
    Re: KDL-40S4100 lcd help please
    I used ShopJimmy's online store to deduce that the KDL46S4100 main board I got is most likely part number 1-857-092-21 (not the alternative 1-857-092-41). The System Firmware value of "V1.021,V1.008P" has the "21" in it (presumably the 1.008P is the actual version, which does match what the main menu says and which is older than the newest 1.115). Also, the serial number reported in the factory service menu is in the correct range for the 1-857-092-21 board.
    Thus, I can deduce from ShopJimmy's store that the LCD panel that the main board is expecting is either the 46" LTY460HB10 or LTZ460HB10. There is no cross-reference anywhere I can find that shows what "LCD_AU037_1920" translates to, so I still cannot tell for sure whether the "Panel Version: LCD_AU037_1920" shown in the factory service menu is the LCD panel that the main board DETECTS that it's attached to or EXPECTS to be attached to.
      LTY460HB10 = Samsung 46" FHD Panel
      LCD_AU037_1920 = AUO 37" FHD Panel
      • dchang0
        • Jun 2014
        • 33
        Thanks, tom66!
        Whoa, that's crazy! Then the 1-857-092-21 board from a 46S4100 somehow got configured with "Panel Version: LCD_AU037_1920" even though neither the 40S4100 nor 46S4100 has a 37" panel in it. I wonder what happened...
        It is probably safe to say then that the Panel Version is what the main board EXPECTS to be connected to and that it does not autodetect what it is actually connected to.
        • Fly_Among_Stars
          VIZIO E70-E3 Half picture with half TCON
          by Fly_Among_Stars
          I have a VIZIO E70-E3.
          Symptoms: Black screen, no picture, but LED backlights are working.
          I probed the power board and voltages are as listed on the board.
          Main board appears fine, too.
          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
          There are two separate ribbon cables feeding the LCD.
          If both are connected, the screen is black.
          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
          04-24-2023, 08:20 PM
        • iglitare
          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
          by iglitare
          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
          Backlight seems to work, Sound (Setup menu after reset) works.
          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
          With my small knowledge i would think at least the cables are good.
          Can this happen because of a bad tcon board?
          Or is it always a bad/shorted...
          09-04-2025, 07:13 AM
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • shelby5041
          Samsung LCD TV no picture backlight on no 12v at tcon
          by shelby5041
          hi
          i have a samsung lcd tv
          it powers on with sound and backlight but no picture
          all voltages from PS are good 12v 3.3v and 5v
          whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
          i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
          no 12v at the tcon fuse
          i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
          the odds of having 2...
          10-08-2021, 08:21 AM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
